adelin
- 32
Why does tangent go to infinity when it increases 0 to 90 degrees?
Tangent goes to infinity because as the angle approaches 90 degrees, the value of tangent becomes larger and larger without bound. This is because in a right triangle, the opposite side becomes larger and larger while the adjacent side remains the same, resulting in a larger ratio and a larger tangent value.
No, there is no limit to how large tangent can get. As the angle approaches 90 degrees, the value of tangent will continue to increase without bound.
Yes, tangent can approach negative infinity as the angle approaches -90 degrees. This is because in a right triangle, the opposite side becomes larger and larger in the negative direction while the adjacent side remains the same, resulting in a larger negative ratio and a larger negative tangent value.
No, tangent only goes to infinity as the angle approaches 90 degrees or -90 degrees. For all other angles, the value of tangent will be finite.
When tangent goes to infinity, the other trigonometric functions such as sine and cosine will also approach infinity or negative infinity, depending on the quadrant in which the angle lies. This is because tangent is equal to the ratio of sine and cosine, so if tangent is infinitely large, then sine and cosine will also become infinitely large.
