Choosing Axis of Rotation in Cylinder Oscillation Problem
In summary, the conversation discusses a problem involving two cylinders connected by a rod and a spring, and the goal is to find the angular frequency of the oscillations. The attempt at a solution involves simplifying the problem by treating the cylinders and rod as one cylinder with mass M, and using the Parallel-Axis theorem to find the moment of inertia. The choice of axis is not critical, but can simplify the algebra by eliminating forces that are not of interest. The conversation also raises a question about how the problem would change if the spring were attached to the top of the cylinder, and whether the cylinder could still be seen as rotating about its center mass.
BBA Biochemistry
Here is a problem we worked in class. I already know the answer, just had a question on the method.
Two cylinders are connected with by a small rod (with presumably negligent mass) through their centers. The cylinders can roll freely. A spring is attached to the small rod and causes the cylinders to oscillate and roll without slipping. The mass of the cylinders (M) and stiffness of the spring (k) are known. What is the angular frequency of the oscillations.
τ=Iα
τ=FR
F=-kx
Icyl=0.5MR2
Parallel Axis Theorem: Ip=ICM+Md2
α=aCM/R
We simplified the problem and said we can look at the two cylinders + rod as one cylinder with mass, M. The force of the spring provides a torque. We said that the cylinder is rotating about an axis at the point where it touches the floor. Is the reason we chose this axis (instead of the center of the cylinders) because the rod that is connected to the spring is going through the center of the cylinder, so there is no Ftan applied to the center mass that can provide torque?
Aside from that, I'm comfortable with the problem. We used the Parallel-Axis theorem to find the moment of inertia for that axis of rotation, and found torque with these two equations:
τ=Iα
τ=FR
We then set them equal to each other and got a differential equation to find ω.
How would this problem change if somehow the spring were attached to the top of the cylinder in a way that the it would apply force tangentially (without following the rolling motion of the ball)? Would we be able to see the cylinder as rotating about the center mass?
Thanks!
In the absence of a diagram you need to provide a clearer description.
I'm guessing that the cylinders and the rod are all coaxial, that this axis is horizontal, that the spring is also horizontal but at right angles to the rod's axis and attached to a fixed point at its other end.
The choice of axis is not critical, but some choices can eliminate forces that are of no interest and thereby simplify the algebra. In the present case, there is a frictional force from the ground. You have no need to determine that force. By taking the point of contact with the ground you avoid involving it in the equations. If you take the mass centre as axis you will need another equation (horizontal linear forces) in order to eliminate it.
(Masses can be negligible; describers of problems can be negligent.)
Related to Choosing Axis of Rotation in Cylinder Oscillation Problem
1. How do I determine the axis of rotation in a cylinder oscillation problem?
The axis of rotation in a cylinder oscillation problem can be determined by considering the point where the cylinder rotates without any translational motion. This point is known as the instantaneous center of rotation and is located on the axis of rotation.
2. What factors should be considered when choosing the axis of rotation in a cylinder oscillation problem?
Factors such as the shape and dimensions of the cylinder, the direction and magnitude of the oscillation, and the location of the point of contact with another surface should be considered when choosing the axis of rotation in a cylinder oscillation problem.
3. Can the axis of rotation be changed during a cylinder oscillation problem?
No, the axis of rotation should remain constant throughout a cylinder oscillation problem. Changing the axis of rotation can lead to incorrect calculations and results.
4. How does the choice of axis of rotation affect the motion of a cylinder in an oscillation problem?
The choice of axis of rotation can affect the complexity of the equations used to describe the motion of the cylinder, but it does not affect the actual motion of the cylinder itself. The motion will remain the same regardless of the choice of axis of rotation.
5. Are there any rules or guidelines for choosing the axis of rotation in a cylinder oscillation problem?
There are no strict rules or guidelines for choosing the axis of rotation in a cylinder oscillation problem. However, it is important to choose a point that simplifies the problem and makes the calculations easier. Additionally, the axis of rotation should be chosen in a way that accurately represents the motion of the cylinder.
