A question about the proof of the simple approximation lemma
In summary, the Simple Approximation Lemma states that for any measurable and bounded function f on a set E, there exist simple functions \phi_{\epsilon} and \psi_{\epsilon} that are close approximations of f on E.
Artusartos
247
The Simple Approximation Lemma
Let f be a measurable real-valued function on E. Assume f is bounded on E, that is, there is an [itex]M \geq 0[/itex] for which [itex]|f|\leq M[/itex] on E. Then for each [itex]\epsilon > 0[/itex], there are simple functions [itex]\phi_{\epsilon}[/itex] and [itex]\psi_{\epsilon}[/itex] defined on E which have the following approximation properties:
[itex]\phi_{\epsilon} \leq f \leq \psi_{\epsilon}[/itex] and [itex]0 \leq \psi_{\epsilon} - \phi_{\epsilon} < \epsilon[/itex] on E.
Proof: Let (c,d) be an open, bouned interval that contains the image of E, f(x), and [itex]c=y_0 < y_1 < ... < y_n = d[/itex] be a partition of the closed, bouned interval [c,d] such that [itex]y_{k}-y_{k-1} < \epsilon[/itex] for [itex]1 \leq k \leq n[/itex].
[tex]I_k = [y_{k-1}, y_k)[/tex] and [tex]E_k = f^{-1}(I_k)[/tex] for [itex]1 \leq k \leq n[/itex]
Since each [itex]I_k[/itex] is an inteval and the function f is measurable, each set [itex]E_k[/itex] is measurable. Define the simple functions [itex]\phi_{\epsilon}[/itex] and [itex]\psi_{\epsilon}[/itex] on E by
[tex]\phi_{\epsilon} = \sum^{n}_{k=1} y_{k-1} . \chi_{E_k}[/tex]
and [tex]\psi_{\epsilon} = \sum^{n}_{k=1} y_{k} . \chi_{E_k}[/tex]
Let x belong to E. Since [itex]f(E) \subseteq (c,d)[/itex], there is a unique k, [itex]1 \leq k \leq n[/itex], for which [itex]y_{k-1} \leq f(x) < y_k[/itex] and therefore [tex]\phi_{\epsilon} (x) = y_{k-1} \leq f(x) < y_k = \psi_{\epsilon} (x)[/tex].
But [itex]y_k - y_{k-1} < \epsilon[/itex], and therefore [itex]\phi_{\epsilon}[/itex] and [itex]\psi_{\epsilon}[/itex] have the required approximation properties.
My Question:
"Let x belong to E. Since [itex]f(E) \subseteq (c,d)[/itex], there is a unique k, [itex]1 \leq k \leq n[/itex], for which [itex]y_{k-1} \leq f(x) < y_k[/itex] and therefore [tex]\phi_{\epsilon} (x) = y_{k-1} \leq f(x) < y_k = \psi_{\epsilon} (x)[/tex]." So if we choose any x, we will aways be able to find [itex]y_k[/itex] and [itex]y_{k-1}[/itex] such that [tex]\phi_{\epsilon} (x) = y_{k-1} \leq f(x) < y_k = \psi_{\epsilon} (x)[/tex], right? But the theorem tell us that we need to find [itex]\phi_{\epsilon}[/itex] and [itex]\psi_{\epsilon}[/itex] so that [itex]\phi_{\epsilon}[/itex] is less than all possible values of f(x) and that [itex]\psi_{\epsilon}[/itex] is greater than all possible values of f(x) (not specific for any x you choose, so you the proof gives you a different [itex]y_k[/itex] and [itex]y_{k-1}[/itex] for each x...but the theorem tell us that there is only one for the whole function. Also, how can the whole function be greater than [itex]\phi_{\epsilon}[/itex] and less than [itex]\psi_{epsilon}[/itex], if the difference is less than epsilon?)...so I don't understand this proof.
##f(x)## as a whole lies between ##\phi_\epsilon## and ##\psi_\epsilon##, which are step functions, a lower step function and an upper. For a single point ##x_0## we have only two single steps: the lower and the upper, and ##f(x_0)## lies between ##y_{k-1}\chi_{E_k}## and ##y_{k}\chi_{E_k}##. However, all steps bands are close enough. Draw a picture.
Can you please explain it to me?
My
The key to understanding this proof lies in the definition of a simple function. A simple function is a function that takes on only a finite number of values. In this case, we are constructing \phi_{\epsilon} and \psi_{\epsilon} to be simple functions that approximate f on the set E. This means that for any given x \in E, there will be a unique k such that y_{k-1} \leq f(x) < y_k, and \phi_{\epsilon} (x) = y_{k-1} and \psi_{\epsilon} (x) = y_k.
As for your confusion about \phi_{\epsilon} and \psi_{\epsilon} being less than and greater than all possible values of f(x), this is simply a way of saying that they are upper and lower bounds for f(x) on the set E. The difference between \phi_{\epsilon} and \psi_{\epsilon} is less than \epsilon, which means that they are very close to each other and therefore provide a good approximation for f(x).
I hope this clarifies the proof for you. The key is to understand the definition of a simple function and how it is being used to approximate f on the set E.
Related to A question about the proof of the simple approximation lemma
1. What is the Simple Approximation Lemma?
The Simple Approximation Lemma is a mathematical theorem that states that any continuous function on a compact interval can be approximated by a polynomial function with a certain degree of accuracy.
2. How is the Simple Approximation Lemma proved?
The proof of the Simple Approximation Lemma involves using the Weierstrass Approximation Theorem, which states that any continuous function on a closed interval can be uniformly approximated by a polynomial function. The proof then uses a constructive algorithm to construct a polynomial function that meets the accuracy requirements.
3. What is the significance of the Simple Approximation Lemma?
The Simple Approximation Lemma is significant because it allows us to approximate complicated functions with simpler polynomial functions, which are easier to work with mathematically. This is useful in many applications, including numerical analysis and signal processing.
4. Are there any limitations to the Simple Approximation Lemma?
Yes, the Simple Approximation Lemma only applies to continuous functions on compact intervals. Additionally, the accuracy of the approximation depends on the degree of the polynomial used, so higher degree polynomials may be needed to achieve a more accurate approximation.
5. Can the Simple Approximation Lemma be generalized to higher dimensions?
Yes, the Simple Approximation Lemma can be extended to higher dimensions through the use of multivariate polynomials. However, the proof and application of the lemma become more complex in higher dimensions.
  • Topology and Analysis
