Winding your own air-core inductor
In summary, there are multiple equations available for determining the inductance of a cylinder with wire wound around it, including Wheeler's Formula, which takes into account the coil diameter, number of turns, and coil length. Layering the wire can increase the inductance, but also increases stray capacitance and lowers the resonant frequency of the coil. The resistance of the coil may also be affected by skin effect at high frequencies. When creating a winding apparatus for a small inductor, it may be helpful to use a turn counter. There are various resources available for calculating solenoid inductance, such as the solenoid inductance calculator used by NASA and online calculators recommended by ham radio operators.
pinchy911
I am trying to duplicate an already existing inductor by buying the components and winding it myself. I have found several different sources that give me different equations for determining inductance. My questions are as follow:
- What is the governing equation for determining the inductance of a cylinder with wire wound around it.
- What affect does layering the wire have. ie wind it once, go back and re-wind over it a second time to increase the field
- How do you incorporate the 'parasitic resistance' of the wire that varies by wire gauge/composition etc.
Lastly, this is a very small inductor (~.5 inches long) are there any tips for creating a winding apparatus...preferably with a turn counter.
The classic formula for winding coils is Wheeler's Formula.
There are lots of references to this if you'd like to feed it into Google.
L = (d^2*n^2) / (l + 0.45d)
where d is the coil diameter in meters, n the number of turns and l the coil length in meters.
If your existing coil has a magnetic core in it, the inductance will vary with frequency, so you need to measure the inductance at the frequency it is going to be used at.
See if a magnet attracts it. If so, you may have difficulty duplicating it unless you use the same grade of ferrite or powdered iron.
Also, the capacitance between turns can cause a coil to become resonant and behave differently to the way it would if it just had inductance. Layering the windings increases the inductance but also increases the stray capacitance and lowers the resonant frequency of the coil.
Also, the resistance of the coil measured with a multimeter may be increased by skin effect if the coil is used at high frequency.
I have seen coil winding machines with counters, but they were made by the users for their own use.
The solenoid inductance calculator used by NASA is available for download at:
http://www.openchannelsoftware.com/projects/Solenoid_Inductance_Calculator/
The analytic equation for a single layer solenoid (thin solenoidal current sheet) is derived by Smythe "Static and Dynamic Electricity" 3rd Ed., page 340
L = pi u0 a2n2[(z2+ a2)1/2 - a]
where z= length, a = radius, and n = # of turns.
There are seeral on-line calculators. One used by ham radio operators is:
http://hamwaves.com/antennas/inductance.html
FAQ: Winding your own air-core inductor
How do I determine the number of turns needed for my air-core inductor?
The number of turns needed for an air-core inductor depends on the desired inductance and the size of the core. You can use an online calculator or a formula to determine the number of turns needed for your specific inductor.
What type of wire should I use for winding an air-core inductor?
The type of wire you use for winding an air-core inductor depends on the desired inductance and current rating. Generally, thin-gauge enameled copper wire is commonly used for low-power inductors, while thicker-gauge wire is used for high-power inductors.
Can I use a pre-made inductor instead of winding my own?
Yes, pre-made inductors are readily available and can save time and effort. However, winding your own air-core inductor allows for customization and can be a more cost-effective option for specific requirements.
How do I test the inductance of my air-core inductor?
You can use an inductance meter or an LCR meter to measure the inductance of your air-core inductor. Alternatively, you can calculate the inductance using a formula and measuring the physical dimensions of the inductor.
Are there any safety precautions I should take when winding my own air-core inductor?
Yes, it is important to wear protective gear, such as gloves and safety glasses, when working with wire. Make sure to also use appropriate tools and handle the wire carefully to avoid injury. Additionally, be aware of any potential electrical hazards when testing your inductor.
10K
