Can gamma rays be deflected or shielded against with an electromagnetic field?
In summary, while electromagnetic fields can contain the energy/plasma from a fusion reaction, they cannot protect against gamma rays. Gamma rays are not affected by electromagnetic fields due to their lack of charge, and can only be shielded by high Z materials through interactions with electrons or nuclei. Thus, it would not be possible to deflect a nuclear blast with an EMF.
jarroe
40
I know we can contain the energy/plasma from a fussion reaction with an electromagnetic field, but would an EMF protect from gamma rays? Would it be possible to deflect a nuclear blast with a powerful enough EMF?
No. While theory predicts some interaction, this is extremely small. You won't change gamma rays in any significant way with electromagnetic fields.
Gamma radiation is from neutrons - they have no charge so the electromotive forces of the EMF have no effect on the gamma rays. The gamma waves could impart an electrical or magnetic effect on the EMF but it would be more like the inductance of an aluminum wire passing through a magnetic field but less intense.
Paul
Thanks! It was in respect to nuclear pulse propulsion and shielding from the blast/radiation effects.
How about a "plasma"? Contain the plasma in a megnetic field but how the density of the plasma or its charge can shield against Gamma ray's.
Paul
One source of Gamma rays is from the NUCLEUS during radioactive decay. But it is by no means the only source of Gamma radiation.
Dont forget Gamma rays are just extremely high energy photons
Dave
Gamma rays are high energy photon keV and above from nuclear or subatomic processes, e.g., anihilation (e+e- → γγ) or decay (e.g., πo → γγ).
Photons interact with charged particles, e.g., electrons, positrons, protons, and nuclei.
Gamma rays will not be detered by electric or magnetic fields, but they will interact with charged particles within those fields.
In radiation shielding, particular for shielding against gamma rays, one would use high Z materials because high-Z means high electron density. Electrons interact with photons via the photoelectric effect or Compton scattering. In the case of nuclei, gamma rays of energy greater than 1.022 MeV initiate pair production, and at higher energies, photoneutron emission, photodissociation (d+γ → p + n) or photofission/spallation.
Related to Can gamma rays be deflected or shielded against with an electromagnetic field?
1. Can gamma rays be deflected or shielded against with an electromagnetic field?
Yes, gamma rays can be deflected or shielded against with an electromagnetic field, but it depends on the strength and direction of the field, as well as the energy and wavelength of the gamma rays.
2. How does an electromagnetic field deflect or shield against gamma rays?
An electromagnetic field can deflect or shield against gamma rays by interacting with their electric and magnetic fields, causing them to change direction or lose energy.
3. Is an electromagnetic field the only way to deflect or shield against gamma rays?
No, there are other methods of deflecting or shielding against gamma rays, such as using lead or other dense materials to absorb the rays, or using magnetic fields to redirect the rays away from sensitive areas.
4. Can an electromagnetic field completely block all gamma rays?
No, it is not possible for an electromagnetic field to completely block all gamma rays. Some gamma rays may still pass through, depending on the strength and direction of the field, as well as the energy and wavelength of the gamma rays.
5. Are there any potential risks or side effects of using an electromagnetic field to deflect or shield against gamma rays?
Yes, there can be potential risks or side effects of using an electromagnetic field to deflect or shield against gamma rays, such as interfering with electronic equipment or causing harm to living organisms if the field is too strong.
