Chemistry: Proper Use of a Pipette
  • Thread starter Mazurka
  • Tags
    Chemistry
In summary, when conducting an experiment involving the transfer of a hot saturated solution, it is important to use a warm pipette to ensure accurate and reproducible results. Using a cool pipette may lead to errors in solubility and volume measurements, as well as potential safety hazards. Pre-warming the pipette to the temperature of the solution allows for more precise and consistent transfers.
Mazurka
Not much background information is needed. Lead (II) iodide is dissolved into deionized water, and the temperature of the solution is manipulated in order to explore the relationship between temperature and the solubility of the solution. To allow the solution to completely dissolve, it is placed inside an Erlenmeyer flask and heated to 100°C.
"When the Erlenmeyer flask is brought to 100°C and the solid settles, the hot saturated solution is transferred to a test tube using a warm pipette. Why must the pipette be warm in completing the transfer?"
N/A
"The pipette is warm to ensure that the solubility of the lead (II) iodide is not affected by changes in temperatures caused during the transfer to the test tube and that the volume of solution measured is accurate. If the pipette is cool, a certain amount of precipitate may be left inside the pipette after the transfer, affecting the measured final results of the experiment. Also, using a cool pipette may pose a safety hazard, as its glass could crack due to a sudden shift in temperature when placed into a 100°C solution."
Is this statement correct, or am I missing certain details that are common practice in a laboratory environment? Any help is greatly appreciated. :)
Thank you,
Eric.
Looks OK to me - at the same time using warm pipette and warm solution is wrong, as glass is always calibrated for some temperature, so you should recalibrate it. See www.titrations.info/pipette-burette[/url] and [url]www.titrations.info/volumetric-glass-calibration[/URL]
?But if the expansion coefficient of the pipette glass was the same as that of the flask glass you could hope errors due to glass expansion cancel each other out. :smile:
Liquids expand more than solids so I guess that causes a larger error than the glass.
Oh.
Well isn't glass an honorary solid?
Anyway what sort of error are we going to get? Something a lot smaller than the solubility effect.
One reason to use a pre-warmed pipette would be for reasons of reproducibility. If you pipette up the warm liquid in a cold pipette the glass will warm by some amount during the transfer, but it will not likely have enough time to reach thermal equilibrium with the liquid. Therefore, potentially every transfer will have a slightly different volume because the pipette was a different temperature during each transfer.
If the pipette is pre-warmed to the temperature of the solution, however, you will not have this problem of the pipette changing temperature during the transfer. While the volume will not be calibrated correctly, you can at least pipette the same amount reproducibly. In other words, this methods allow you to pipette precise amounts albeit not accurate amounts.
Your response is correct. The use of a warm pipette is necessary to ensure the accuracy of the experiment and to prevent any safety hazards. When transferring a hot solution, it is important to use a warm pipette to avoid sudden temperature changes that could affect the solubility of the lead (II) iodide. Additionally, using a warm pipette ensures that the volume of solution measured is accurate and that all of the precipitate is transferred to the test tube. This is a common practice in laboratory experiments to ensure reliable results and maintain safety precautions.
Related to Chemistry: Proper Use of a Pipette
1. How do I properly use a pipette?
To properly use a pipette, first make sure it is clean and calibrated. Then, insert the pipette tip into the liquid and slowly press the plunger to draw up the desired volume. After removing the pipette from the liquid, wipe off any excess liquid on the outside of the tip. Finally, dispense the liquid by carefully pressing the plunger to the first stop, and then fully releasing it.
2. What is the difference between a serological pipette and a volumetric pipette?
A serological pipette is designed for general use and has a graduated scale along the entire length of the pipette, allowing for variable volume measurements. A volumetric pipette, on the other hand, is designed for more precise measurements and has a single graduation mark at the calibrated volume, typically near the top of the pipette.
3. How do I maintain the accuracy of my pipette?
To maintain the accuracy of your pipette, it is important to regularly calibrate and clean it. Calibration involves checking the accuracy of the volume measurements and making adjustments if necessary. Cleaning should be done before and after each use, using a mild detergent and thorough rinsing with deionized water.
4. What is the proper way to store a pipette?
Pipettes should be stored in an upright position, either in a pipette rack or a designated holder. This helps to prevent any damage to the tip, as well as any contamination from other surfaces. It is also important to store pipettes in a dry and clean environment to maintain their accuracy.
5. How do I dispose of a used pipette tip?
Used pipette tips should be disposed of in a biohazard waste container, as they may come into contact with potentially hazardous substances. It is important to follow proper disposal guidelines to prevent any potential harm to yourself or others.
15K
