Wooden sphere rolling on a double metal track
  • Thread starter Hak
  • Tags
    Rolling
  • #71
erobz said:
Is there something you are not understanding about the trig that allows you to have doubt about it?
No, I cannot understand why A and B should be considered not on the same level and why the ## \angle OAB## angle should measure 60° instead of 90°...
  • #72
Hak said:
At this point, I am no longer sure about this. Interestingly, this document from an American competition, in problem 2, reports the result with ##\sqrt{3}##, without proof. I can't understand...
In the diagrams you attached, it is not entirely clear where points P and Q are. Are they (1) respectively the lowest and highest points of the sphere, or (2) the point nearest where the plates meet and the point furthest from it?
The right-hand diagram appears to show the plates end-on, so is looking up the slope. That means (2) is the correct interpretation. This makes the answer 'Q' correct. The text is wrong to refer to them as (1).
Under interpretation (2), the speed of Q is v multiplied by the ratio of distances from Q to AB and O to AB, namely, ##(1+1/\sqrt 2)/(1/\sqrt 2)=1+\sqrt 2##.
Under interpretation (1), Q is not the fastest point, and its speed is indeterminate because we do not know the angle of the slope.
My guess is that your friend has taken the answer at the aapt site on trust and has fabricated an argument to justify it.
As to how the aapt answer came to be wrong, perhaps it was a rehash of an old question and they forgot to change everything consistently. It happens.
It sometimes helps to consider an extreme case. Suppose the plates are vertical, which they could be, as far as we know. The point at the top of the sphere is ##R\sqrt{3/2}## from AB, so moves at speed ##v\sqrt{3}##. Meanwhile, the point furthest from the plate join still moves at ##v(1+\sqrt 2)##.
Likes erobz
  • #73
Thank you so much, but... could you explain me the last paragraph? I don't think I understand this correctly, including the calculations...
  • #75
  • #76
The point O is ##R/\sqrt 2## from AB.
In the vertical plates model, that is a horizontal distance. The top of the sphere is R above O, so distance ##R\sqrt{(1/\sqrt 2)^2+1^2}=R\sqrt{3/2}## from AB.
Being ##\frac{R\sqrt{3/2}}{R/\sqrt 2}=\sqrt 3## times further away from AB, it moves that much times faster than O.
  • #77
erobz said:
That is a different problem... The left rail is not tangent to the sphere at the point of contact.
Looks suspiciously like a case of sloppy plagiarism by an aapt contributor.
I have emailed aapt.
Likes erobz
  • #78
Thank you very much to everyone. You have all been very kind and professional. A wonderful disquisition.
Likes erobz
  • #79
A friend of mine, regarding point 3, set up a different procedure.
"The weight force acting on the center of mass ##O## forms the angle ##\alpha## with its projection on the plane ##AOB##, ##AB## being the instantaneous axis of rotation. Therefore the component of the weight force acting along the inclined plane, rib of the guide, results ##F_P = Mg \sin \alpha##. The other component ##F_H = Mg \cos \alpha## has two components, one on ##AO## and one on ##BO##, perpendicular to the tracks of ##A## and ##B## on the guides. Their value is ##N = Mg \frac{\sqrt{2}}{2} \cos \alpha##. We determine the minimum value of ##\mu##, i.e., ##\mu_m##, by imposing constancy of ##v##, i.e., that twice the friction force ##F_{friction}## (because it develops in ##A## and ##B##) is equal to the force ##F_P##. Meanwhile, it is ##F_{friction} \le \mu N##, whence ##\mu \ge \frac{F_{friction}}{N}##. Since it must be, for the constancy of ##v##, ##2F_{friction} = 2 Mg \sin \alpha##, it follows that ##\mu## must be at least equal to ##\mu = \sqrt{2} \tan \alpha##".
All this is different from the procedure carried out together a few days ago. What is wrong with this?
  • #80
How many friends do you have? Do any of them agree with the method found in this thread? :cry:
  • #81
The "friends" you speak of are only two, with the term "friends" not so appropriate. You are absolutely right, but could you tell me what is wrong with my "friend" 's reasoning? As I understand it, he assumed ##v## constant, while we considered some acceleration of the center of mass other than 0. Perhaps he considered "rolling without sliding" simply as "pure rolling"? Could you provide some guidance on this?
  • #82
There is no reason why you shouldn't be able to reconcile these errors on your own at this point if you insist on checking everyone else's work. There are obvious errors, but I want you to find them with confidence, and report back your findings if it is that important to you.
  • #83
I found two errors in the resolution I posted previously.
1. He says that "twice the friction force (because it develops in ##A## and ##B##) is equal to the force ##F_P##", but then inexplicably concludes that ##2F_{friction} = 2Mg \sin \alpha##, considering twice the tangential component of the weight force. Therefore, his result, according to his reasoning, should be half of what he obtained, i.e., ##\mu = \frac{\sqrt{2}}{2} \tan \alpha##.
2. The one just quoted is the result that would be obtained by setting the acceleration of the center of mass equal to 0. I do not understand, however, why should ##v## be considered constant . There is a net torque produced by the forces (obviously, different depending on the axis chosen), which produces angular acceleration, so the center of mass possesses its own acceleration .
Are these objections correct? In what do I mistake?
  • #84
Your objections are correct, however you can immediately ignore explaining the silly math in you first objection, because your second objection outweighs it. The center of mass is accelerating as you point out.
