Work done lifting cable against gravity
In summary, a 2-pound-per-foot cable is suspended 200 feet deep in a well and needs to be raised to the surface. Using a constant weight of 32m, the work done in raising the cable can be found by calculating the integral of the weight density multiplied by the distance. In this case, since the weight density is constant, it can be taken out of the integral and the work is equivalent to the weight of the cable multiplied by half its length.
physicsnnewbie
49
A cable weighing 2 pounds per foot of length (and so having a mass of 2 pounds per foot) is suspended from the top of a well 200 feet deep and extends to the bottom. Find the work done in raising the cable to the surface. Over the distance of 200 feet you may use 32m as the constant weight of a mass 'm'.
3. attempt at a solution
dW/dr = F
dW/dr = 32m
dW/dr = 32(2r)
dW/dr = 64r
W = 32r^2 + C = 32(200)^2 = 1280000
The fact that 'r' is measuring cable length (instead of distance between two objects which was used to derive the original equation) is screwing with me. I need someone to help me get my head around it.
find the CM and you are done :)
For a problem like this, where the weight density is constant, lswtech's idea is easiest- the center of mass is exactly at the middle of the cable and lifting the cable requires the same work as if the total mass were concentrated at the center of mass. Just a couple of simple arithmetic operations.
More generally (and a way of showing that the previous statement is true), focus on some small section of chain, of length [tex]\Delta x[/tex], at height x below the surface. If the weight density is [tex]\gamma(x)[/tex], then the weight of that little section is (approximately) [tex]\gamma(x)\Delta x[/tex] and it has to be lifted a distance x. It takes (approximately) [tex]\gamma(x) x\Delta x[/tex] work to lift it to the surface. Dividing the entire cable into pieces and adding the work required to lift each piece, the total work would be (approximately) [tex]\sum \gamma(x) x \Delta x[/tex].
The reason for the repeated "approximately"s is that if the density is NOT constant, and [tex]\Delta x[/tex] is not "infinitesmal", the weight is not simply a product. But that is a "Riemann" sum, as is used to define the definite integral. If take the limit as [tex]\Delta x[/tex] gets smaller and smaller, becoming "infinitesmal", it becomes exact: the work is given by
[tex]\int \gamma(x) x dx[/tex]
If, in particular, [itex]\gamma[/itex] is a constant, we can take it out of the integral:
[tex]\gamma \int_0^L x dx[/tex]
(I have put in 0 and L as the distances of the two ends of the cable- it extends down from 0 to its length L.)
That is easily seen to be
[tex]\left[\gamma \frac{x^2}{2}\right]_0^L= \gamma \frac{L^2}{2}= \left(\gamma L\right)\left(\frac{L}{2}\right)[/tex]
where at the end I have factored to show it is "[itex]\gamma L[/itex]" times "[itex]L/2[/itex]", the weight of the cable times the distance it midpoint is lifted.
Thanks, that was very helpful!
Related to Work done lifting cable against gravity
1. What is work done lifting cable against gravity?
Work done lifting cable against gravity is the amount of energy required to lift a cable against the force of gravity. This work is typically measured in Joules (J) or Newton-meters (Nm).
2. How is work done lifting cable against gravity calculated?
The work done lifting cable against gravity can be calculated by multiplying the force applied to the cable by the distance it is lifted. This can be expressed as W = F x d, where W is the work done (in J or Nm), F is the force (in Newtons), and d is the distance (in meters).
3. What factors affect the amount of work done when lifting a cable against gravity?
The amount of work done when lifting a cable against gravity is affected by several factors, including the weight of the cable, the height it is lifted, and the force applied. Additionally, the angle at which the cable is lifted and any friction or resistance in the lifting mechanism can also impact the amount of work done.
4. Why is work done lifting cable against gravity important?
Understanding the concept of work done lifting cable against gravity is important for engineers and scientists in designing and analyzing lifting systems. It also has practical applications in industries such as construction, transportation, and manufacturing where lifting heavy objects against gravity is a common task.
5. How does the work done lifting cable against gravity relate to potential energy?
The work done lifting cable against gravity is directly related to the potential energy of the cable. As the cable is lifted, the work done against gravity is stored as potential energy in the cable. This potential energy can then be converted back into work when the cable is lowered. This relationship is described by the formula PE = mgh, where PE is the potential energy (in J), m is the mass of the cable (in kg), g is the acceleration due to gravity (9.8 m/s^2), and h is the height the cable is lifted (in m).
