Where am i going wrong? partial fraction question
In summary: Homework Statement Doing a homework question and I ran it through wolfram and I get a different answer to what I'm working it out as...and I can't see where I'm going wrong. Anyone able to give a pointer?my equation is \frac{1}{s(0.641s + 1)}Wolfram gives the answer as\frac{1}{s}-\frac{1}{s+1.56006}Homework EquationsThe Attempt at a SolutionUsing partial fraction decomposition I get (using cover up) -\frac{1}{s(0.641s + 1)} = \frac{A}{s} + \frac{B}{0
braceman
30
my equation is
[tex]\frac{1}{s(0.641s + 1)}[/tex]
[tex]\frac{1}{s}-\frac{1}{s+1.56006}[/tex]
[tex]\frac{1}{s(0.641s + 1)} = \frac{A}{s} + \frac{B}{0.641s+1}[/tex]
[tex]A = \frac{1}{s(0.641s + 1)} ~~~~~~ where~s~ = 0[/tex]
[tex]=\frac{1}{0.641.0 +1}[/tex]
[tex]=\frac{1}{1}[/tex]
[tex]∴A=1[/tex]
[tex]B = \frac{1}{s}[/tex]
[tex](0=0.641s+1[/tex]
[tex]-1=0.641s[/tex]
[tex]s=\frac{-1}{0.641}[/tex]
[tex]s=-1.56)[/tex]
[tex] ∴B=\frac{1}{s}[/tex]
[tex] ∴B=\frac{1}{-1.56}[/tex]
[tex] ∴B=-0.641[/tex]
[tex] Inserting~A~and~B~into~the~decomposition[/tex]
[tex]\frac{1}{s} + \frac{-0.641}{0.641s+1}[/tex]
which I get to be
[tex]\frac{1}{s} - \frac{1}{s+1}[/tex]
Where am I making my schoolboy error? It's my first go at partial fractions and my textbook aint exactly crammed with examples. Anyone able to point out if I've made a glaring error or just something stupid...any help would be appreciated.
You might want to look again at setting s = 0. Given it's a factor of the denominator.
my equation is
Let's begin by factoring ##.641## out of the denominator:$$
\frac{1}{s(0.641s + 1)}=\frac 1 {.641}\cdot \frac 1 {s(s+\frac 1 {.641})}=
1.56\cdot \frac 1 {s(s+1.56)}=
\frac a {s(s+a)}$$where ##a=1.56##. You want the fraction in that form to do the "cover up" method, from which you get$$
\frac 1 s + \frac {-1}{s+a}$$which agrees with Wolfram. I suggest you take it from there.
braceman said:
[tex]\cdots + \frac{-0.641}{0.641s+1}[/tex]
which I get to be
[tex]\cdots - \frac{1}{s+1}[/tex]
There. If you wanted to divide the top and bottom by 0.641, you forgot one of the terms in the fractiom.
Ignore that. Maybe PeroK doesn't understand the "cover up rule".
Likes 1 person
If the cover up rule allows you to divide by 0 and then tweak the distributive law, then I certainly don't understand it.
That's simply two algebraic wrongs making a right!
If A/x+ B/(x- a)= C/(x(x- a))
Then multiplying by x(x- a) we have A(x- a)+ Bx= C.
There is now no denominator so we can, without difficulty, let x= 0 and x= a getting
x= 0, -aA= C so A= -C/a and
x= a, aB= C so B= C/a.
Notice that
[tex]\frac{(-C/a)}{x}+ \frac{C/a}{x- a}= \frac{(-(C/a)x+ C}{x(x- a)}+ \frac{(C/a)x}{x(x= a)}= \frac{C}{x(x- a)}[/tex]
as desired.
Thanks for the replies...I realized where I went wrong suddenly, ie- had to make it 'standard form' and needed a 1 on the numerator instead of the 0.641...so manipulated the equation and it all fell into place.
So once again, thankyou all for the help.
my equation is
[tex]∴A=1[/tex]
[tex]s=-1.56)[/tex]
which I get to be
If you do it properly, it is more-or-less straightforward. You went at it the wrong way, so made it longer and more complicated than necessary.
Write
[tex] \frac{1}{s(1+as)} = \frac{A}{s} + \frac{B}{as+1}[/tex]
where ##A,B## are constants. Put the above over a common denominator:
[tex] \frac{A}{s} + \frac{B}{as+1} = \frac{A(as+1)+Bs}{s(as+1)}[/tex]
This supposed to equal ##1/[s(as+1)] ## for ALL ##s##, so the numerators much match exactly (because the denominators match). The numerator is ##A(as+1)+ Bs = (Aa+B)s + A##, so we need
[tex] (Aa+B)s + A = 1[/tex]
for ALL ##s##. The polynomial ##P(s) = (Aa+B)s + A## must satisfy ##P(s) = 1## for all ##s##; that means its constant term must = 1 and the coefficient of ##s## must vanish, so ##A = 1## and ##Aa+B = 0##. In other words, we have
[tex] \frac{1}{s(1+as)}= \frac{1}{s} - \frac{a}{as+1}[/tex]
[tex]A = \frac{1}{s(0.641s + 1)} ~~~~~~ \text{where }s~ = 0[/tex]
The OP made an algebra error, and the righthand side should have been
$$\frac{1}{0.641 s + 1}$$ which is defined for ##s=0##.
(Of course, to get to that point, you multiply the original equation by ##s## and therefore are assuming that ##s\ne 0##, but that's a minor complication.)
FAQ: Where am i going wrong? partial fraction question
1. What are partial fractions and when are they used?
Partial fractions are a method used to simplify and solve complex algebraic expressions, particularly rational functions. They are typically used in integration, solving differential equations, and simplifying equations for further manipulation.
2. How do I know if I need to use partial fractions in my problem?
If you have a rational function with a denominator that can be factored into linear or quadratic terms, then you may need to use partial fractions to simplify it. Additionally, if you are integrating a rational function, you will need to use partial fractions to solve it.
3. How do I set up the partial fraction decomposition?
The general form for partial fraction decomposition is:
- For distinct linear factors: A/(x-a)
- For repeated linear factors: A/(x-a) + B/(x-a)^2
- For distinct quadratic factors: (Ax+B)/(x^2+bx+c)
- For repeated quadratic factors: (Ax+B)/(x^2+bx+c) + (Dx+E)/(x^2+bx+c)^2
To find the coefficients A, B, C, etc. you can use the method of equating coefficients or plug in values for x to solve for the coefficients.
4. What are some common mistakes when solving partial fraction problems?
Some common mistakes when solving partial fraction problems include:
- Forgetting to consider all possible factors when setting up the decomposition
- Making errors when equating coefficients
- Forgetting to include all terms in the partial fraction decomposition
- Not simplifying the fractions before solving
- Making errors when integrating the decomposed fractions
5. Are there any tips for solving partial fraction problems more efficiently?
Yes, some tips for solving partial fraction problems more efficiently include:
- Familiarizing yourself with the general form and patterns for partial fraction decomposition
- Checking your work by plugging in values for x and comparing the original function to the decomposed fractions
- Using algebraic techniques to simplify the fractions before integrating
- Practicing and becoming comfortable with the method of equating coefficients
- Being patient and double-checking your work to avoid common errors.
