Any sunlight band pass filter for 400-700nm of EM Spectrum?
In summary, a Fresnel lens or other device concentrating sunlight to and through a transparent material could be used to remove excess heat beyond its rated capacity.
shane2
89
This 400-700nm slice is the Photosynthetically Active Radiation (PAR) required of plants and, for many applications, there is much unwanted UV and IR heat outside of it.
Is there any known translucent material or film that will pass a high % of that 400-700nm wavelength from sunlight while also largely excluding the rest, either by reflection and/or absorbance?
If there is anything worth looking into, but it's also crazy expensive for much more than a couple square inches of it, how best to remove any excess heat beyond its rated capacity if a Fresnel lens or other device concentrates sunlight to and through it?
Thanks for any suggestions or links for more info.
Science news on Phys.org
What exactly are you trying to do? We may have a another suggestion that can help you.
New hot desert small greenhouse design, inquiring if any better films, perhaps not well known for this application, that could be used to minimize IR gain.
Or, if crazy expensive for more than a couple square inches, if could have sunlight concentrated onto and through it to then be diffused inside, minus IR component.
Well, I certainly can't help you with that. Hopefully others here can. Best of luck!
The most simple filter I can think of would be a few cm of water held within a polycarbonate tray. Water will absorb most of the IR and the polycarbonate will absorb most of the UV:
https://upload.wikimedia.org/wikipedia/commons/1/18/Absorption_spectrum_of_liquid_water.png
http://www.americanaquariumproducts.com/images/graphics/polycarbonatetransmission.jpg
Likes davenn
Does a standard greenhouse setup not perform well enough?
Greenhouses in cooler weather function very well as designed warming up interior, though have challenges at night keeping it.
Greenhouses in deserts in summer heat expend huge resources in water and electricity in pumps/fans for evaporation cooling fighting excess IR heat build up. They also often employ moveable shading, which unfortunately also reduces the good PAR portion of sunlight desired, too.
Bottom Line: I'm interested in exploring anything that could be employed, beyond current commercial greenhouse specialty glazing, to let more of that 400-700nm slice of Photosynthetically Active Radiation (PAR) required of plants in, while reflecting or absorbing, thus keeping out, more of that unwanted UV and IR heat outside of 400-700nm.
Oh, I thought you wanted a desert environment inside of a greenhouse, but you want a non-desert environment inside while the greenhouse is in the desert.
Thanks, Tom.G!
Update; Off exploring Borofloat hot mirrors now, to where inexpensive solar reflectors or cheap re-purposed Cassegrain parabolic dish could concentrate light through hot mirror smaller footprint, where IR reflected off it there, then PAR visible light transmitted coolly through it to inside before being diffused. Looking at direct hollow light tube, rather than adding complexity/cost of fiber optics to direct that cooler light inside. Some outfits already offering both versions, but seeing what DIY cheaper options possible.
Bottom Line: trying to determine if it could be done cheaper than dealing with usual excessive solar IR gain of desert summer greenhouses requiring expense of cooling space via evaporation coolers, pumps and fans, especially where water and electricity is scarce.
Any suggestions or thoughts appreciated.
Related to Any sunlight band pass filter for 400-700nm of EM Spectrum?
1. What is a sunlight band pass filter for 400-700nm of EM Spectrum?
A sunlight band pass filter is a type of optical filter that selectively transmits light within a specific range of wavelengths, in this case 400-700 nanometers (nm) of the electromagnetic (EM) spectrum. This range includes visible light, which is the portion of the EM spectrum that can be seen by the human eye.
2. How does a sunlight band pass filter work?
A sunlight band pass filter works by using a material or coating that only allows light within a certain range of wavelengths to pass through, while blocking all other wavelengths. In this case, the filter is designed to only allow light between 400-700nm to pass through, resulting in a band of visible light being transmitted.
3. What are the applications of a sunlight band pass filter?
A sunlight band pass filter has various applications in science, technology, and everyday life. It can be used in photography to remove unwanted wavelengths of light and enhance the colors in an image. It is also used in spectrophotometers to analyze the light spectra of different materials. Additionally, sunlight band pass filters are commonly used in sunglasses and camera lenses to protect against harmful UV radiation.
4. How is a sunlight band pass filter different from other types of filters?
A sunlight band pass filter is different from other types of filters in that it specifically targets a range of wavelengths in the EM spectrum, rather than just blocking or transmitting all wavelengths. This allows for more precise control over the light that is transmitted, making it useful for a variety of applications.
5. Can a sunlight band pass filter be customized for different wavelengths?
Yes, a sunlight band pass filter can be customized for different wavelengths by changing the materials or coatings used. For example, a filter designed to only allow light between 500-600nm could be created by selecting materials that block all other wavelengths. This customization allows for a wide range of applications in various fields of science and technology.
