Can I know the reconstruction of phase shift interferometry in Matlab
In summary, the reconstruction of phase shift interferometry by angular spectrum method in Matlab appears to produce a high MSE value.
Leena Thomas
I want to know the reconstruction of phase shift interferometry by angular spectrum method in matlab
Welcome to the PF. :smile:
What research and reading have you been doing so far on this? Can you post some links? What other work have you done in Matlab that may be of similar complexity?
I did a Google search on your thread title, and got lots of useful hits. Please show us what you have done so far, to help us try to give you some help. Sounds like an interesting project. Is this for school? Or your work in an industrial lab?
I go through some papers on which hologram image is produced by PSI. So I think of its reconstruction.
Matlab:
clear all; close all;
I=imread('cameraman.tif', 'tif');
% parameter setup
M=256;
deltax=0.001; % pixel pitch 0.001 cm (10 um)
w=633*10^-8; % wavelength 633 nm
z=25; % 25 cm, propagation distance
delta=pi/2; % phase step (change it to show part b)
%Step 1: Simulation of propagation using the ASM
r=1:M;
c=1:M;
[C, R]=meshgrid(c, r);
A0=fftshift(ifft2(fftshift(I)));
deltaf=1/M/deltax;
p=exp(-2i*pi*z.*((1/w)^2-((R-M/2-1).*deltaf).^2-((C-M/2-1).*deltaf).^2).^0.5);
Az=A0.*p;
EO=fftshift(fft2(fftshift(Az)));
%Step 2: Interference at the hologram plane
AV=(min(min(abs(EO)))+max(max(abs(EO))));
% the amplitude of reference light
% Recording of Four phase-shifting holograms
I0=(EO+AV).*conj(EO+AV);
I1=(EO+AV*exp(-1j*delta)).*conj(EO+AV*exp(-1j*delta));
I2=(EO+AV*exp(-2j*delta)).*conj(EO+AV*exp(-2j*delta));
I3=(EO+AV*exp(-3j*delta)).*conj(EO+AV*exp(-3j*delta));
MAX=max(max([I0, I1, I2, I3]));
figure(1);
subplot(2,4,1);imshow(I);
title('Original object')
axis off
figure(1)
subplot(2,4,2)
imshow(I0/MAX);
axis off
title('hologram 1')
subplot(2,4,3)
imshow(I1/MAX);
axis off
title('hologram 2')
subplot(2,4,6)
imshow(I2/MAX);
axis off
title('hologram 3')
subplot(2,4,7)
imshow(I3/MAX);
axis off
title('hologram 4')
%Step 3: Reconstruction
CH=(I0-I2)-1j*(I1-I3); % the complex hologram (4-step PSH)
%A1=fftshift(ifft2(fftshift(CH)));
%Az1=A1.*conj(p);
%EI=fftshift(fft2(fftshift(Az1)));
%EI=(EI.*conj(EI));
%EI=EI/max(max(EI));
%figure(1);
%subplot(2,4,4)
%imshow(EI);
%title('Reconstructed image of 4-step PSH')
%axis offU1 = ifft2(ifftshift(fftshift(fft2(CH)).*conj(p)));
Iangular = (1/(16*pi)).*(U1.*conj(U1));
EI=Iangular/max(max(Iangular));
figure(1);
subplot(2,4,4)
imshow(EI);
axis off
s=PSNR(I,EI)
I did reconstruction of PSI but MSE found to be a high value... is the reconstruction method correct? please help me.
Related to Can I know the reconstruction of phase shift interferometry in Matlab
1. What is phase shift interferometry?
Phase shift interferometry is a technique used in optics and interferometry to measure the phase differences between two or more beams of light. It involves introducing a known phase shift between the beams and then measuring the resulting interference pattern, which can be used to calculate the phase difference.
2. How does phase shift interferometry work in Matlab?
In Matlab, phase shift interferometry works by using a combination of mathematical algorithms and functions to analyze the interference patterns and calculate the phase differences. It involves processing the captured images of the interference patterns and using various techniques such as Fourier transforms and phase unwrapping to extract the phase information.
3. What are the advantages of using Matlab for phase shift interferometry?
Matlab offers a powerful and versatile platform for analyzing and processing data, making it well-suited for phase shift interferometry. It has built-in functions and tools specifically designed for optical and mathematical analysis, making it easier to implement and troubleshoot algorithms. It also allows for easy visualization of results and can handle large datasets efficiently.
4. Are there any limitations to using Matlab for phase shift interferometry?
Like any software, Matlab has its limitations in terms of processing speed and memory constraints. This can become an issue when dealing with large datasets or when real-time analysis is required. Additionally, Matlab may not have specific functions or tools for certain types of phase shift interferometry techniques, which may require the user to develop their own algorithms.
5. Can I learn how to use Matlab for phase shift interferometry without prior experience?
Yes, Matlab has a user-friendly interface and provides extensive documentation and tutorials for beginners. With some basic knowledge of programming and optics, anyone can learn how to use Matlab for phase shift interferometry. There are also many online resources and forums available for guidance and support.
  • General Engineering
13K
