Why Does My Integral Calculation Yield the Inverse Result?
In summary, when integrating -\int \frac{1}{1-x}dx, you should get \ln|1-x| instead of -\ln|1-x|. This leads to the final answer of \ln\frac{|1-x|}{x^4}+c.
jiasyuen
25
\(\displaystyle \int \frac{3x-4}{x(1-x)}dx\)
\(\displaystyle =\int \frac{-4}{x}dx-\int \frac{1}{1-x}dx\)
\(\displaystyle =-4\int \frac{1}{x}dx-\int\frac{1}{1-x}dx\)
\(\displaystyle =-4\ln\left | x \right |-\ln \left | 1-x \right |+c\)
\(\displaystyle \ln \frac{x^4}{\left | 1-x \right |}+c\)
But the correct answer is \(\displaystyle \ln \frac{\left | 1-x \right |}{x^4}+c\).
Where's my mistake?
I agree with you up to here:
\(\displaystyle -4\int \frac{1}{x}\,dx-\int\frac{1}{1-x}\,dx\)
Then upon integrating, we obtain:
\(\displaystyle -4\ln|x|+\ln|1-x|+C\)
And then combining the two log terms, we get:
\(\displaystyle \ln\left(\frac{|1-x|}{x^4}\right)+C\)
Where's my mistake?
You have a sign error when you integrated \(\displaystyle \displaystyle - \int \frac{1}{1-x}\, dx\).
\(\displaystyle \displaystyle \int \dfrac{dx}{ax+b} = \dfrac{1}{a} \ln |ax+b|\) - in your case because \(\displaystyle a=-1\) you end up with a minus sign outside the integral
FAQ: Why Does My Integral Calculation Yield the Inverse Result?
What is an integral?
An integral is a mathematical concept that represents the area under a curve on a graph. It is used to find the total value of a function over a specific interval.
How do I check for mistakes in an integral?
To check for mistakes in an integral, you can use the fundamental theorem of calculus and take the derivative of the integral. If the derivative does not match the original function, then there is a mistake in the integral.
What are common mistakes to look out for in integrals?
Some common mistakes in integrals include incorrect limits of integration, incorrect use of substitution or integration by parts, and forgetting to add a constant of integration.
Why is it important to check for mistakes in an integral?
Checking for mistakes in an integral is important because even a small error can significantly change the result. It is also crucial to ensure the accuracy of calculations and to avoid incorrect conclusions.
Are there any tips for avoiding mistakes in integrals?
To avoid mistakes in integrals, it is essential to carefully follow the steps of integration, double-check the limits of integration, and always include a constant of integration. It is also helpful to practice regularly and ask for help when needed.
