What is the magnitude of the downward force
NIn summary, to determine the magnitude of the downward force exerted on the fulcrum, we use momentum equations to determine the boy's weight, which is one-fourth of the man's weight. Then, using forces equations, we find that the downward force exerted on the fulcrum is equal to the weight of the boy plus the weight of the man, which is equal to 981 Newtons.
catmd13
80-kg man balances the boy on a teeter-totter as shown.
Note: Ignore the weight of the board. What is the magnitude of the downward force exerted on the fulcrum in Newtons?
Note: Ignore the weight of the board. What is the magnitude of the downward force exerted on the fulcrum in Newtons?[/b]
Perhaps like this. First we use momentum equations to determine boys weight.
ΣM=0 mb*g*4=mm*g*1
mb=mm1/4
mb=80/4=20
Then we use forces equations.
ΣF=0 mb*g+mm*g-Ff
Ff=mb*g+mm*g
Ff=20*9,81+80*9,81
Ff=981 N
The magnitude of the downward force exerted on the fulcrum in Newtons is equal to the weight of the 80-kg man plus the weight of the boy. Assuming the boy has a weight of 40 kg, the total downward force would be 120 kg (80 kg + 40 kg) or approximately 1176 Newtons (120 kg x 9.8 m/s^2). This is because the downward force exerted on the fulcrum is equal to the sum of all the forces acting on the teeter-totter, which includes the weight of the man and the boy.
FAQ: What is the magnitude of the downward force
What is the definition of magnitude of the downward force?
The magnitude of the downward force is the size or strength of the force acting in a downward direction on an object. It is a scalar quantity, meaning it only has a magnitude and no direction.
How is the magnitude of the downward force calculated?
The magnitude of the downward force is calculated by multiplying the mass of an object by the acceleration due to gravity (9.8 m/s²). This can be represented by the equation F=mg, where F is the force, m is the mass, and g is the acceleration due to gravity.
What factors affect the magnitude of the downward force?
The magnitude of the downward force is affected by the mass of the object and the acceleration due to gravity. The greater the mass of an object, the greater the downward force, and the greater the acceleration due to gravity, the greater the downward force.
How is the magnitude of the downward force different from the weight of an object?
The magnitude of the downward force is the measurement of the force acting on an object in a downward direction, while weight is a measurement of the force of gravity acting on an object. Weight takes into account the mass of an object and the acceleration due to gravity, while the magnitude of the downward force only considers the force acting on the object in a downward direction.
Can the magnitude of the downward force ever be negative?
No, the magnitude of the downward force is a scalar quantity and cannot have a negative value. However, the direction of the force can be negative, indicating that it is acting in the opposite direction (upward) of the chosen reference direction.
