What is the limit of a^x when a tend to infinity and x tend to 0?
In summary, the limit of [a]^x when [a] approaches infinity and [x] approaches zero is indeterminate and can approach a finite number, positive or negative infinity, or not exist at all. This concept is important in the renormalization of Quantum Field Theory and can be interpreted in different ways such as using L'hopital's rule or considering the rates at which the base and exponent approach their respective limits.
ndung200790
519
Please teach me this:
What is the limit of [a]^{x} when [a]\rightarrow[/infinity] and[x]\rightarrow[/zero].It seem to me that it is divergent as lna,but I can not demontrate.It appears in the renormalization of Quantum Field Theory.
Thank you very much in advanced.
I am not sure how this limit should be interpreted formally.
We know that [itex]\lim_{x\to\infty}x^{1/x}=1[/itex], but it's not the same limit of course.
According to http://en.wikipedia.org/wiki/Multivariable_calculus:
"Since taking different paths toward the same point yields different values for the limit, the limit does not exist."
The limit is one.
Lim(x,a -> 0,inf) a^x= L
lim x(lna)= ln(L)
lim (lna)/(1/x) = ln(L)
By l'hopital's, lim (1/a) / (-1/x^2) = ln(L)
lim(-x^2/a)=0=ln(L)
L=e^0=1
If we set a = e^(1/x) and take the limit from x to zero from the positive side, we get:
[tex]\lim_{a,x \to \infty,0} a^x = \lim_{x \downarrow 0} (e^{\frac 1 x})^x = \lim_{x \downarrow 0} e^1 = e[/tex]
In other words, it matters which path you take, so the limit does not exist.
Calculus textbooks say it this way: " [tex]\infty^0[/tex] is an indeterminate form ".
Another way to look at the OP's problem is the rate at which the exponent approaches infinity and the base approaches 0. Depending on the rates, this could approach some finite number, +/-infinity or not exist.
FAQ: What is the limit of a^x when a tend to infinity and x tend to 0?
What is the concept of a limit when a tends to infinity and x tends to 0?
The concept of a limit refers to the value that a function approaches as its independent variable (in this case, a) approaches a particular value (in this case, infinity) while another variable (x) approaches a different value (in this case, 0).
How do you calculate the limit of a^x when a tends to infinity and x tends to 0?
The limit of a^x when a tends to infinity and x tends to 0 can be calculated using the following formula: lim a^x = e^(lim x ln a) where e is the base of the natural logarithm and ln a is the natural logarithm of a.
Is the limit of a^x when a tends to infinity and x tends to 0 always equal to 1?
No, the limit of a^x when a tends to infinity and x tends to 0 is not always equal to 1. It depends on the value of a. If a is greater than 1, the limit will be infinity. If a is between 0 and 1, the limit will be 0.
Can the concept of a limit be applied to other functions besides a^x?
Yes, the concept of a limit can be applied to any function. It is used to determine the behavior of a function as its input approaches a certain value. In this case, we are looking at the limit of a^x as a tends to infinity and x tends to 0, but the concept can be applied to any function and any values of its variables.
Why is the limit of a^x when a tends to infinity and x tends to 0 important in mathematics?
The limit of a^x when a tends to infinity and x tends to 0 is important because it helps us understand the behavior of exponential functions. It also has applications in calculus, where it is used to find the derivative of exponential functions. Furthermore, the concept of a limit is crucial in many other areas of mathematics, such as differential equations and optimization problems.
