Why is the electrolyte in a cell necessary?
  • Thread starter radaballer
  • Tags
    Cell
In summary: The two processes are mutually dependent - the voltage is stable because the ions are constantly moving.
radaballer
86
If electrons always flows from an area of high density to low density, why is it necessary for the ions in a cell to flow across the electrolyte as well. It seems that charge should be able to flow from the anode to the cathode without the need of these ions flowing as well. Why are these two processes mutually dependent on one another to create a steady voltage?
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
I just now saw this thread, Radaballer.
If I understand your question correctly, it's because electrons can't "jump". ie: they need a conductive medium in which to "propagate" like billiard balls from one electrode to the other. Space in between would act as an insulator. (In the case of the somewhat misnamed "cathode ray" tube like in a TV, they are violently accelerated by an external voltage source rather than just seeking an electrical balance as in a battery.)
That's not a great explanation, I know, but for now it's the best that I can do with my limited scientific vocabulary.
Likes radaballer
Charges don't exist in isolation: in order to have a negative charge you have to start with a neutral charge and separate it into positive and negative. The positive ions exist to be re-combined with the electrons -- the attraction between them is what generates the voltage.
Likes radaballer
Apologies if this is a bit basic, but I will put it another way.
Electrons don't flow in isolation. A charged capacitor is a good example of two different electron densities very close to each other but unable to flow. Thus the capacitor stores the electrons as a potential charge.
A spark plug is also worth thinking about here. Until the difference in potential between the contacts is sufficient no electrons will flow. (When it is sufficient, 10s of thousands of volts, a spark is created).
In both cases the resistance is too large for the electrons to flow at battery voltages.
Both the spark plug and the capacitor would allow the flow of electrons if we were to wire up a resistor between the contacts. The electrolyte does exactly that - creates a resistance that is sufficiently low enough for electrons to flow.
FAQ: Why is the electrolyte in a cell necessary?
What is an electrolyte and why is it necessary in a cell?
An electrolyte is a substance that conducts electricity when dissolved in water. It is necessary in a cell because it helps to maintain the electrical balance and flow of ions, which are essential for various cellular processes such as nerve and muscle function, hydration, and acid-base balance.
How does the electrolyte in a cell affect its overall function?
The electrolyte in a cell is responsible for maintaining the proper concentration of ions inside and outside of the cell. This is important for maintaining the cell's membrane potential, which is necessary for communication between cells and for the cell to carry out its functions.
What happens if there is an imbalance in the electrolyte levels of a cell?
If there is an imbalance in the electrolyte levels of a cell, it can disrupt the cell's membrane potential and lead to various health issues. For example, too much or too little potassium, sodium, or calcium can cause irregular heartbeats, muscle cramps, weakness, and other symptoms.
Can a cell function without an electrolyte?
No, a cell cannot function without an electrolyte. The presence of electrolytes is essential for the cell to maintain its structure and carry out its various functions. Without electrolytes, the cell would not be able to maintain its electrical balance, leading to dysfunction and possibly cell death.
Do all cells contain electrolytes?
Yes, all cells contain electrolytes. This is because electrolytes are essential for the basic functioning of cells and are present in various bodily fluids, such as blood and urine. However, the types and concentrations of electrolytes may vary between different cell types and organisms.
