Confusion About Wheels and Friction
In summary, the conversation discusses the relationship between the friction force and the force acting on the center of gravity of a freely rolling wheel. It is noted that if the two forces were equal in magnitude, the wheel would have a constant translational velocity but an increasing angular velocity, which is not possible. It is then explained that this is due to the forces being vectors and the distinction between "free vectors" and "bound vectors." The concept of rolling resistance is also mentioned. The conversation ends with the conclusion that the relationship between the two forces can be derived using Newton's second law and the no slipping condition.
QQB
If a wheel is freely rolling on the ground (not torque driven, but by a force acting on its center of gravity) towards the right, the friction force on the bottom of the wheel would be acting towards the left.
What if the friction force was equal to the force acting on the wheel's COG? Then the wheel would be translating with a constant velocity, yet its angular velocity would be increasing... and that's not possible.
I'm sure my thinking's wrong somewhere, but I don't know where.
Likes Stephen Tashi
The "what if" part.
As @A.T. points out, the problem is the assumption that the two forces can be equal in magnitude. In fact, what you did is called proof by contradiction. You assumed something, showed that it leads to a contradiction, and therefore proved the assumption is false.
A.T. said:
The "what if" part.
I'm afraid I don't see why the forces cannot be equal in magnitude (except by proof by contradiction). Is it just one of those facts of the universe, or do I have a poor understanding of the situation?
If the two forces were instead replaced by strings in tension (maybe the wheel is lying down on some friction-less plane), I can visualize that indeed the translational velocity would remain constant while the wheel spins faster and faster. Or is that wrong too...?
Imagine that the wheel is on an long treadmill surface that is accelerating to the right, exerting a friction force F to the right, and that an accelerating string attached to a frictionless hub is also exerting a force F to the right. What is the total force to the right on the wheel? What is the net torque applied to the wheel?
You mean equal in magnitude? Forces are vectors.
There is the distinction between "free vectors" and "bound vectors". The situation that you wish to consider is one where the frictional force and the force on the center of mass would sum to zero if they were treated as "free vectors" - i.e. as forces applied to the same point.
There is a difference between the practical situation and the theoretical situation.
In a theoretical model, if we roll a wheel along a flat surface, it will keep rolling at a constant velocity after we stop pushing it. The frictional force between the surface of the wheel and the flat surface drops to zero after we let the wheel roll "on its own".
Imagine a wheel rolling along a flat horizontal surface with some applied torque that makes it "burn rubber" - i.e. attempts to accelerate the wheel's angular velocity.. The force of friction upon the wheel points in the direction of the wheels translational velocity. Imagine a wheel rolling along a horizontal surface with some applied torque that attempts to "slam on the brakes" - i.e. deaccelerate the wheel's angular velocity. The force of friction upon the wheel points in the opposite direction to the wheels translational motion. We can appeal to a continuity argument to say that if the wheel's angular velocity is neither accelerating or deaccelerating then the frictional force is zero.
If we imagine a situation where a constant force of F is applied to the center of gravity of the wheel and a constant force of -F is applied to the wheel where it meets the flat surface, then the angular velocity of the wheel would accelerate. How can we imagine that happening? We can imagine there are small gremlins who live in the flat surface that grab the bottom of the wheel and try to spin it faster as its moves overhead. But to exert force to spin it, the gremlins would have to move their hands faster than the tangential velocity of the place where they were touching the wheel. If they just matched the velocity of their hand with the velocity of the place they were touching, they couldn't exert any force on it.
Likes Ibix
The wheel experiences rolling resistance that is counter to the driving force ,it is a reactive force , so that it cannot accelerate wheel
If the tangential string is unwinding from the wheel, then it's like rolling (same kinematic constraint).
The tangential string would go slack, or it would accelerate relative to the wheel, so not like rolling at constant speed anymore.
Well, you can calculate the relationship between the axle force and the friction force and prove it that way, but frankly your proof by contradiction is more elegant.
It feels weird to try to convince someone that their own line of reasoning is right. Usually I am contradicting them.
Likes QuantumQuest
I agree with Dale
So you can derive it with Newton's second law, the rotational form of Newton's second law, and the no slipping condition written as ##a=r\alpha##
Ohhh, after trying to piece together what everyone said and thinking about it some more, I remember the relationships now. I forgot it when I thought of the situation in my question!
Thanks for everyone's help!
Related to Confusion About Wheels and Friction
What is friction?
Friction is a force that opposes the motion of objects in contact with each other. It is caused by irregularities in the surfaces of the objects and can result in heat and wear on the objects.
How does friction affect wheels?
Friction can affect wheels in several ways. It can slow down the rotation of the wheels, making it harder for them to move. It can also cause wear on the wheels, which can lead to decreased performance and efficiency. Additionally, friction can cause heat to build up in the wheels, which can be dangerous if not managed properly.
Why do some wheels seem to roll more smoothly than others?
The smoothness of a wheel's rotation is affected by several factors, including the amount of friction present, the shape and material of the wheel, and the surface it is rolling on. Wheels with low levels of friction, such as those with ball bearings, will roll more smoothly than those with higher levels of friction.
How can friction be reduced in wheels?
There are several ways to reduce friction in wheels. One way is to use lubricants, such as oil or grease, to reduce the contact between the surfaces of the wheel and the surface it is rolling on. Another way is to use materials that are smoother and have lower levels of friction, such as ball bearings or Teflon coatings.
What is the relationship between friction and the weight of a wheel?
The weight of a wheel can affect the amount of friction present. Heavier wheels will have more force pressing down on the surface they are rolling on, which can increase the amount of friction. However, the shape and material of the wheel also play a significant role in the level of friction, so weight alone is not the only factor to consider.
