Where Does Feynman Get This Equation For E Field?
In summary: V = q/4πε0rUsing the electric potential, we can then derive Coulomb's law with retarded positions by taking the gradient of the potential to get the electric field:E = -∇V = q/4πε0 r2This is the same equation that we would get if we directly applied the principle of superposition to the electric field equation, but the use of the electric potential allows for a simpler derivation.In summary, the derivation of Coulomb's law with retarded positions is based on the principle of superposition and the use of the electric potential to calculate the electric field at a point due to a charge at a retarded position
Hornbein
2,652
2,219
The derivation of Coulomb's law with retarded positions is actually quite simple. It is based on the fact that the electric field at a point in space is generated by all charges in the universe. If we assume that the charges are moving at a constant speed, then the contribution to the field from any given charge must be calculated using the position of the charge at an earlier time, which is known as the "retarded position".To start the derivation, we can use Gauss's law, which states that the net electric flux through any closed surface is equal to the enclosed charge divided by the permittivity of free space:∮E⋅dA = q/ε0where E is the electric field, A is the area of the surface, ε0 is the permittivity of free space, and q is the charge enclosed by the surface.We can rewrite this equation in terms of the electric potential V, which is related to the electric field by the relationE = -∇Vwhere ∇ is the gradient operator. This gives us∫∇V⋅dA = q/ε0where the integral is taken over a closed surface enclosing the charge q.Now, we can apply the principle of superposition to this equation. That is, we can add together the contributions to the electric potential from each individual charge in the universe, weighted by its retarded position. This gives us∫∇[∑q r(t-t')/4πε0 r2]⋅dA = q/ε0where q is the charge of the individual particle, r(t-t') is the retarded position of the charge at time t', and r is the distance from the charge to the point of observation.We can simplify this equation further by noting that the gradient of the retarded position is zero outside of the light cone, since the charge can only affect the electric potential at points within the light cone. Thus, we can rewrite the equation as∫∇[∑q δ(t-t')/4πε0 r]⋅dA = q/ε0where δ(t-t') is the Dirac delta function.Finally, we can solve this equation to get
FAQ: Where Does Feynman Get This Equation For E Field?
What is the "equation for E field" that Feynman uses?
The equation for E field, also known as the electric field, is given by E = kq/r^2, where k is the Coulomb's constant (8.99 x 10^9 Nm^2/C^2), q is the charge, and r is the distance from the source of the electric field.
Where did Feynman get this equation from?
Feynman's equation for E field is derived from Coulomb's Law, which states that the force between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
How is this equation used in physics?
This equation is used to calculate the strength and direction of the electric field at a given point in space. It is also used to understand and predict the behavior of charged particles in an electric field.
Is this equation applicable in all situations?
While Feynman's equation for E field is a fundamental equation in electromagnetism, it is only applicable to point charges and does not take into account other factors such as the distribution of charges or the presence of conductors or insulators.
Can this equation be modified for different scenarios?
Yes, this equation can be modified for different scenarios by incorporating other concepts such as electric potential, permittivity, and the superposition principle. However, the fundamental form of the equation remains the same.
