Breaking force over set distance.
  • Thread starter fwFAWFSERG
  • Tags
    Force Set
In summary, two vehicles are approaching a red light at the same starting and ending points with the same velocities. One vehicle brakes early and coasts, while the other coasts and brakes in one application. The question is whether the wear on the brakes differs and if there is a difference in friction between coasting at 60mph and 40mph. It is determined that the wear on the brakes may differ due to the application of braking force and that air resistance and rolling resistance may have an impact on the efficiency of the braking process.
fwFAWFSERG
Hey guys, I have been having trouble trying to reason out in relation to real life application.
Problem:
Two vehicles (1,2) are traveling at 60mph approaching a red light 300 meters ahead. First let us state that both vehicles have the same starting & ending points, as well as the same final & initial velocities.
Vehicle A braked to 45mph relatively early (300m-250m) and coasted a majority of the way, braking @ the final stretch (100m-0m).
Vehicle B coasted relatively early (300m-150m) and braked in one application to a stop (150m-0m).
Question?
-Does the wear on the brakes differ, since both applied a braking force to decelerate from 60mph-0mph.
-Is the difference in friction negligible between 60mph vs. 40mph? (Car B and car A have the same friction/stopping power exerted upon them because they travel the same distance, at speeds relatively similar?)
-This may boil down to is the rate of deceleration/distance proportional to velocity ?
Thanks!
Intuition tells me that the wear and tear on the breaks must differ. I don't know what units wear and tear are measured in so it will be hard for me to quantify anything.
An analogous situation is speeding up in a car. Let's say two cars have identical final velocities and initial velocities. But one car speeds up at 'x' mphs while the other one speeds up at '3x' mph. One of the cars will have used more gas than the other right? There is no way to tell which car used more gas until you can find out the acceleration that yields optimal power output per unit volume of fuel. So basically unless you can find the variable "wear and tear per unit torque per second" for breaks then you won't be able to tell.
What about simply from a energy perspective, does friction/deceleration differ in aiding the braking of the vehicle depending on which speed the vehicle is coasting at (longer distance coasting @ higher speed vs shorter distance @ slower speed).
The flaw in this "real life" logic is that "coasting" most of the distance disippates energy (speed) via rolling friction and air resistance before the brakes are applied.
It is always more 'efficient' to coast, slow down, for as long a distance as possible to utilize
the momentum of the car instead of the gas pedal...and use friction to slow the vehicle instead of the brakes.
"The flaw in this "real life" logic is that "coasting" most of the distance disippates energy (speed) via rolling friction and air resistance before the brakes are applied. "
Since you are traveling the same total distance, is there a difference between coasting at a lower speed vs a higher speed. Will you generally endure the same rolling friction and air resistance?
Why analyse coasting friction at all? The OP's question is about breaking. The wear and tear on breaks due to rolling is either 0 or negligible in comparison to breaking.
This doesn't have anything to do with the question.
The internal friction should be negligible between 40mph and 60mph, but the wind resistance will not be.
If you apply the brakes in one go, then they will heat up more than if you spread it out over two times. That might have an impact on wear and tear and how much friction they can supply...whether positive or negative. Besides that, the brakes in both instances dissipate the same energy except for rolling and air resistance.
Air resistance rises with speed squared, so the car that braked in one go will have less braking to do. The rolling resistance I think is more or less the same no matter how fast you go.
Related to Breaking force over set distance.
1. What is breaking force over set distance?
Breaking force over set distance, also known as tensile strength, is the maximum amount of force that a material can withstand before it breaks when subjected to a specific distance or amount of strain. It is an important measure of a material's strength and durability.
2. How is breaking force over set distance measured?
Breaking force over set distance is typically measured using a tensile testing machine, which pulls a sample of the material until it breaks. The force and distance are recorded, and the breaking force over set distance is calculated by dividing the maximum force by the original cross-sectional area of the sample.
3. What factors can affect breaking force over set distance?
Breaking force over set distance can be influenced by various factors, including the type of material, its composition and structure, the rate at which it is pulled, and the surrounding temperature and humidity. It can also be affected by any defects or imperfections in the material.
4. How is breaking force over set distance used in engineering?
Breaking force over set distance is an important consideration in engineering, as it helps determine the suitability of a material for a particular application. Engineers use this measurement to select materials for different components and structures, ensuring they can withstand the expected forces and stresses without breaking.
5. Can breaking force over set distance be improved?
Yes, the breaking force over set distance of a material can be improved through various methods, such as altering its composition or structure, adding reinforcements, or using different manufacturing processes. However, each material has its limits, and there is no single solution to improve breaking force over set distance for all materials.
  • Mechanical Engineering
