roineust
- 338
- 9
Why shouldn't i be skeptical about SR postulate no.1 ??
From wiki (https://en.wikipedia.org/wiki/Special_relativity):
"1. the laws of physics are invariant (i.e. identical) in all inertial frames of reference (i.e. non-accelerating frames of reference) "
1. Particles aren't an experiment accelerated up to a certain constant relativistic speed in order to affirm postulate no.1 , particles are only a part of an experiment. The whole experiment should be accelerated into a constant relativistic speed, as in for example: accelerate to a constant relativistic speed also the sensors that measure the particle collision results. Never been done as much as i know.
2. Therefore, a true affirmation or refute of SR postulate no.1 would be executed on macro bodies (the whole experiment) and not on micro bodies (particles only) i.e. compare results from 2 sets of identical experiment equipment, both executed as a whole entire experiment including all experiment parts, at 2 different up to a satisfying enough degree of difference, relativistic constant speeds. Never been done as much as i know.
3. An environment of 2 sets of identical experiment equipment (macro bodies) traveling at 2 different constant relativistic speeds or even 1 relativistic and other not relativistic (in all cases in relation to Earth ground), does not exist in nature as SR defines it (natural celestial objects movement), as much as i understand, therefor it must be an environment artificially created by human beings. Never been done as much as i know.
4. What kind of experiment? I don't know the exact nature of that experiment, but first such an experiment environment should be created (engineered) and on it, many types of postulate no.1 affirmation/refute experiments should be executed.
If anyone is interested in the details of such as experiment environment engineering in order to affirm/refute SR postulate no.1, i have an idea and can describe it, but this post would probably never get to that and i will probably be very quickly denounced as another crack pot, don't really care about being called so, that is obvious (that i don't care much about being called so).
When it comes to Newtonian vs Relativistic theories, the small but important difference in experiment results, that becomes non-negligible at relativistic speeds, is brought up again and again to explain modern physics vs classic physics, therefore why is this same consideration neglected when affirming so easily the truth of SR no.1 postulate, while that postulate was actually never really tested in a constant relativistic environment, in the true sense of the word i.e. the whole experiment including the sensors?
Perhaps there would be non-negligible result differences, when whole 2 identical experiments will be executed in 2 different up to a satisfying enough degree, relativistic constant speeds? Or perhaps 1 relativistic constant speed and 1 non-relativistic constant speed identical experiments, would be what is needed to see experiment result differences (all speeds described in all cases, relative to Earth ground).
Isn't SR actually all about the question of the sensors constant relative speed and not only the question of non-sensor experiment parts constant relative speed?
