What is the significance of taking the derivative of y=sin^-1(x)?
  • Thread starter JDude13
In summary: This topic is a bit strange. There are MANY expressions in physics, chemistry, engineering, etc. that have the SAME mathematical form as this. You are fishing to put more "meaning" into this than there really is.
JDude13
95
I was mucking around with graphmatica and decided to take the derivitive of
[tex]y=\sin^{-1}(x)[/tex]
and got
[tex]y=\frac{1}{\sqrt{1-x^2}}[/tex]
which is the lorentz factor with
[tex]\beta=x[/tex]
and
[tex]\gamma=y[/tex]
Does this have any significance?
No significance for relativity.
It just comes from sin^2 +cos^2=1.
If [itex]y= sin^{-1}(x)[/itex] then x= sin(y). dx/dy= cos(y) so that [itex]dy/dx= 1/cos(y)= 1/cos(sin^{1}(x))[/itex]. Since, as Meir Achuz said, [itex]sin^2(x)+ cos^2(x)= 1[/itex], [itex]cos(x)= \sqrt{1- sin^2(z)}[/itex] so that [itex]cos(sin^{-1}(x)= \sqrt{1- sin^2(sin^{-1}(x)}= \sqrt{1- x^2}[/itex].
That is, [itex]dy/dx= 1/\sqrt{1- x^2}[/itex].
(I assume you meant [itex]y'= 1/\sqrt{1- x^2}[/itex] not [itex]y= 1/\sqrt{1- x^2}[/itex].)
dunno. Like i said. I was mucking around with graphmatica.
Why WOULD it have any significance?
Why WOULDN'T it have any significance?
I'm asking you, I'm wondering why you would think it would have significance. Do you know how to differentiate/integrate inverse trig functions (not with the program you mentioned)?
no... I was just a little confused when it happened.
and got
[tex]\beta=x[/tex]
and
[tex]\gamma=y[/tex]
As HallsofIvy pointed out, it should be [tex]dy/dx=\frac{1}{\sqrt{1-x^2}}[/tex]
I do see the significance myself, or maybe better to say "I see the relation". I'd agree with your assessment. It's just a matter of understanding how the abstract math applies to the physical model of relativity theory. If x = v/c, then dy/dx = gamma (not y = gamma) where c=1. We then have the gamma factor of relativity, and the angular orientation differential (in 4-space) between the 2 frames of interest ... y = theta = sin-1(v/c).
GrayGhost
Zz.
FAQ: What is the significance of taking the derivative of y=sin^-1(x)?
What is the derivative of y=sin^-1(x)?
The derivative of y=sin^-1(x) is equal to 1/√(1-x^2).
How do you find the derivative of y=sin^-1(x)?
To find the derivative of y=sin^-1(x), you can use the inverse trigonometric identity: d/dx (sin^-1(x)) = 1/√(1-x^2).
What is the meaning of the derivative of y=sin^-1(x)?
The derivative of y=sin^-1(x) represents the instantaneous rate of change of the inverse sine function at a given point. It measures how much the output value of the function changes with respect to the input value.
Can the derivative of y=sin^-1(x) be simplified further?
Yes, the derivative of y=sin^-1(x) can be simplified further using algebraic manipulation. It can be rewritten as (1/√(1-x^2)) * (1-x^2/1-x^2), which simplifies to 1/(1-x^2).
How is the derivative of y=sin^-1(x) related to the derivative of y=sin(x)?
The derivative of y=sin^-1(x) and y=sin(x) are related through the inverse trigonometric identity: d/dx (sin^-1(x)) = 1/√(1-x^2) = d/dx (sin(x)). This shows that the derivatives of these two functions are equal but with opposite signs.
