Why Is the Electric Field Not Zero Inside the Spherical Cavity?
The summary for this conversation is: In summary, the electric field at 2.0 cm from the center of a spherical cavity within a metal sphere with a point charge at its center is not 0 because it would violate Gauss' law. The field is only 0 inside the material of the conductor, not the hollow space. The two surfaces of the hollow sphere will acquire some charge in order to balance the electric field due to the central charge, which is a property of conductors and is used to find the charge.
SupremeV
A spherical cavity of radius 4.50 cm is at the center of a metal sphere of radius 18.0 cm. A point charge Q = 6.40 µC rests at the very center of the cavity, whereas the metal conductor carries no net charge. Determine the electric field at the following points.
(a) 2.0 cm from the center of the cavity
integral of ( E * dA ) = (1/Epsilon o) * Q enc
E = k q / r2
The answer, is suppose to 1.44e8, and has a very straightforward use of E = k q / r2.
My question is why isn't the electric field 0 at 2.0 cm from the center at the cavity. Isn't that inside the static metal conductor, hence must be 0.
Thanks all!
E = k q / r2
The short answer is: because Gauss' law would be violated if the field was 0. For a concentric Gaussian shell of radius 2 cm, the enclosed charge is not 0. So the field at the surface of that shell cannot be 0.
You may be confusing a situation in which you are to determine the field inside a charged sphere, with no charge inside the spherical cavity. In that case, there would be no enclosed charge (all the charge would be outside a Gaussian sphere of radius 2 cm) so the field would be 0.
AM
Hi SupremeV :biggrin:
(Have an epsilon and integral: ε, ∫ and try using X2 and X2 button just above the reply box --- ©Tiny-Tim)
Field is only zero inside the material of the conductor ... not the hollow space
In this case ... the two surfaces(inner and outer) of hollow sphere will get come charge so as to balance the electric field due to central charge ... in in fact this property of conductors (and gauss law) is used to find this charge.
Thank you! I appreciate the help!
The electric field inside a conductor is indeed zero, but in this case, the point charge Q inside the cavity creates an electric field that extends outside of the conductor. This electric field is not affected by the presence of the conductor and can be calculated using Gauss's Law. The electric field at a distance r from the center of the cavity is given by E = kQ/r^2, where k is the Coulomb's constant and Q is the charge inside the cavity. Therefore, at a distance of 2.0 cm from the center of the cavity, the electric field would be 1.44 x 10^8 N/C. This is because the charge Q inside the cavity is still exerting its influence on the point 2.0 cm from the center, despite being inside the conductor.
FAQ: Why Is the Electric Field Not Zero Inside the Spherical Cavity?
What is Gauss's Law?
Gauss's Law is a fundamental concept in electromagnetism that describes the relationship between electric charges and electric fields. It states that the total electric flux through a closed surface is equal to the total charge enclosed by that surface divided by the permittivity of free space.
How is Gauss's Law applied?
Gauss's Law is applied to situations where there is a known distribution of electric charges and the resulting electric field needs to be calculated. It can be used to find the electric field of a point charge, a line of charge, or a charged surface.
What is the importance of Gauss's Law?
Gauss's Law is important because it provides a powerful tool for calculating electric fields and understanding the behavior of electric charges. It also helps to simplify complex situations by allowing us to focus on the charges enclosed by a surface rather than individual charges.
What is the difference between Gauss's Law and Coulomb's Law?
Gauss's Law and Coulomb's Law both describe the relationship between electric charges and electric fields. However, Coulomb's Law applies to point charges and is used to calculate the force between two charges, while Gauss's Law applies to situations with distributed charges and is used to calculate the electric field at a point.
How is Gauss's Law related to the divergence theorem?
The divergence theorem is a mathematical theorem that relates the flux through a closed surface to the divergence of a vector field. Gauss's Law is a specific application of the divergence theorem to the electric field, where the flux through a closed surface is equal to the enclosed charge divided by the permittivity of free space. In other words, Gauss's Law can be seen as a special case of the more general divergence theorem.
