Why are pressure and current scalar?
In summary, pressure and current can be considered as vectors, but in some cases they are treated as scalars or tensors. To prove if a physical quantity is a vector, its components must transform under rotations. In Newtonian physics, tensors refer to rotations and the stress tensor for a static fluid is described by a symmetric rank-two tensor. The current density is a vector field and the current through a surface is a scalar, with the surface-normal vectors determining the direction of the flow.
donaldparida
146
I know that a vector quantity or simply a vector is a physical quantity which has a magnitude and is associated with some definite direction. According to this definition should not pressure and current be vectors since both are associated with some definite direction?In some places they are treated as scalars while in other places as tensors. What types of quantities are they actually?Also is there any method we can use to prove that a physical quantity is a vector or not.
Are you referring to relativistic or non-relativistic tensors? In Newtonian physics one is talking about tensors in the sense of 3D vector calculus, and there transformation properties refer to rotations. Now pressure is a special case of stress, and stress is described by a symmetric rank-two tensor. In the case of a static fluid the stress tensor reads $$\hat{\sigma}=-\mathrm{diag}(p,p,p).$$
The current density (not current!) is a vector (field). If ##\rho## is the density and ##\vec{v}## the flow field, then
$$\vec{j}=\rho \vec{v}.$$
The current through a surface ##A## is given by
$$I=\int_{A} \mathrm{d}^2 \vec{a} \cdot \vec{j}$$
is thus indeed a scalar. It gives the amount of mass of the fluid going through the surface ##A##. The surface-normal vectors can be oriented as you like. The two different orientations of the surface just defines the sign of the current, i.e., the direction of the normal vectors tells you which direction of the flow counts as positive.
You can proof of any components ##T_{ijk\ldots}## whether they are tensor components by checking that they transform under rotations (orthogonal linear transformations) as (Einstein summation implies; all components wrt. to Cartesian bases)
$$T'_{abc\ldots} = O_{ai} O_{bj} O_{ck} \cdots T_{ijk\ldots}.$$
Related to Why are pressure and current scalar?
1. Why are pressure and current scalar?
Pressure and current are scalar quantities because they only have magnitude and no direction. This means that they can be described by a single numerical value and do not have any vector components.
2. How is pressure different from force?
Pressure is defined as the force per unit area, while force is a vector quantity that represents the push or pull on an object. Pressure is a measure of how much force is applied over a given area, while force is a measure of the strength of the push or pull.
3. What is the unit of measurement for pressure and current?
The unit of measurement for pressure is typically expressed in pascals (Pa) or newtons per square meter (N/m^2). The unit of measurement for electric current is usually expressed in amperes (A).
4. Why is pressure and current important in physics?
Pressure and current are important concepts in physics because they play a crucial role in many physical phenomena and can be used to describe and understand various natural phenomena. Pressure is essential in fluid mechanics, while current is crucial in understanding electricity and magnetism.
5. Can pressure and current be negative?
Yes, pressure and current can both be negative. Negative pressure can occur in situations where there is a pulling force instead of a pushing force, while negative current represents the flow of electrons in the opposite direction of conventional current flow.
