What really is the charge of the electron?
In summary, the conversation discusses the natural shielding caused by photon to electron/anti-electron pair fluctuations and how it reduces as you get closer to the electron. This leads to the question of what the actual charge of an electron is, which is dependent on the energy at which the measurement is made. The shielding is a result of renormalization group flow and can be observed in condensed matter physics. The charge of an electron is a well-known value that has been measured multiple times and is used in various experiments and calculations.
Somali_Physicist
117
In my study of Quantum physics i have arrived at the natural shielding caused by photon to electron/anti-electron pair fluctuations.The shielding reduces as you get closer the electron which naturally leads me to the question.What actually is the charge on an electron?
It depends on the energy at which you make the measurement of the charge. That is what the "shielding" is really telling you. A more technical description of what is going on is "renormalization group flow".
Likes vanhees71
The charge of an electron is the published value in CODATA and PDG handbook. If this value is wrong, many particle accelerators, especially those synchrotron light sources and FELs, will be in deep doo doo, because they were built based on the physics that used that value.
We know about shielding. In fact, in condensed matter physics, this is an everyday issue. It still does not detract from us knowing its value, even considering the issue of quantum fluctuations that surround every particle that we know. Do the e/m measurement using Helmholtz coils as many times as you want, and you'll get the same answer.
Zz.
Likes Dadface
Which, as I understand it, is the low energy value--in renormalization group terms, it's the value that the coupling constant flows to in the limit of zero interaction energy. I agree that this value has been measured many, many times in experiments and is not in dispute.
Likes vanhees71
Does the coupling constant change with self-energy? With that I mean if an electron has more kinetic energy does its self-energy increase and therefor the coupling constant?
Cheers
"Self-energy" is a vague term. The coupling constant depends on the interaction energy--the total energy of all particles involved in the interaction, in the center of mass frame.
Kinetic energy is frame-dependent, so it can't be a factor in the coupling constant.
Yes of course, thanks.
Cheers
By definition the change of the coupling constant comes from radiative vertex corrections, i.e., one-particle irreducible (1PI) Feynman diagrams with three external amputated legs (electron, positron, and photon lines) and loops.
However since QED is an Abelian gauge theory there are socalled Ward-Takahashi identities, which connect this tree-point vertex function with the electron self energy (1PI diagram with two external amputated electron-positron lines). This connects the wave-function renormalization of the electron/positron with the renormalization of the coupling constant.
In non-Abelian gauge theories you can play a similar trick using the socalled background-field gauge, where you get similarly simple Ward-Takahashi identities as in QED, because in this particular gauge the effective quantum action becomes gauge invariant itself. Then, in this gauge, this implies that the gauge-boson wave-function reormalization factor is related with the coupling-constant renormalization factor through a QED-like Ward identity, and thus you don't need to evaluate the vertex corrections to get the running of the coupling (and asymptotic freedom!) but the somewhat less complicated gauge-field self-energy.
For details, see my QFT manuscript:
https://th.physik.uni-frankfurt.de/~hees/publ/lect.pdf
B-level?
Argh. Sorry, I always overlook the levels.
Likes Demystifier
Charge measurement fluctuates with energy as this induces photons to spontaneously come into existence and thus increasing shielding (i'm assuming). What i am asking is that if you get rid of the fluff of vacuum shielding what is the charge left on the electron.After all as the shielding causes the electron to be a function of radius how could we even measure this?
Zz.
Well how do we know that this shielding doesn't reduce the effective electric charge and thus all classical experiments? after all its only at small distances that this effect fluctuates.Similar how we can assume relativistic effects don't exist at Newtonian speeds.
And the answer is that you can't get rid of the vacuum shielding without getting rid of the electron itself as well. The two are inseparable. There is no such thing as an electron without the vacuum shielding but with charge still left.
The best you can do is to probe the electron with a wide range of interaction energies and see how the measured charge varies.
I have no idea what you mean by this.
So where is this reduction? Don't you think that if there is such a thing, it will be detected? And if it can't be detected, what difference does it make, because it is now a unicorn that you've made up that can't be measured?
Zz.
You have it backwards. The "effective electric charge" is what we actually measure in experiments, and there are measurements from various high energy accelerators showing how the measured charge varies with interaction energy. The "shielding" is our best current theoretical explanation of why the measured charge varies with interaction energy (heuristically, because a higher energy probe can penetrate further into the shielding).
so the charge varies from a base point which we know of , okay.
Alright that makes sense, what i meant in the second part was referring to the fine constant changing the closer you get to an electron.
Zz.
But indeed it can be detected. The running of the em. coupling has been measured. At the Z peak it's about ##\alpha_{\text{em}}(m_Z) \simeq 1/128##, compared to ##\alpha_{\text{em}}(0) \simeq 1/137##. Here are just two examples found easily on Google Scholar:
https://arxiv.org/abs/hep-ex/0505072
https://arxiv.org/abs/hep-ph/9411377
Still doesn't make sense.So charge increases the closer you get to the electron yet you are saying we definitely know the charge?
