Why does [f(b)-f(a)]/(b-a) make sense?
  • I
  • Thread starter egio
In summary, [f(b) - f(a)] / (b - a) is a versatile expression that can represent different concepts depending on the context. It can represent slope, average velocity, or average rate of change, among others. It is useful to keep all these interpretations in mind when encountering the expression in calculus, as it allows for a deeper understanding and application of the concept.
egio
Hello,
As I progress into advanced mathematics I have noticed that [f(b) - f(a)] / (b - a) appears all the time, representing different things. For instance, it can represent slope, and if seen as Δposition/Δtime, it represents average velocity.
How can I read this expression, more so the numerator and denominator separately, intuitively? For instance, the formula for a mean is (∑x)/N, which makes sense to me. However, I'm not quite there yet with [f(b) - f(a)] / (b - a), and as I encounter different versions of it throughout calculus, I think it would help me to truly understand and read it in a general way, and know why it applies to so many different applications.
Thanks!
Mathematics news on Phys.org
That's the entire usefulness of calculus. If there was only one interpretation of this quantity, then calculus wouldn't be this useful. Instead, there are plenty, plenty of different interpretation available. It's useless to search for one interpretation that will contain them all. It is far more useful to keep all the distinct interpretations in the back of your mind and use all of them simultaneously. So whenever you encounter ##\frac{f(b)-f(a)}{b-a}##, you should try to give it all the different interpretations you know about - slope, velocity, acceleration, etc. - and see what different concepts you get.
egio said:
Hello,
The quotient above represents the change in function values divided by the change in the independent variable. If you have a curve y = f(x), two points on the curve are (a, f(a)) and (b, f(b)). ##\frac{f(b) - f(a)}{b - a}## gives the slope of the line segment joining the two points; that is, the slope of the secant line.
If the function represents distance travelled, then the quotient can be interpreted as average velocity. If the function represents the population of, say, bacteria, at time t, then the quotient represents the average rate of growth between two times.
Thanks!
Likes DrewD and SammyS
Basically it is a ratio used to compare two quantities. The idea is simpler but much powerful if you think the contribute in the calculus ... You can interpret as a velocity where the function is the space and the variable the time. If you have a population, it represents the change in the time of the number of organism. Also in chemistry you can represent the change of the concentration of a substance respect the time ...
Here's how average velocity is connected to ##\frac{\Delta x}{\Delta t}##.
Let's suppose the velocity is piecewise-constant during the entire time-interval.
\begin{align*}
v_{avg} &\equiv \frac{\int_a^b v\ dt}{\int_a^b \ dt}\\
&=\frac{v_1\Delta t_1+v_2\Delta t_2+v_3\Delta t_3}{\Delta t_1+\Delta t_2+\Delta t_3}\\
&=\frac{\Delta x_1+\Delta x_2+\Delta x_3}{\Delta t_1+\Delta t_2+\Delta t_3}\\
&=\frac{\Delta x_{total}}{\Delta t_{total}}\\
&=\frac{x(b)-x(a)}{b-a}
\end{align*}
since ##x(b)=x(a)+\Delta x_{total}## and ##b=a+\Delta t##.
FAQ: Why does [f(b)-f(a)]/(b-a) make sense?
Why is the formula [f(b)-f(a)]/(b-a) used to find the slope of a line?
The formula [f(b)-f(a)]/(b-a) is used to find the slope of a line because it represents the change in the y-values (f(b)-f(a)) over the change in the x-values (b-a). This ratio is the definition of slope, which measures the steepness of a line.
How does [f(b)-f(a)]/(b-a) relate to the concept of average rate of change?
The formula [f(b)-f(a)]/(b-a) is equivalent to the concept of average rate of change because it calculates the change in the output (f(b)-f(a)) over the change in the input (b-a). This is similar to the average rate of change, which measures the average speed at which a quantity changes over a period of time.
Why do we use the notation "h" instead of "b-a" in the limit definition of a derivative?
The notation "h" is used in the limit definition of a derivative because it represents a small change in the input variable, which is the basis of the derivative concept. It is also used to represent a variable value approaching 0, which is necessary for finding the exact slope at a point.
How does [f(b)-f(a)]/(b-a) relate to the concept of instantaneous rate of change?
The formula [f(b)-f(a)]/(b-a) is used to approximate the instantaneous rate of change at a specific point by finding the slope of the tangent line to the curve at that point. As the change in the input (b-a) approaches 0, the approximation becomes closer to the true instantaneous rate of change.
In what situations is [f(b)-f(a)]/(b-a) not a valid representation of the slope of a curve?
The formula [f(b)-f(a)]/(b-a) is not a valid representation of the slope of a curve when the curve is not continuous or when there is a change in the slope at the specific point being evaluated. In these cases, the slope must be calculated using a different method, such as the derivative or by finding the slope of a secant line with a smaller interval.