There is another error yet.
  • #85
Would that be the other mistake? I could not understand the meaning of his statement, could you explain it to me?
  • #86
they appear to be talking about the normal forces being components of the component of weight resolved perpendicular to the incline. It’s not something one should try to understand… they are saying ∑ forces perpendicular to plane…not well.
  • #87
Maybe I expressed myself wrongly. I didn't mean that "I can't understand it," I meant that "I couldn't understand the meaning." In other words, I did not understand why he conceived such an argument, which is why I asked you... So, are these the main errors?
Likes erobz
  • #88
Could you explain more about this statement?
  • #89
When they say there are two components of the resolved weight force, they mean there are two forces that oppose the resolved weight force.
They are not correctly stating what they mean( and appear to understand )based on the result they got for ##N##. That error is forgivable in comparison to the others, but still should be addressed.
  • #90
It's inaccurate to say ##F_H## has two components. Rather, it can be resolved into two components, each normal to a plate, and normal to each other. Since there is no acceleration normal to a plate, these must equal the normal forces from the plates.
As discussed, the constant velocity argument is nonsense.
  • #91
Thank you so much!
Likes erobz
  • #92
Postscript.
I notified AAPT of the issue …
A student has contacted me regarding this document (
https://www.aapt.org/Common/upload/2020-Fma-Exam-A_solutions.pdf). He is baffled by a formula quoted in the solution. I share his bafflement.
First, there seems to be some confusion regarding point Q in the diagram. The text defines it as the "highest point" of the sphere. The diagram implies it is not that; rather, it is the point furthest from the junction of the plates. Indeed, the highest point is not the fastest moving, whereas the point furthest from the junction of the plates is.
But what bothers the student is the formula quoted, v (2+sqrt(3))/sqrt(3). It seems clear it should be v(1+sqrt(2)).
… and got an appreciative response:
Thank you for the correction, we completely agree! 2020 was an unusual year, and the problems and solutions that year were much less polished due to the pandemic -- we didn't even bother grading the exams. We'll update the file on the website later this year, and we'd appreciate hearing about any other issues as well.
  • #93
haruspex said:
Postscript.
Thank you so much, @haruspex!
  • #94
kuruman said:
Look at the figure below. The axis of rotation is the red dotted line AB. All points on the sphere rotate about that axis with a common angular velocity ##\mathbf{\omega}##. Their linear velocity relative to AB, which is at rest relative to the track, is ##\mathbf{v}=\mathbf{\omega}\times \mathbf{r}.## Here, ## \mathbf{r}## is the position vector of a point on the sphere perpendicular to the axis AB. How do you find the point at which ##\mathbf{v}## has the largest magnitude?
Hi, this problem is pretty interesting and it does not seem simple to understand. Particularly, I think I disagree with the notion that the line joining the points A and B is the rotation axis. I think the rotation axis is the line passing through the center O of the sphere and parallel to the AB segment. This is because otherwise the sphere would not simply roll (without slipping) through the plates. In order to see it, remove the plates from your picture and imagine the sphere rotating about the AB axis: its movement would not correspond to a rolling (without slipping) through the plates! In fact, the center O of the sphere would go below the AB axis during part of such a movement. Therefore, I think either one of the following options would be true: the rotation axis is still the diameter parallel to the AB axis, or the movement is not simply rolling without slipping and we should have a more complicated dynamics (maybe this is what haruspex is also finding difficult to figure out regarding this problem, see this post: https://www.physicsforums.com/threa...-on-a-double-metal-track.1055489/post-6930364 ).
  • #95
You are confusing instantaneous centre of rotation with a constant centre of rotation.
By your argument, a wheel rolling along the road can't be rotating about the point of contact because it would penetrate the road. But the point of contact must be the instantaneous centre of rotation because that is the only part of the wheel that is instantaneously stationary.
  • #96
I am not familiar with this concept of instantaneous center of rotation. I think a wheel rolling along the road is clearly rotating about its diameter. In fact, if it was rotating about the point of contact it would not simply roll along the road.
  • #97
I am sure you have watched a wheel spin in place about a fixed axis. You should know that each point on the rim has velocity directed tangent to the rim and linear speed ##v=\omega~R## where ##\omega## is the angular speed. That's the background.
You should also be familiar with the following situation. You are riding a bicycle moving at 15 mph on a road. You look over the handle bar down at the front wheel. What do you see?
You see the axle of the wheel at rest relative to you while the wheel is spinning about it. Based on what was said in the first paragraph, you also see the top of the wheel moving forward with speed ##v=\omega~R=15~##mph and the bottom of the wheel where it touches the ground moving backward with speed ##v=\omega~R=15~##mph. Furthermore, you see the road surface moving backwards at 15 mph.
This is a relative velocity question. If the road is moving backwards at 15 mph and the point of contact is also moving backwards at 15 mph, what is the velocity of the road relative to point on the rim that is (Instantaneously) in contact with the road?
  • #98
If the wheel is not skidding then the point of contact is instantaneously still. A point distance y above it is moving forward at speed ##\omega y##, a point distance y below it is moving backward at speed ##\omega y##, a point distance y in front is moving down at speed ##\omega y##, a point distance y behind it is moving up at speed ##\omega y##.
It is the instantaneous centre of rotation.
If that bothers you, you will find it easier to think of the motion as the sum of the linear motion of the ball's centre and a rotation about that. The algebra works either way.
