How can Sine Integrals be calculated using polynomial representations?
  • Context: Graduate
  • Thread starter Thread starter TheDestroyer
    Integrate
The discussion revolves around the integration of the function sin(x)/x, exploring various methods including series expansions, integration by parts, and references to special functions like the Sine Integral. Participants also touch on related functions and their integrals, such as e^(x^2).
  • Some participants suggest using series expansions, such as Taylor series or Fourier series, to approach the integration of sin(x)/x.
  • Others argue that while Taylor series can provide a series representation, it does not yield a general antiderivative for the function.
  • Daniel mentions that the integral can be expressed in terms of the Sine Integral function, Si(x), and discusses conventions regarding constants in such expressions.
  • Some participants propose integration by parts as a method to evaluate the integral, though there is disagreement about its effectiveness in this case.
  • One participant describes a specific integration by parts approach that leads to a complex expression involving logarithms and trigonometric functions.
  • Another participant notes that sin(x)/x cannot be integrated in general terms and relates it to the exponential integral, suggesting contour integration as a method for specific limits.
  • References to polynomial representations and special functions are made, indicating that these functions cannot be expressed in terms of elementary functions.
Participants express multiple competing views on the methods for integrating sin(x)/x, with no consensus on a definitive approach or solution. The discussion remains unresolved regarding the best method to use.
Limitations include the dependence on specific series expansions and the unresolved nature of the antiderivative for sin(x)/x. Some methods discussed may not yield straightforward results, and assumptions about convergence and representation are not fully explored.
This discussion may be of interest to those studying calculus, particularly in the context of integrals involving trigonometric functions and special functions, as well as those exploring advanced mathematical techniques such as series expansions and contour integration.
TheDestroyer
Hi guys, I think the question is clear (lol)
How can the Sin(x)/(x) function be integrated? i heared it can be integrated using a series, anyone can explain?
Last added : I remembered the function e^(x^2) how also can it be integrated?
Thanks,
TheDestroyer
Can you think of a series for (sin x)/x?
Actually I studied taylor series, and using it will not give the general wanted answer as a function, but I heared it can be solved using the Fourier series, I don't know, I really completely don't know what to do about it!
I don't understand your objection: after integrating the Taylor series, you get the Taylor series for the result of the integral.
According to my ancient Maple,it is a constant times Si(x) + a constant.For some authors (like the ones who produced Maple),the first constant is +1...There are other conventions,though,tipically "normalization" ones,v.Erf(x) ...
Daniel.
THAT was initially
\int \frac{\sin x}{x} dx :wink:
Daniel.
P.S.Yours can be integrated exactly without any problem...
when you say "integrated" do you mean "antidifferentiated"?
Of course,what else,he wants to find the antiderivative for those 2 functions...
Daniel.
then there is not antiderivative for them ! even with a series?
try integration by parts...that is usefull for evaluating an integral composed of two fuctions, in this case, your first integral include the fuctions \sin {x} and \frac {\11}{x} and your second integral includes e^x and x^2
Remember, integration by parts formula yeilds:
{u}{v} - \int{v}{du}
and for the {e^{x^2}} fuction, when you integrate by parts, make sure you set u equal to the fuction whose derivative will eventually go to zero, otherwise you will have a mess on your hands.
They have antiderivatives,Si(x) and erf(ix) are (up until mulitplicative and additive constants) their antiderivatives...
Daniel.
Yes,part integration is a succesfull method of antidifferentiation,BUT NOT IN THIS CASE... :wink:
Daniel.
Can't you integrate sin(x)/x by using the fact that sin(x) = x - x^3/3! + x^5/5! - x^7/7! ... so sin(x)/x = 1 - x^2/3! + x^4/5! - x^6/7! ... this would give x - x^3/(3*3!) + x^5/(5*5!) - x^7/(7*7!) + C, and we know that sin(x)/x -> 1 as x -> 0, so C=1. This would give us that the antiderivate of sin(x)/x is:
1 + x - x^3/(3*3!) + x^5/(5*5!) - x^7/(7*7!) ...
And this can be expressed as an infinite sum if you like
Sure, hedlund:
This has already been mentioned by Hurkyl, hinted at by Daniel, and Zurtex has provided a link to a wolfram page.
You woke up a bit too late.This series method had been discussed in the first posts of the thread :-p
Daniel.
If you'd like a "better" series than a Taylor series, you might want to know the asymptotic expansion for the function. (By "better", I mean more, faster convergence).
\int{\frac{\sin{x}}{x}} = -\frac{\cos{x}}{x}-\int{\frac{\cos{x}}{x^2}}<br /> = -\frac{\cos{x}}{x}-\frac{\sin{x}}{x^2}-2\int{\frac{\sin{x}}{x^3}}
Notice that with each successive integration by parts, the remainder term gets smaller for large values of x. Thus, for all x above a certain value, this series should converge.
you need to use the midpoint rule, the trapezium rule and then apply these to simpsons rule silly, what's the width ur integrating?
open your MATLAB and insert the operation
then differentiate the answer given by MATLAB
then search the solution reverse...
(start from the final step and come to the first step)
sometimes the above method will work...but even I am not sure about it
There could be other way as to go for Fourier transform keeping f=0 (frequency )in its equation.If h(x)=\hat{f}(x) then  \hat{h}(\xi)= f(-\xi). that is duality of Fourier transform.
well... i looked through all the replies to this question and felt that no one really answered it. sooooo
i got the integral to sin(x)/(x) to = -cos(x)(1/2x) + (1/2)ln(x)sin(x) +c
done by integration by parts twice.
so integral of udv = uv - integral of vdu
u = lnx
du = 1/x
dv = sinx
v = -cosx
u get -cosx/x + (integral of cosxlnx) ------ do integration by parts again
u = lnx
du = 1/x
dv = cosx
v = sinx
so u get lnxsinx - (integral of sinx/x). add the (integral of sinx/x) over. So now you have 2(integral of sinx/x) = -cosx/x + lnxsinx
divide the 2 over n you get -cos(x)(1/2x) + (1/2)ln(x)sin(x) +c
u = lnx
du = 1/x
dv = sinx
v = -cosx
u = lnx
du = 1/x
dv = cosx
v = sinx
i lied... i differentiate wrong lol
sin(x)/x
Essentially you cannot integrate sin(x)/x in general -- you just get something related to the exponential integral which is defined as the integral of e^x/x.
However, the integral can be done from -infinity to infinity using coutour integrals in the complex plane. See
http://raghumahajan.wordpress.com/2010/07/26/integral-of-sinxx/
In this case the value of int^infty_infty sin(x)/x is pi.
You are trying to find what is called the Sine Integral:
http://en.wikipedia.org/wiki/Trigonometric_integral
Sine integrals and related functions cannot be represented by elementary functions (they are similar to elliptic integrals in this regard).
The value of such functions can be calculated using certain polynomial representations. For example, see Abramowitz and Stegun.
