Vriska
- 138
- 2
doesn't make sense, h+ just has a really nice positive charge which is begging electrons but electrons go to the NO3(^2-) instead? why?
Borek said:Beware: there is no such thing as NO3(^2-).
Have you heard about reactivity series? Redox potentials?
Borek said:First of all: you can't oxidize H+, so most of what you wrote is off.
Is H+ an oxidizer strong enough to oxidize copper?
Borek said:Yes, there is thermodynamic behind, in particular relationship between the reaction ΔG and the potential.
Borek said:The only thing to remember here is the reactivity series, which will give answer to many other problems as well.
And I believe I told you long ago inorganic chemistry is not based on mechanisms like organic is.
snorkack said:Mechanisms are just as essential.
snorkack said:Wrong. Mechanisms are just as essential.
Check reactivity series, and you will find that cold dilute sulphuric acid is easier to reduce than hydrogen. To S8, not SO2 - sulphurous acid dismutes. And S8 itself is a stronger oxidant than hydrogen.
Check reactivity series, and you will find that both NO2 and NO are unstable to dismutation.
Check reactivity series, and you will find that cold dilute perchloric acid is a strong oxidant, stronger even than nitric acid.
By thermodynamics and reactivity series, the reactions in cold dilute acids ought to be:
4Cu+4H2SO4→CuS+3CuSO4+4H2O
5Cu+12HNO3→N2+5Cu(NO3)2+6H2O
4Cu+8HClO4→CuCl(ClO4)+3Cu(ClO4)2+4H2O
None of these reactions take place, for reasons of mechanism.
A reaction not expressly given there: how would you compute the standard potential for the reactionSO4-2 + 4H+ + 2e- ⇋ H2SO3 + H2O +0.172
H2SO3 + 4H+ +4e- ⇋ S + 3H2O +0.450
The reduction of NO32- instead of H+ in Cu+HNO3 is due to the relative strengths of the two species. NO32- is a stronger oxidizing agent compared to H+, meaning that it is more likely to undergo reduction.
Cu acts as a reducing agent in this reaction. It donates electrons to the NO32- ions, causing them to be reduced to other products.
H+ ions do not play a direct role in the reduction of NO32- in Cu+HNO3. However, they do act as a catalyst, speeding up the reaction by providing a favorable environment for the reduction to occur.
Yes, other metals can also be used as reducing agents in this reaction. However, the specific metal used may affect the rate of the reaction and the products formed.
The reduction of NO32- in Cu+HNO3 is an important reaction because it is a common method for preparing other compounds and is also used in various industrial processes. It also helps to understand the principles of redox reactions and their applications in chemistry.
