AC superconductor transmission
In summary, the conversation discusses the limitations of underground AC transmission due to line charging current and the potential for using superconducting material to mitigate these limitations. However, there are still risks and challenges associated with underground cables, such as floods and heat baking. The possibility of using higher currents and lower voltages in superconducting cables is also mentioned as a potential solution, but there are still limitations to consider.
kevinisfrom
36
TL;DR Summary
For underground AC transmission, the line charging current prevents the lines from exceeding 100 km due to the close proximity and high capacitance between the line and ground. If the line was made with superconducting material, I think the same distance limitation applies (assuming same power and voltages). The only saving grace I can see is that due to the higher currents, the voltages can be reduced, thus less effect of line charging and potentially longer lines.
For underground AC transmission, the line charging current prevents the lines from exceeding 100 km due to the close proximity and high capacitance between the line and ground. If the line was made with superconducting material, I think the same distance limitation applies (assuming same power and voltages). The only saving grace I can see is that due to the higher currents, the voltages can be reduced, thus less effect of line charging and potentially longer lines. Wanted to check and see if this rough understanding makes sense to the community?
It works. Some pilot cables are in use.
The challenge, above ground or below is the power to keep it cold compared with the power saved by zero resistive losses.
Underground cables have other unique risks. Floods are a big one. Heat baking is another. The city of Aukland NZ was blacked out when hot weather baked all the underground cables bringing power into the city.
Good thinking by the way. Line to ground capacitance is indeed a major limitation of underground AC cables. We might reduce that somewhat with super conducting cables. But maybe not enough to matter. Depends on the details.
Likes berkeman and DaveE
As current in a superconductor increases there are two limitations. The first is that there is a critical current density at which the superconductivity ceases. That is of the order of about 105 A/cm2.
The second is that the current flowing when superconductivity is suddenly lost, can generate sufficient heat to vaporise the superconductive material.
Related to AC superconductor transmission
1. What is an AC superconductor transmission?
An AC superconductor transmission is a type of electrical transmission system that uses superconducting materials to transmit alternating current (AC) electricity with very low resistance and high efficiency.
2. How does an AC superconductor transmission work?
An AC superconductor transmission works by using superconducting materials, which have zero electrical resistance at very low temperatures, to carry AC electricity. This allows for the transmission of large amounts of electricity with minimal losses.
3. What are the advantages of using AC superconductor transmission?
The main advantages of using AC superconductor transmission are its high efficiency, low losses, and ability to transmit large amounts of electricity over long distances. It also has a smaller footprint and requires less maintenance compared to traditional transmission systems.
4. What are the challenges of implementing AC superconductor transmission?
The main challenges of implementing AC superconductor transmission are the high cost of superconducting materials and the need for extremely low temperatures to maintain their superconducting properties. There are also technical challenges in designing and constructing the transmission systems.
5. What are the potential applications of AC superconductor transmission?
AC superconductor transmission has the potential to be used in various applications, including long-distance power transmission, renewable energy integration, and high-speed transportation systems. It can also be used in medical imaging and research, as well as in particle accelerators and other scientific experiments.
  • General Engineering
  • Electrical Engineering
  • Classical Physics
