When tan theta is -ve why did we assume that it's in the second quad?
  • Thread starter Douna2nd
  • Tags
    Tan Theta
In summary, when finding the resultant of two forces and their angle of inclination, the convention is to take the "principal value" for arctan, between 0 and π, which places the angle in the 1st or 2nd quadrant. The -ve sign is equivalent to "negative" and the angle created is the smaller of the two angles formed by the two forces.
Douna2nd
The problem says
" Two forces of magnitudes 12 and 15 Newton are applied to a point and the tangesnt of the angle between them is -3/4. Find the resultant of the two forces and the measure of its angle of inclination on the first force.
In the answer it says that the theta belongs to the second quad, and I assume this is because the tan -ve but why didn't it assume it's in the fourth quad? And why doess the -ve sign belong to the 4 on the x-axis not the 3 on the y-axis??
Mathematics news on Phys.org
Hi Douna2nd! :smile:
Douna2nd said:
" … the tangesnt of the angle between them is -3/4"
Because the convention is we always take the "principal value" for arctan, and that's between 0 and π (ie, 1st or 2nd quadrant).
Not following you. :confused:
That's because -ve is baby-talk for "negative".
Two rays, starting at the same point, create two angles, one less than or equal to 180 degrees, the other larger than or equal to (and the two angles add to 360 degrees). The angle created is, by definition, the smaller of the two.
I would like to clarify that the assumption of the angle being in the second quadrant is based on the convention of using the unit circle to represent angles in mathematics. In this convention, the positive x-axis is considered to be the 0 degree angle, and the positive y-axis is considered to be the 90 degree angle. As we move counterclockwise around the unit circle, the angles increase and are labeled as 90, 180, 270, and 360 degrees.
When we have a negative tangent value, it means that the angle is between 180 and 270 degrees, which falls in the second quadrant. This is because the tangent function is defined as the ratio of the opposite side to the adjacent side of a right triangle, and in the second quadrant, both of these sides are negative.
In this specific problem, the negative tangent value of -3/4 indicates that the angle is in the second quadrant and not the fourth quadrant. This is because in the fourth quadrant, both the x and y values would be positive, resulting in a positive tangent value.
Therefore, the assumption of the angle being in the second quadrant is not based solely on the negative sign of the tangent value, but also on the convention of representing angles in the unit circle.
FAQ: When tan theta is -ve why did we assume that it's in the second quad?
Why is tan theta negative in the second quadrant?
In the second quadrant, both the x and y coordinates are negative. Since tan theta is defined as the ratio of the opposite side to the adjacent side of a right triangle, both the numerator and denominator will be negative, resulting in a negative value for tan theta.
How do we determine the quadrant of an angle?
The quadrant of an angle is determined by the signs of the x and y coordinates of the point where the angle intersects the unit circle. In the second quadrant, both x and y coordinates are negative.
Why do we assume that theta is in the second quadrant?
We assume that theta is in the second quadrant because tan theta is negative in this quadrant. This is important in trigonometry calculations and helps us determine the correct sign of the value of tan theta.
Can tan theta ever be negative in other quadrants?
Yes, tan theta can be negative in other quadrants. In the third quadrant, only the y coordinate is negative, resulting in a negative value for tan theta. In the fourth quadrant, only the x coordinate is negative, making tan theta positive.
How does the sign of tan theta affect other trigonometric functions?
The sign of tan theta affects other trigonometric functions because they are all related to each other. For example, in the second quadrant, both sin theta and cos theta are negative, while in the third quadrant, only sin theta is negative. This affects the values of these functions and their relationships with each other.
