- #36
songoku
- 2,296
- 325
Thank you very much for all the help and explanation Lnewqban, erobz, kuruman, haruspex, Steve4Physics, jbriggs444, malawi_glenn
Linear acceleration refers to the change in velocity of an object in a straight line, while angular acceleration refers to the change in rotational velocity of an object. In rolling motion, both linear and angular acceleration are present as the object is both translating and rotating.
The larger the radius of a pulley, the smaller the acceleration of the system will be. This is because a larger radius provides a greater mechanical advantage, meaning that less force is required to move the system, resulting in a slower acceleration.
Yes, the acceleration of a system can be negative in rolling motion. This occurs when the object is slowing down or moving in the opposite direction of its initial motion. It can also happen when there is a net force acting in the opposite direction of the object's motion.
Friction can slow down the acceleration of a system in rolling motion. This is because friction acts in the opposite direction of the object's motion, creating a resistive force that must be overcome by the applied force in order for the object to accelerate.
The mass of an object has an inverse relationship with its acceleration in rolling motion. This means that as the mass of the object increases, its acceleration decreases. This is because a greater mass requires a greater force to accelerate, and in rolling motion, the force is dependent on the mass of the object.
