When does potential energy change?
In summary, the potential energy of a substance does not change when the pressure changes, unless the substance is a body or system of particles that can deform and do mechanical work. In that case, the potential energy will change when pressure is applied. For gases in an enclosed system, the relationship between pressure and potential energy is described by the ideal gas laws and the kinetic theory of matter. The internal energy of a gas can change if the volume or pressure is changed, but the role of potential energy is minimal compared to the kinetic energy of the gas particles.
Angela Liang
36
Why doesn't the potential energy of a substance change when the pressure changes? Or in what case will the potential energy of a substance change?
pl.elaborate about your substance...is it a body or a system of particle or a liquid.?
if the external pressure has deformed it and the work done in deformation can be accounted for as capacity of the body to do mechanical work then the potential energy does change by applying pressure.
a common example is a spring of length l and one changes its length to say l-dl !
How about gas in an enclosed system?
for gas as substance the relation with pressure changes is well anaysed using p, v, t relations and the energy of the system is related to temperature and work -energy theorems deal with it...gas molecules are in incessant motion and a state of potential energy is not well defined.
Thanks. How to describe it using kinetic model of matter?
Kinetic theory is based on the postulates,/ assumptions like gases are composed of a large number of particles that behave like hard, spherical objects in a state of constant, random motion.
These particles move in a straight line until they collide with another particle or the walls of the container. the collisions are perfectly elastic
the interaction between them is during collision
The average kinetic energy of the gas particles depends only on the absolute temperature of the system.
you can see the details in any textbook of physics.
If you've been told that PE doesn't change you've been dealing with a theoretical gas called an ideal gas where any changes of PE are considered to be negligibly small. No gas is perfectly ideal but they approach ideal behaviour as the pressure approaches zero, in other words for very largeparticle separations. There are PE changes with real gases where the particles are more closely packed and to find out why this is so search for the interatomic / intermolecular force curve.
Likes Angela Liang
Potential energy of what object are you talking about?
There is a fixed mass of gas. By increasing the volume, the internal energy doesn't change. So does the temperature change? Cos in my understanding, internal energy= internal KE + internal PE. Does increasing the volume increase the PE of the particles? If so, the internal KE should have decreased as the total internal energy remains unchanged?
when one is handling a gas in a container -it has three parameters pressure, volume and temperature and if you are changing two of them the third may be kept constant .
suppose the volume is being increased keeping temperature constant then the behaviour is pressure decreases .if however the volume is being increased keeping pressure constant then the temperature falls /decreases meaning thereby that the internal energy decreases .the role of PE in in internal energy of a gas is minimal as the energy is most of the time kinetic in nature -it has minimal time interacting with each other .
there are ideal gas laws governing the variation of P ,V and T.
Likes Angela Liang
Generally, the "potential energy of a system" can be thought of as the "energy of configuration" [ a function of the configuration variables ].
When the configuration changes (e.g. a displacement, a volume, [and in the case of a capacitor, an amount of charge displaced from equilibrium]), that energy generally changes.
Likes Angela Liang
Thank you very much:)
FAQ: When does potential energy change?
Potential energy changes when there is a change in the position or configuration of an object or system.
What are the different types of potential energy?
There are several types of potential energy, including gravitational potential energy, elastic potential energy, chemical potential energy, and electric potential energy.
How is potential energy calculated?
Potential energy can be calculated using the formula PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object.
Does potential energy always change into kinetic energy?
No, potential energy can also change into other forms of energy, such as thermal energy or chemical energy.
Can potential energy be negative?
Yes, potential energy can be negative in certain situations, such as when an object is below the zero reference point for gravitational potential energy.
