What is the final velocity of the particle?
In summary, the conversation discusses using a force-time graph to find the velocity of a 2.40 kg ice block at t = 11 s. The net force is found to be 15N and the kinematic equation is used to find the acceleration. However, the calculated velocity is way off and the question is asked about where the mistake was made. It is suggested to factor in the mass and initial velocity, or consider the impulse of the force to find the change in momentum and then convert it to a change in velocity.
DavidAp
44
The image below "gives, as a function of time t, the force component x that acts on a 2.40 kg ice block that can move only along the x axis. At t = 0, the block is moving in the positive direction of the axis, with a speed of 2.5 m/s. What is its velocity, including sign, at t = 11 s?
Answer: 8.8 m/s"
Relevant equations:
F=ma
Vf = Vo + at
I was thinking that the total area under the graph would give the net force the component seeing that the y-axis represents Force and the x-axis represents Time. With that I got the net force 15N (29N - 14N). So,
F = 25N
F = ma
m = 2.40kg
Vo = 2.5m/s
t = 11
Vf = ?
Therefore, with the given information, I decided to use the following kinematic equation to find acceleration.
Vf = Vo +at
a = (Vf - Vo)/t
So,
F = m(Vf - Vo)/t
And if we solve for Vf we get
Vf = tF/m + Vo
____________________________________________________________
However, when I plug in the units I get an answer that is way way off.
Vf = 11(15)/2.4 + 2.5
Vf = 165/2.4 + 2.5
Vf = 68.75 + 2.5
Vf = 71.25 m/s
I know I added in the units at the end but I checked and the units come out correctly. Therefore, my question is: what did I do wrong? Why am I so far off? Obviously I did something horribly wrong in my calculation, but where?
Thank you for taking the time review my question. Any help is much appreciated.
Answer: 8.8 m/s"
Relevant equations:
F=ma
Vf = Vo + at
F = 25N
F = ma
m = 2.40kg
Vo = 2.5m/s
t = 11
Vf = ?
Vf = Vo +at
a = (Vf - Vo)/t
So,
F = m(Vf - Vo)/t
Vf = tF/m + Vo
Vf = 165/2.4 + 2.5
Vf = 68.75 + 2.5
Vf = 71.25 m/s
This is a Force time graph. If you factor in the mass, you have an acceleration time graph. The area "under" and acceleration time graph gives change in velocity does it not?
Don't forget it had an initial velocity.
EDIT: Alternately, the area under a Force-time graph gives you the impulse of the force. The impulse gives you the change in momentum, which can easily be changed to a change in velocity.
FAQ: What is the final velocity of the particle?
The final velocity of a particle is the speed and direction at which it is moving at the end of a particular time interval.
How is the final velocity calculated?
The final velocity can be calculated by using the formula: final velocity = initial velocity + acceleration x time. This formula is based on the principles of Newton's laws of motion.
What are the units of final velocity?
The units of final velocity are usually in meters per second (m/s) or kilometers per hour (km/h), depending on the system of measurement being used.
Can the final velocity be negative?
Yes, the final velocity can be negative if the particle is moving in the opposite direction of its initial velocity. This indicates a change in direction or deceleration.
How does the mass of the particle affect its final velocity?
The mass of the particle does not directly affect its final velocity. However, it can affect the acceleration and therefore indirectly impact the final velocity according to Newton's second law of motion (F=ma).
