Ball does not bounce automatically because of entropy?
In summary, The entropy gravity hypothesis is a contested theory about the relationship between entropy and gravity. It suggests that entropy is a force that behaves like an entropic force.
Avichal
295
When reading about entropy it states that ball does not automatically bounce up because of entropy. It is just not favorable.
I don't get this. Isn't the correct reason gravity? Ball does not bounce up because of gravity! Where does entropy come from?
Science news on Phys.org
Entropy and gravity are two very different topics. Entropy is the measure of randomness of the system. In the question it says that "the ball does not automatically bounce up". The only other way is that the ball must hit the surface and 'stick to it' so that it can't bounce. Since entropy is about randomness, it must have meant that the 'sticking up of ball and Earth is nothing but the increase of randomness' (we must note that Earth and ball are two very different things!).
However if could just give the whole context/paragraph of it (means more details..), then the discussion might become more easier... :)
I read about entropy some time back. This thought occurred to me now. However I did find an instance where it gives a similar example. http://2ndlaw.oxy.edu/entropy.html
It says that when we drop a ball it will fall down and this is because of second law of thermodynamics. I don't understand what second law of thermodynamics has to do with ball falling down. It falls down because of gravity.
The ball has enough thermal energy to lift the ball against gravity. So it wouldn't violate Conservation of Energy (1st law of thermodynamics) if the ball would jump up on its own. But it would violate the 2nd law, and constitute a perpetual motion machine of the second kind:
http://en.wikipedia.org/wiki/Perpetual_Motion_Machine#Classification
Thermal energy is kinetic energy with random movement of molecules. Converting that into kinetic energy of the ball as a whole would require a reduction of randomness (Entropy) of the movement .
If the ball is left in air - it falls down. Well if it stays, it's neither violating law of conservation of energy nor second law of thermodynamics.
Of course you'll say it falls because of gravity. But I'm still confused - it doesn't violate any law!
Your confusion relies on the fact that gravity tends to be an entropic force. For example if you have a clump of gas in one area and you let the system evolve, by diffusion the clump will spread and entropy will increase.
In gravitational physics however entropy is different. If we start out with a almost evenly diffused system of gas molecule and only consider gravitational interactions, the molecules will start to clump together. This better be in accordance with the second law of thermodynamics. That must mean gravity behaves like an entropic force. Thinking about gravity and entropy in this way should help you understand your doubt
I googled 'entropy gravity' and found an article on Wikipedia. It seems to be an hypothesis and is intensely contested. I don't think I should think on the lines of that as it may not be true.
For it to stay in the air it would have to violate physics by not responding to the applied force of gravity. Note that something doesn't have to be called a law in order for it to be true.
Thanks, it makes sense now. Is the entropy gravity hypothesis a hot topic in physics? I am intrigued by the idea.
Based on my extremely limited reading about the subject, it appears that it isn't really that hot. It appears more as another "interpretation" of gravity, since it makes no predictions that GR doesn't already make.
The big question touched on here is one that's still unresolved in physics. All the laws of motion from particles to galaxies are symmetric in time. So why do we see time having an obvious direction (the past is different than the future)?
On the level of single particles, we can't tell if a film of a trajectory is being played forward or backward. A planet orbiting a star would look the same except it would be moving in the opposite direction, still described accurately by the same laws.
The obvious exception to this is the second law of thermodynamics.
There is an obvious direction to time as we know it. We never see an egg unscramble, even though it's theoretically possible that every atom's trajectory could happen to be just so that it ends up coming back together again.
The reason we never see this is that it is so incredibly unlikely that every atom will happen to be arranged just so. There are much MUCH fewer ways that the atoms in the shell and yolk could be arranged to come back together again than there are for the shell and yolk to remain an icky mess on the floor.
This isn't entirely satisfactory because all that it means is that the entropy is always smaller in the past and larger in the future, and that the arrow of time points toward increasing entropy (kind of circular).
Getting a bit more speculative, if there were some point in the far distant past where the entropy was minimal (think.. big bounce scenario), then before that time, the arrow of increasing entropy would be pointing in the opposite direction in time that it does now. Alternatively, if there were some point in the far distant future, where the entropy was maximal (think.. heat death of the universe), there would be no meaningful distinction between past and future since the arrow of time in the direction of increasing entropy would no longer work as a concept.
I study information theory and entropy in grad school (for physics). Hope this helps:)
Related to Ball does not bounce automatically because of entropy?
1. Why does a ball not bounce automatically?
A ball does not bounce automatically because of the principle of entropy. Entropy is a measure of the disorder or randomness in a system, and it is always increasing. When a ball bounces, it loses energy to the surrounding environment in the form of heat, sound, and deformation. This energy loss increases the disorder of the system, making it less likely for the ball to bounce again.
2. What is entropy and how does it affect a bouncing ball?
Entropy is the measure of the disorder or randomness in a system. In the case of a bouncing ball, entropy is affected by the energy loss that occurs during the bouncing process. As the ball bounces, it loses energy in the form of heat, sound, and deformation, which increases the disorder of the system. This decrease in energy and increase in disorder makes it less likely for the ball to bounce again.
3. Can a ball bounce forever?
No, a ball cannot bounce forever because of the principle of entropy. As mentioned earlier, entropy is always increasing in a system, and a bouncing ball is no exception. With each bounce, the ball loses energy to the surrounding environment, increasing the disorder of the system and making it less likely to bounce again. Eventually, the ball will come to rest due to the continuous increase in entropy.
4. Is there a way to prevent a ball from losing energy and bouncing forever?
No, there is no way to prevent a ball from losing energy and bouncing forever. The principle of entropy is a fundamental law of nature, and it is impossible to reverse or stop this process. However, we can slow down the effects of entropy by reducing energy losses through methods such as using more elastic materials or reducing friction.
5. What other factors besides entropy can affect a ball's bounce?
Besides entropy, other factors that can affect a ball's bounce include the material and shape of the ball, the surface it is bouncing on, and the force with which it is thrown or dropped. For example, a ball made of rubber will bounce higher than a ball made of clay due to its elasticity. Similarly, a ball will bounce higher on a hard surface compared to a soft surface. The force with which the ball is thrown or dropped also plays a role in its bounce, as a higher force will result in a higher bounce.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
