Why is the ember of a cigarette harder than the non-burning tobacco alone?
  • Thread starter BrainSalad
In summary, the ember of a cigarette stays lit longer than non-burning tobacco due to its higher concentration of heat-producing chemicals. It is composed of partially burned tobacco and other byproducts of combustion. The ember also produces more smoke and continues to glow even when not being actively smoked, contributing to the overall burning process by providing sustained heat and igniting new tobacco.
BrainSalad
53
The glowing end of a lit cigarette appears to be more solid/sturdy/hard than the loose tobacco that makes it up.
This may be more of a chemistry question, but why is this?
I'm not sure about the exact scientific explanation, but essentially that part has lost its moisture and is in the process of becoming primarily carbon. That alters the chemical bonds.
FAQ: Why is the ember of a cigarette harder than the non-burning tobacco alone?
Why does the ember of a cigarette stay lit longer than the non-burning tobacco alone?
The ember of a cigarette stays lit longer because it contains a higher concentration of heat-producing chemicals. These chemicals are released when the tobacco is burned, and they help sustain the ember's heat and combustion.
How does the ember of a cigarette differ from the non-burning tobacco in terms of composition?
The ember of a cigarette is composed of partially burned tobacco, ash, and other byproducts of combustion. The non-burning tobacco, on the other hand, is mainly composed of dried plant material and contains less heat-producing chemicals.
What causes the ember of a cigarette to produce more smoke than the non-burning tobacco?
The ember of a cigarette produces more smoke because it contains a higher concentration of heat-producing chemicals, which leads to more efficient combustion and the release of more smoke.
Why does the ember of a cigarette continue to glow even when not being actively smoked?
The ember of a cigarette continues to glow due to the presence of smoldering particles and residual heat-producing chemicals. These particles can continue to smolder and produce smoke even when not being actively smoked.
How does the ember of a cigarette contribute to the overall burning process?
The ember of a cigarette is an essential part of the burning process, as it provides a sustained source of heat and combustion. Without the ember, the tobacco would not continue to burn and produce smoke. It also helps to ignite and sustain the burning of new tobacco as it is drawn into the cigarette during smoking.
