Maximum torque on a rotating cylinder kept on a moving plank
In summary: No, as I pointed out before, the acceleration of the platform is not constant. The trig function of time should be there.
Vinita
23
A cylinder of mass M and radius R is resting on a horizontal platform (which is parallel to the x-y plane) with its axis along the y- axis and free to rotate about its axis. The platform is given a motion in the x-direction given by x= Acos(ωt). There is no slipping between the cylinder and platform. The maximum torque acting on the cylinder during its motion is?
τ = Iα = F x R
Frictional force = μmg
Differentiating the given equation 2 times, I found out that maximum acceleration = Aω²
Torque will be maximum when acceleration is maximum to prevent slipping.
If an observer is placed on the plank,
the cylinder will appear at rest to him.
Thus to balance forces, frictional force= Pseudo force = mAω²
⇒μmg = mAω²
⇒μ = Aω²/g
Now to find torque due to friction -
We take a small ring on the disk (bottom part of the cylinder) of thickness dx and radius x,
Mass of this ring = M/πr² (2πr dx)
⇒dτ = M/πr² (2πx dx) μg x
Integrating x from 0 to R
τ = 2/3 μMgR
Putting the value of μ
τ = 2/3 MRAω²
But the answer is τ = 1/3 MRAω²
Since the cylinder never slips, you are dealing with static friction. For static friction the formula ##f_s^{\rm max} = \mu N## represents the maximum static friction force that could exist. But you can't assume that the friction force in this problem will ever equal its maximum possible value. The coefficient of friction ##\mu## is irrelevant in this problem. You may assume that there is always enough friction to prevent slipping. So, at any instant of time, the friction force will adjust itself to whatever is needed to prevent slipping.
I don't follow what you are doing in your integration. You have rings "of thickness dx and radius x", yet you write 2πr dx. What does r represent? There is no need to integrate over the cylinder. Just treat the cylinder as a rigid body and apply Newton's laws. You can work in the frame of reference of the Earth or the frame of reference of the platform (with pseudo-force).
Sorry that was a typing error. I corrected it.
I don't understand how.
Frictional force is acting forwards on the cylinder and backwards on the plank.
That means both have different accelerations.
I don't see why that stops you following TSny's advice.
You know the horizontal acceleration of the point of the cylinder which is (instantaneously) the point of contact.
I am doing something wrong.
At the point of contact, at a particular time t
a + Rα = Aw²
Where a = acceleration of cylinder
From here a = Aw²/2
So,
τ = Iα = MR²/2 (Aw²/2R) = 1/4 (MRAω²)
I am not able to visualize this problem. It's because the cylinder is kept vertically. It's confusing me too much.
Vinita said:
From here a = Aw²/2
Why?
The axis of the cylinder is horizontal, but you seem to have understood that, so why do you say it is vertical?
a + Rα = Aw²
These are functions of time. The trig function should be present.
Is it correct now?
haruspex said:
Why?
I misunderstood the question. Its clear now.
I the earlier post I assumed a = Rα
But that is clearly wrong.
I tried it again.
At a particular time t,
a + Rα = Aω² ---- (1)
Also, fR = τ = Iα
Where f = friction
⇒ fR = (MR²/2)α
⇒α = 2f/Mr ---- (2)
Also f = Ma ---- (3)
because f is the only force acting on the cylinder.
So from equations (1), (2) and (3),
f/M + 2f/M = Aω²
f/M = a = Aω²/3
⇒τ = MR²/2 (Aω²/3R) = 1/6 MRAω²
Its still wrong.
I don't understand.
Should I replace a by acos(t) ?
How do I know what trig function is it's acceleration?
You are given
Vinita said:
x= Acos(ωt).
Derive the acceleration from that.
haruspex said:
You are given
x = Acosωt --- (1)
a = -Aω² cosωt
But this will be the acceleration of the plank.
To convert it to acceleration of cylinder, I'll have to subtract distance traveled by cylinder on the plank from equation (1).
How should I do that?
Let
vc/g = the velocity in the x direction of the center of mass of the cylinder relative to the ground
vc/p = the velocity in the x direction of the center of mass of the cylinder relative to the plank
vp/g = the velocity in the x direction of the plank relative to the ground.
How are these related?
How can you use this relation to get the relationship between the accelerations ac/g, ac/p, and ap/g?
vc/p = vc/g - vp/g
I think the same will go for acceleration.
Vinita said:
vc/p = vc/g - vp/g
Yes
I did this again.
But this time I took the value of α = (Aω² - a)1/R = 2Aω²/3R
τ = MR²/2 (2Aω²/3R) = 1/3 (MRAω²)
Am I right this time?
Vinita said:
I did this again.
You might be right, but your solution is broken up among several previous posts. I think it would be a good idea to put it all together neatly in one post. Also, why do you assume from the beginning that you can use Aω2 for the acceleration of the plank? In post #14 you have the acceleration of the plank as a function of time. Using this you can deduce the torque on the cylinder as a function of time and then see when the torque is maximum.
Equation given for plank -
x = A cos(ωt)
Differentiating with respect to t, twice
a = -Aω² cos(ωt)
Maximum value of a = Aω²
a + Rα = acceleration of plank
Because there is no slipping.
Here a = acceleration of cylinder
⇒a + Rα = Aω² ---- (1)
Using τ = Iα
fR = MR²/2 (α)
where f = friction
α = 2f/MR ---- (2)
Using equations (1), (2) and (3)
f/M + 2f/M = Aω²
⇒f/M = Aω²/3 = a ----(4)
Using equations (4) and (1),
α = (Aω² - Aω²/3)/R = 2Aω²/3R
Again, τ = Iα
τ = MR²/2 (2Aω²/3R)
= 1/3 (MRAω²)
Is this correct?
Yes, that looks good.
Vinita said:
a = -Aω² cos(ωt)
OK, if this is clear to you before any calculations are done.
Or, you could use a = -Aω² cos(ωt) throughout the calculation to end up with τ =(1/3) MRAω²cos(ωt). So, you have the torque at any time and you can then clearly see that the maximum torque will be (1/3) MRAω² and that this occurs when the plank has its maximum acceleration.
Good work.
Okay. Thank you Sir for helping me.
Thank you Haruspex Sir for helping once again.
Related to Maximum torque on a rotating cylinder kept on a moving plank
What is maximum torque?
Maximum torque is the maximum amount of twisting force that can be applied to a rotating object. It is typically measured in newton-meters (Nm) or foot-pounds (ft-lb).
How is maximum torque calculated?
To calculate maximum torque on a rotating cylinder kept on a moving plank, you will need to know the force applied, the distance from the axis of rotation to the point where the force is applied, and the angle between the force and the lever arm. The formula for calculating torque is torque = force x lever arm x sin(angle).
Why is maximum torque important?
Maximum torque is important because it determines the amount of force that can be applied to a rotating object without causing it to rotate. It is also important for understanding the capabilities and limitations of machines and equipment.
How does a moving plank affect maximum torque?
A moving plank can affect maximum torque by changing the distance between the axis of rotation and the point where the force is applied, as well as the angle between the force and the lever arm. This can increase or decrease the torque depending on the direction and speed of the plank's movement.
What factors can affect maximum torque on a rotating cylinder?
Aside from the force applied and the distance and angle of application, other factors that can affect maximum torque on a rotating cylinder include the mass and shape of the cylinder, as well as any external forces or friction that may be present.
