calvino
- 108
Any explanation would be great. Also, are there any examples of finite Integral domains that aren't fields?
calvino said:Also, are there any examples of finite Integral domains that aren't fields?
I believe there is a stronger and harder result that relies on the fact that finite division rings are commutative, thus any finite domain (which is a division ring) is field without assuming comutativity.
An Integral Domain is a mathematical structure that consists of a set of elements with addition and multiplication operations defined on them. It is a commutative ring with no zero divisors, meaning that the product of any two non-zero elements is always non-zero.
Every finite Integral Domain is a field because it satisfies the additional property of having a multiplicative inverse for every non-zero element. In other words, every element in a finite Integral Domain has a corresponding element that, when multiplied together, results in the identity element (usually denoted as 1).
The property of having no zero divisors is a necessary condition for a mathematical structure to be a field. This is because if a field has zero divisors, it cannot have a multiplicative inverse for every non-zero element, which is a defining characteristic of a field.
Yes, the set of integers under regular addition and multiplication is a finite Integral Domain but is not a field. This is because it does not have a multiplicative inverse for every non-zero element. For example, 2 does not have an inverse in this set since there is no integer that, when multiplied by 2, results in 1.
The fact that every finite Integral Domain is a field is significant because it allows for simplification and generalization of mathematical concepts and theorems. This property also has many practical applications in areas such as coding theory and cryptography.
