Work done by pulling block over surface.
In summary: So you can assume that for most of the motion, the force you're pulling with is equal to the kinetic friction, and use that to calculate the work. So in summary, the work done in moving the block a distance of 1.25 metres across a rough surface with a coefficient of static friction of 0.3 and kinetic friction of 0.2, assuming low velocities, is 196 J.
cthionic
A 80-kg block is pulled across a rough surface a distance of 1.25 metres. How much work was done in moving it? The coefficient of static friction was 0.3 and kinetic friction was 0.2. Assume the velocities were very low.
W = fd
I don't know how to apply kinetic/static friction together. static is to get from 0 velocity to starting to move, but how uncertain how to combine the two together.
W = 80(0.3/0.2??) * 1.25 = 16 * 1.25 = 20. .. multiple choice options are 98 J, 148 j, 196 j or 392 j
Welcome to PF!
At the beginning, when you're trying to overcome static friction, you increase the force with which you're pulling until you overcome it, and the block starts moving. However, during this time that you're increasing your pull to start the block moving, the block is still stationary. That means there is no displacement. That means no work is done. It's only once you've got it in motion that work starts being done.
Now, let's assume you're lazy and you want to pull using the minimum required effort. Once you overcome static friction, kinetic friction (which is lower) takes over. So for this brief moment of time at the beginning, you are pulling with a force larger than the frictional force. So there is a net force on the block, and it accelerates up to some speed. Let's assume that you don't let it accelerate too much before lessening your pull so that it is *equal* to the kinetic friction. At this point, there is 0 net force on the block, and Newton's 1st says that it continues along at the constant (and very low) speed that you allowed it to accelerate up to before you lessened your pull.
So, for most of the motion, you pull with a force equal to the kinetic friction, and maybe it's not such a bad approximation to assume that that is how hard you pull for the entire time. If I make that assumption, then I get one of the answers given in the answer choices.
Thanks!
So I would take the weight of the block, 80, multiply that by gravity, 9.8, which would be the normal force. then, 9.8 * 80 * 0.2, which is 156.8, then multiplied by the distance, 1.25, and then i get 196 J. is this correct?
cthionic said:
Thanks!
The math is correct. The physics is correct IF the assumptions I outlined in my previous post hold. Do you buy that line of reasoning?
I think so. If you kept pulling/pushing with the force you needed to get it started, you would be accelerating instead of keeping a constant low velocity, right?
Yeah, that's right.
FAQ: Work done by pulling block over surface.
What is work done by pulling block over surface?
Work done by pulling block over surface is the energy transferred or expended when an object is moved by a force applied in the direction of its motion. This work is equal to the force applied multiplied by the distance the object moves.
How is work done calculated in this scenario?
The formula for calculating work done is W = F * d, where W is the work done, F is the force applied, and d is the distance the object moves.
What factors affect the amount of work done?
The amount of work done by pulling a block over a surface is affected by the magnitude of the force applied, the distance the object moves, and the angle between the force and the displacement of the object.
What are some real-life examples of work done by pulling a block over a surface?
Examples of work done by pulling a block over a surface include pushing a shopping cart, dragging a suitcase, pulling a sled, and pulling a door open.
How is work done related to energy?
Work done is a form of energy. When work is done on an object, energy is transferred to that object, causing it to move or change in some way. In other words, work is the process of transferring energy from one object to another.
