- 2,119
- 2,692
Member warned that the homework template must be used, and an effort shown
In any triangle ABC, prove that $$(b+c-a) \left( \cot {\frac {B}{2}} + \cot {\frac {C}{2}} \right)=2a \cot {\frac {A}{2}} $$
Wrichik Basu said:In any triangle ABC, prove that $$(b+c-a) \left( \cot {\frac {B}{2}} + \cot {\frac {C}{2}} \right)=2a \cot {\frac {A}{2}} $$
Buffu said:Did you try to solve this ?
Also you should not vandalise the template.
Use sine rule and A + B + C = 180.Wrichik Basu said:I tried in several ways, trying to change a, b, c to 2R sin A and like that, or trying the formulae for cot A/2, but got nowhere.
The three basic trigonometric functions are sine, cosine, and tangent. These functions relate the angles of a right triangle to the lengths of its sides.
To find the missing side length of a right triangle using trigonometry, you can use the Pythagorean theorem (a² + b² = c²) or one of the trigonometric ratios (sin, cos, or tan) depending on the information given. If you have the length of one side and the measure of one angle, you can use sine or cosine. If you have the lengths of two sides, you can use tangent.
The primary properties of triangles that are used in trigonometry are the Pythagorean theorem, the sum of angles in a triangle (which is always 180 degrees), and the trigonometric ratios (sine, cosine, and tangent).
The Law of Sines and the Law of Cosines are used to solve problems involving triangles that are not right triangles. The Law of Sines relates the lengths of the sides of a triangle to the sine of their opposite angles, while the Law of Cosines relates the lengths of the sides to the cosine of one of the angles. These laws can be used to find missing side lengths or angle measures in oblique triangles.
Yes, trigonometry is used in many real-life applications, such as engineering, architecture, physics, and astronomy. It can be used to calculate distances, angles, and heights in various structures and objects. For example, trigonometry is used to design buildings and bridges, navigate ships, and predict the movement of planets and stars.
