symplectic
- 11
Hi,
We use as an integration form in Riemannian geometry the covariant
[tex]\int \sqrt{g}d\Omega[/tex]
I understand how this is invariant under an arbitrary change of coordinates (both Jacobian and metric square root transformation coefficient will cancel each other), what I don't understand is why don't an integral can be expressed only by
[tex]\int d\Omega[/tex]
I mean, it's true that a Jacobian will appear, but its effect will be "canceled" by the change of the integrand under the same change of variables, and it will give the same result! What is the difference between a flat and a curved space in this precise case, why the non flatness will make this integral non well-defined (without the [tex]\sqrt{g}[/tex] )?
e.g: 1 dimension
[tex]I = \int dx (x^{2} - 1)[/tex]
change of variables :
[tex]y = x^{2}[/tex]
Will give :
[tex]I' = \int dy \frac{(y - 1)}{2 \sqrt{y}}[/tex]
[tex]I' = I[/tex]
and this works for higher dimensions ...
So what will change if one introduce a metric ?
e.g: 1 dimension
Will give :
[tex]I' = I[/tex]
