scienceisbest
- 10
Can a self replicating, or self growing robot (programmed to make logical decisions) can be called as Living thing?
If not, what is the definition of living thing?
DaveC426913 said:The basis of the definition of life is:
- it eats and excretes
- respirates
- grows
- reproduces
- reacts to stimuli
There's all sorts of nuancing but it starts with those.
A machine that could reproduce itself would not be easy.Oldfart said:It seems easy enough to imagine the building of a machine that can do all those things.
DaveC426913 said:A machine that could reproduce itself would not be easy.
What makes you think life is so complex?
Danger said:I disagree that it must eat and excrete, only because that the human concepts of those functions are personalised. They might not be recognised in a normal manner, but are unmissable by those who grew up with the crap.
Archosaur said:Here's a sort of thought experiment:
If a person has a prosthetic leg, is he still human? Of course!
What if he has two prosthetic legs?
Two prosthetic legs and an artificial heart?
What if every organ is replaced with a mechanical substitute, even the brain, the contents of which are "downloaded" into a network with transistors instead of neurons?
After which gradual step is he suddenly no longer human?
DaveC426913 said:Human versus non-human is a very different question.
Yes. Eating and excreting are terms we put a lot of meaning on. Ultimately, it must consume raw materials and emit waste materials. Eating/excreting and respiration are both subsumed under that.K^2 said:I would only disagree with DaveC's criteria on eating/excreting and respiration. By that definition, anaerobic bacteria are not alive, since they require no respiration.
I would then replace all statements about feeding/breathing or whatever into the single most broad definition. It must consume energy to maintain it's own Gibbs' free energy at above equilibrium level. This is all we really need to exclude "simple reproduction" of things like growing crystal.
If it responds to no external stimuli, is it alive at all?K^2 said:Response to stimuli is also questionable, but only because of vagueness.
Even that has its vagueness. There are organisms that can't reproduce without the help of other organisms (some parasites and symbiotes). Is that kind of like saying a machine needs the symbiotic help of another machine to produce its raw materials?K^2 said:I would start with reproduction as most important criterion. It must self-reproduce however. I would not classify something like a virus as alive. Otherwise, we must include all existing technology in the definition.
And it must grow.K^2 said:Anything that follows these two criteria will evolve with changing environment. If it doesn't end up evolving to respond to stimuli or to do any of the other things we associate with living things, then it obviously doesn't need them.
Basically, as long as these two criteria are fulfilled, I'd call it alive regardless of origin.
If I remove support from under a rock, it drops. And many living organisms can't respond to more than a pressure change. So it's way too vague.DaveC426913 said:If it responds to no external stimuli, is it alive at all?
I agree. This needs work. What I'm trying to get to is difference between requiring a host for environment, in case of a parasite, and needing host to do the actual reconstruction, in case of a virus. Former should be classified as alive, while later should not. Any thoughts on how to formulate it better?DaveC426913 said:Even that has its vagueness. There are organisms that can't reproduce without the help of other organisms (some parasites and symbiotes). Is that kind of like saying a machine needs the symbiotic help of another machine to produce its raw materials?
Reproduction sort of forces growth at some stage. If it never grows past that point, I see no reason to disqualify it from being alive.DaveC426913 said:And it must grow.
But if it doesn't reproduce, how can it evolve?scienceisbest said:I think "having the free energy above equilibrium level" is the most basic condition. Rest of all the conditions, like growth, reproduction, consciousness etc are the properties gained in the process of evolution, depending upon at what stage of evolution it has reached. May be a growing crystal can evolve to a stage where it can do all the function what now we consider as the characteristics of living thing.
Except that a growing crystal is not alive. So we know that definition is too loose.scienceisbest said:May be a growing crystal can evolve to a stage where it can do all the function what now we consider as the characteristics of living thing.
Yes it is. But vagueness doesn't disqualify it; it simply measn we need to refine it.K^2 said:If I remove support from under a rock, it drops. And many living organisms can't respond to more than a pressure change. So it's way too vague.
K^2 said:Reproduction sort of forces growth at some stage. If it never grows past that point, I see no reason to disqualify it from being alive.
DaveC426913 said:Well, if it simply made an identical copy of itself whole and unchanging, like a photocopier, would that count as life?
I think that may be too literal.Archosaur said:I can't see why not. If a bacterium assembled the next generation outside of itself using ambient materials, would we call it less alive than one that undergoes binary fission (which necessitates growth)?
Also (devils advocate here) if reproduction is a defining characteristic, then are sterile hybrids alive?
DaveC426913; said:Well, if it simply made an identical copy of itself whole and unchanging, like a photocopier, would that count as life?
Danger said:I find myself in the peculiar position of both agreeing and disagreeing with someone.
I consider a virus to be alive. My best argument in favour of that is the fact that inoculations are specified to contain a killed virus.
Newai said:All they know is on/off and move.
What an interesting paradox. I have thought about essentially the same question multiple times. From a particular viewpoint, the crux of answering the question lies in establishing some threshold where once crossed the object in question no longer retains its identity. I believe this can be given quite a measurable, i.e., mathematical, representation.DaveC426913 said:We were discussing life versus non-life. Human versus non-human is a very different question.
The central paradox here is often known as the http://en.wikipedia.org/wiki/Ship_of_Theseus" .
If Theseus replaces every wooden plank on his ship one by one, is it still the same ship?
Archosaur said:This is a pretty shortsighted view. First off, there's a multi-billion dollar industry that says they can do a lot more, including recognize facial expressions, and even eat. Secondly, they're able to do more and more complex things every year. The solid line you're trying to draw between robots and living things simply isn't there, and that grey area is going to start being challenged in the future.
Your viewpoint ignores the idea that new additions can be imbued with identity once added.Noesis said:What an interesting paradox. I have thought about essentially the same question multiple times. From a particular viewpoint, the crux of answering the question lies in establishing some threshold where once crossed the object in question no longer retains its identity. I believe this can be given quite a measurable, i.e., mathematical, representation.
Already the framing of the question establishes some threshold since it is assumed that the ship, or the human vessel, remain static throughout time. Small changes are also likely to be dismissed: If a splinter is removed from the ship or a hair removed from my body, we are still likely to not question the persistence of the object's identity. I think interesting conclusions can be drawn from these thoughts, although some are, granted, fairly academic.
I don't think this will work. I would not have to remove many pieces from a computer program for it to stop working. In fact, the removal of a single character - virtually any single character I might care to choose - is quite likely to be fatal. I would then erroneously conclude that that single character is the most important component in the program.Noesis said:Of more practical concern: I think this provides a simple algorithm to determine what is responsible for something's function. Basically: remove things until it stops doing what it was doing. Removing planks one by one might provide considerable insight as to what keeps the ship afloat in the first place, in case Theseus was wondering. If technically feasible, I think this would be a fantastic way to attempt to identify the basis of consciousness. Ideally one could start by removing one molecule at a time and analyzing throughout, initially it'd be far more practical to start at a coarser grain by, say, removing entire neural compartments or neural assemblies.
I think the algorithm can also be abstracted away from a material setting, although will probably be more difficult to carry out in general. For example, in regards to an argument of what constitutes life, one could identify a living object and then start to subtract parameters until it was clear that the object could not possibly be alive without these remaining parameters. Then this fundamental set must be the basis of life. This might sound very oversimplified since, after all, it has been traditionally very difficult to establish a working definition of what life is. However, I think the main impediment has been what Dave mentions in another post: human versus non-human is a very different question than alive, or animate, versus inanimate.
