Why eigenvalues of L_x^2 and L_z^2 identical?
  • Thread starter fandango92
  • Tags
    Eigenvalues
In summary, the eigenvalues of the L_x^2 matrix and the L_z^2 matrix are both 0 and \hbar^2. This is because the direction chosen for the x and z components does not affect the eigenvalues. However, this does not determine the state of the particle, as an eigenstate of one operator does not necessarily correspond to an eigenstate of the other.
fandango92
Calculate the eigenvalues of the [itex]L_x^2[/itex] matrix.
Calculate the eigenvalues of the [itex]L_z^2[/itex] matrix.
Compare these and comment on the result.
[itex]L_x=\frac{1}{2}(L_+ + L_- )[/itex]
I have derived eigenvalues for each: [itex]0[/itex] and [itex]\hbar^2[/itex] for both [itex]L_x^2[/itex] and [itex]L_z^2[/itex]. But why are they identical? I'm finding it difficult in qualitatively explaining why the eigenvalues are the same for both.
Because the God of Physics does not care which direction you call the [itex]x[/itex]-direction and which direction you call the [itex]z[/itex]-direction.
Sorry I forgot to mention this is for [itex]l=1[/itex].
Okay, but I used [itex]L_z[/itex] eigenvalues of [itex]m\hbar[/itex], where [itex]m=-1,0,1[/itex] in this case, and used [itex]L_x=\frac{1}{2}(L_+ + L_- )[/itex]. I have called the z component the one in which is certain, so how can the x component squared in this case have the same eigenvalues as the z component squared?
The operators will have the same eigenvalues for the reason Oxvillian said, but that's not saying anything about the state a particle is in. If a particle is in an eigenstate of ##\hat{L}_z##, it's not in an eigenstate of ##\hat{L}_x##.
As a scientist, it is important to understand the underlying principles and mathematical concepts behind any results we obtain. In this case, the similarity in eigenvalues for L_x^2 and L_z^2 can be explained by the commutation relationship between the two operators.
In quantum mechanics, operators representing physical observables, such as the angular momentum operators L_x and L_z, do not necessarily commute with each other. This means that their order of operations matters and they may not yield the same result if applied in different orders.
However, the operators L_x^2 and L_z^2 do commute with each other, meaning that their order of operations does not affect the outcome. This is due to the fact that L_x and L_z are both components of the total angular momentum operator L, and L_x^2 and L_z^2 can be thought of as measuring the square of the total angular momentum along the x and z axes, respectively.
Since L_x and L_z represent different components of the same physical quantity, it makes sense that their squares would have the same eigenvalues. This is similar to how the x and y components of a vector have the same magnitude, but different directions.
In summary, the identical eigenvalues of L_x^2 and L_z^2 can be attributed to the commutation relationship between the operators and the underlying physical concept of total angular momentum.
FAQ: Why eigenvalues of L_x^2 and L_z^2 identical?
Why are the eigenvalues of L_x^2 and L_z^2 identical?
The eigenvalues of L_x^2 and L_z^2 are identical because they represent the square of the angular momentum operators in the x and z directions, respectively. These operators are related by the commutation relation [L_x, L_z] = iħL_y, which means that they do not commute with each other. However, the squared operators, L_x^2 and L_z^2, commute with each other and therefore have the same set of eigenvalues.
How do we calculate the eigenvalues of L_x^2 and L_z^2?
The eigenvalues of L_x^2 and L_z^2 can be calculated using the Schrödinger equation and the appropriate eigenfunctions. In the case of L_x^2, the eigenfunctions are the spherical harmonics Y_l^m and the eigenvalues are given by l(l+1)ħ^2, where l is the orbital angular momentum quantum number. Similarly, for L_z^2, the eigenfunctions are also the spherical harmonics, but the eigenvalues are given by m^2ħ^2, where m is the magnetic quantum number.
Are the eigenvalues of L_x^2 and L_z^2 always the same for any quantum system?
No, the eigenvalues of L_x^2 and L_z^2 are not always the same for any quantum system. They are only identical for systems with spherical symmetry, such as atoms or molecules. In systems with different symmetries, the eigenvalues of L_x^2 and L_z^2 may differ.
What is the physical significance of the eigenvalues of L_x^2 and L_z^2 being identical?
The fact that the eigenvalues of L_x^2 and L_z^2 are identical has several physical implications. It means that the square of the angular momentum in the x and z directions, which represent different physical quantities, have the same set of allowed values. This reflects the underlying symmetry of the system and has consequences for the selection rules in spectroscopy and the quantization of energy levels.
Can the eigenvalues of L_x^2 and L_z^2 ever be different?
Yes, the eigenvalues of L_x^2 and L_z^2 can be different in systems without spherical symmetry. For example, in a system with cylindrical symmetry, the eigenvalues of L_x^2 and L_z^2 may be different. This is because the operators L_x^2 and L_z^2 do not commute in this case, and therefore have different sets of eigenvalues.
