Why doesn't the energy come out right in the Dirac Equation?
In summary: However, you can write an eigenvalue equation in terms of a 4-component spinor, and the eigenvalue will be the mass.In summary, the conversation discusses the Dirac Equation and the confusion surrounding the eigenvalues of the momentum and energy operators. It is noted that the operators for spin do not commute and therefore do not have common eigenvectors, but a 4-component spinor can be used to express an eigenvalue equation with the eigenvalue representing the mass. The conversation ends with a clarification about the non-commutativity of Hermitian operators and their bases of eigenvectors.
Xezlec
318
Hello,
I'm looking at the Dirac Equation, in the form given on Wikipedia, and (foolishly) trying to understand it.
[itex]\left( c \boldsymbol{\alpha}\cdot \mathbf{\hat{p}}+\beta mc^2 \right ) \psi = i\hbar\frac{\partial \psi}{\partial t}\,\![/itex]
So I picture a wavefunction in an eigenstate of the momentum operator in the [itex]e_1[/itex]-direction with an eigenvalue of p, and simultaneously an eigenstate of the [itex]\alpha_1[/itex] and [itex]\beta[/itex] operators with an eigenvalue of 1 in both cases. Now obviously, for this case:
[itex]\left( c \boldsymbol{\alpha}\cdot \mathbf{\hat{p}}+\beta mc^2 \right ) \psi = \left( p c +mc^2 \right ) \psi\,\![/itex]
But we know that [itex]E = \sqrt{p^2 c^2 + m^2 c^4}[/itex], so this doesn't seem to give the right eigenvalue for the energy operator on the RHS. We want the hypotenuse of a right triangle with [itex]c p[/itex] and [itex]m c^2[/itex] as its legs, not the length of a line with those two quantities as segments of the line! It seems like it might work out right if somehow they were complex and 90 degrees out of phase, but I can't see any way to get that.
What part of my brain is broken?
Thanks.
Wow. I had forgotten those didn't commute. Now I'm really confused. Back to the drawing board.
Thanks!
OK, I may have tracked down part of what's confusing me now. I've always been told that if two operators don't commute then they can't have a common eigenstate, but looky here. If
[itex]A = \begin{bmatrix}-1 & 0 & 0 \\0 & 1 & 0 \\0 & 0 & 1 \end{bmatrix}[/itex]
and
[itex]B = \begin{bmatrix}0 & 1 & 0 \\1 & 0 & 0 \\0 & 0 & 1 \end{bmatrix}[/itex]
then
[itex]AB = \begin{bmatrix}0 & -1 & 0 \\1 & 0 & 0 \\0 & 0 & 1 \end{bmatrix}[/itex]
but
[itex]BA = \begin{bmatrix}0 & 1 & 0 \\-1 & 0 & 0 \\0 & 0 & 1 \end{bmatrix}[/itex].
Since these are different, [itex]A[/itex] and [itex]B[/itex] do not commute. However,
[itex]r = \begin{bmatrix}0 \\0 \\1 \end{bmatrix}[/itex]
is clearly an eigenvector of both [itex]A[/itex] and [itex]B[/itex]. I guess I'm having trouble with the math at a more basic level than I thought.
I was a bit too fast, sorry to have misled you. If the rank of ##[A,B]## is not maximal, there may be some common eigenvectors. The true statement is that, for two Hermitian operators that don't commute, their bases of eigenvectors are not the same. In other words, they are not simultaneously diagonalizable.
Now, to get back to the original problem, it turns out that ##\alpha_1## and ##\beta## still do not have a common eigenvector.
FAQ: Why doesn't the energy come out right in the Dirac Equation?
Why is the energy in the Dirac Equation not always accurate?
The energy in the Dirac Equation may not always be accurate due to the presence of higher order terms that are not taken into account in the equation. These higher order terms can lead to small errors in the predicted energy levels.
Can the Dirac Equation be used for all particles?
No, the Dirac Equation was originally formulated for spin-1/2 particles, such as electrons. It is not applicable to particles with different spin values, such as photons.
How does the Dirac Equation account for relativistic effects?
The Dirac Equation takes into account relativistic effects by incorporating the concept of spin and the theory of special relativity. This allows for the prediction of energy levels for particles moving at high speeds.
Are there any limitations to the Dirac Equation?
Yes, the Dirac Equation only accurately predicts energy levels for single particles. It becomes more complex and less accurate when applied to systems with multiple interacting particles.
Can the Dirac Equation be derived from other more fundamental equations?
Yes, the Dirac Equation can be derived from the more fundamental Klein-Gordon Equation by taking into account the spin of the particle. It can also be derived from the Standard Model of particle physics, which is a more comprehensive theory that describes the behavior of all known particles.