I don't understand where your problem is. The charge of the electron is well determined. It's -1 in natural units. The electromagnetic coupling constant ##\alpha_s## is "running" as is any coupling constant in QFT. There's nothing undefined or uncertain about the electron's charge at all.
What can still be confusing to many is that the electron charge is a coupling constant itself, so if all coupling constants run, then why is the electron charge always exactly -1? (I know why, but I don't know how to explain it at a B-level.)
Likes Somali_Physicist
Or let me try. Doing theoretical physics usually consists of two parts:
(i) Writing the equations.
(ii) Finding the solutions of those equations.
Usually the equations in (i) look simple, but the solutions in (ii) look very complicated. Very often we cannot find exact solutions, but only approximative ones.
The charge ##e=-1## is a parameter that appears in (i). But that's not something that we can measure directly. What we directly measure is some physical measurable quantity ##M##. To find how ##M## depends on ##e##, we must do (ii), that is find the solution of (i). We don't know the exact solution, but we know an approximative solution that has the form
$$M\approx ae^2$$
where ##a## is constant. Another way to write this is
$$e^2\approx \frac{M}{a} \;\;\;\; (1)$$
This is a very simple expression, but unfortunately it is only approximately true. It would be nice if something as simple as that would be exactly true, so we ask the following question: Is it possible to find a similar relation that is both simple and exactly true at the same time?
It turns out that it is possible, by performing a trick that is called "renormalization". Instead of dealing with the charge ##e##, we introduce a new quantity ##e_R## defined by the formula
$$e^2_R\equiv \frac{M}{a} \;\;\;\; (2)$$
The quantity ##e_R## is called renormalized charge. It does not appear in simple equations in (i), but it is useful because the solution (ii) looks simple when expressed in terms of ##e_R##, rather than ##e##. Formula (2) looks very similar to the formula (1), except that formula (2) is exactly true, by definition.
Since ##M## is something that we actually measure, it should not be surprising that it depends on details how the measurement is performed. In particular, it depends on energies of the particles, that is on how close the particles approach each other. Hence ##M## is really a function of energy, so we write ##M=M(E)##. But then (2) implies that ##e_R## is also a function of energy, so (2) must be written as
$$e^2_R(E) = \frac{M(E)}{a} \;\;\;\; (3)$$
Thus we see that the renormalized charge ##e_R## is not a constant, but a function of energy. This dependence of ##e_R## on energy ##E## is called "running". At the same time, ##e=-1## is a true constant. The parameter ##e## is useful because it makes the equations (i) simple, while the ##e_R(E)## is useful because it makes the solution (ii) simple.
The final and perhaps most difficult question is what is the "true" charge? Is it ##e## or is it ##e_R##? Well, the question is more philosophical than physical. It depends on what do you mean by "true". The ##e## is "true" because it appears in the fundamental equations in (i), while ##e_R## is "true" because it is directly related to something measurable.
Likes eys_physics, vanhees71 and weirdoguy
The charge ##e=-1## is a parameter that appears in (i). But that's not something that we can measure directly. What we directly measure is some physical measurable quantity ##M##. To find how ##M## depends on ##e##, we must do (ii), that is find the solution of (i). We don't know the exact solution, but we know an approximate solution that has the form
$$M\approx ae^2$$
The quantity ##e_R## is called renormalized charge. It does not appear in simple equations in (i), but it is useful because the solution (ii) looks simple when expressed in terms of ##e_R##, rather that ##e##. Formula (2) looks very similar to the formula (1), except that formula (2) is exactly true, by definition.
Basically my question is if charge is changing due to screening and all our measurments are altered by this.Is it not fine to say that the electron charge is unknown due to this inherent uncertainty.Or is it such that the electron hits a value at a distance which stays constant from then on?
If by charge you mean my ##e_R##, then the answer is - yes.
Ok so then how do we know what the "charge of an electron" really is.
See the last paragraph in my post #20.
FAQ: What really is the charge of the electron?
What is the charge of an electron?
The charge of an electron is a fundamental physical property of matter, and it is equal to approximately -1.602 x 10^-19 coulombs. This value is considered negative because it is opposite in sign to the charge of a proton, which has a value of +1.602 x 10^-19 coulombs.
How do we know the exact charge of an electron?
The charge of an electron was first determined through experiments by J. J. Thomson in 1897 using a cathode ray tube. Since then, there have been numerous experiments and measurements using different methods, such as the Millikan oil drop experiment and the electron magnetic moment, which have all confirmed the value of the electron's charge.
Why is the charge of an electron important?
The charge of an electron is important because it is one of the fundamental properties that governs the behavior of matter at the atomic and subatomic level. It determines the electromagnetic interactions between particles, which are responsible for many physical phenomena, such as electricity, chemical bonding, and the structure of atoms and molecules.
Can the charge of an electron change?
According to current scientific understanding, the charge of an electron is a constant value and does not change. However, there are some theories that propose the existence of particles with fractional charges, but these have not been confirmed by experiments.
How does the charge of an electron affect its behavior?
The charge of an electron determines its interaction with other charged particles, such as protons and other electrons. It also affects its behavior in electric and magnetic fields, which are essential for many technological applications, such as electronics and medical imaging.
