Construction of lines from points
In summary, the problem is that a line does not comprise points because points have no dimension. No two points form a line segment until you connect them with a line. No matter how small the inteval is between two points on a line, the points merely define the end points of the line segment between them but comprise no part of the line segment itself. To construct the line segment one would have to place a straight edge between the two points.
exmachina
44
After a rather interesting discussion in #math on freenode, I'm perplexed by the fact that there is no way to construct lines from points.
For example, I initially thought of constructing a line between 0 and 1 by repeatedly dividing into two smaller halves, eg:
0,1
0,0.5,1
0,0.25,0.5,0.75,1
..etc
But obviously this approach will miss the irrationals and cover only rationals of the form (1/2)^n thus, missing all others with such as (1/3)^n, (1/5)^n, (1/m)^n where m is prime.
So, in the hypothetical case where I do cover all the points arising from
(1/2)^n
(1/3)^n
(1/m)^n ...
I would STILL miss the irrationals.
It's hard to answer without knowing what precisely you mean by "constructing a line from points".
If you mean "enumerate the set of points lying on a line segment as a countable sequence", then that can't happen by a counting argument: that set is uncountable.
Yeah that's basically what I meant, is there an uncountable argument that can be used to construct R (without resorting to Dedekind cuts)? I can easily construct rationals by a countable argument (since there exists an injective function from Q to N)
One of the ways to go from N to R is to construct infinite sequences of naturals to represent reals. You don't miss any numbers doing this.
Or more conventionally you can use Dedekind cuts or Cauchy sequences of rationals.
0,1
0,0.5,1
0,0.25,0.5,0.75,1
..etc
(1/2)^n
(1/3)^n
(1/m)^n ...
The problem is that a line does not comprise points because points have no dimension. No two points form a line segment until you connect them with a line. No matter how small the inteval is between two points on a line, the points merely define the end points of the line segment between them but comprise no part of the line segment itself. To construct the line segment one would have to place a straight edge between the two points. This can not be done mathematically even with infinite series, the job belongs with the technician who does not worry about infintesimals.
ramsey2879 said:
The problem is that a line does not comprise points ...
A line is what its defined to be. And when studying plane geometry, a line is most typically defined as a set of points. This is adequate, because the geometry is provided by Euclidean geometry.
If you wanted to talk about a line on its own, you would use Euclidean line geometry -- a structure typically consisting of nothing more than points and a betweenness relation.
I really suggest that you learn some topology before you start making brazen assertions about dealing with points in spaces.
(And as an interesting note, please pay attention to the fact specifying a line in the Euclidean plane is, in fact, strictly less information than specifying a pair of points in the Euclidean plane)
Yes, also a line can be defined by two points but the line is not those points. You can also define a line by the equation y = Ax + B which is in effect defining a line by an infinite number of points. But a line has a dimension while points have no dimension. An infinite number of zeros add to nothing which is why you have to rely on more than points such as a betweenness relation. There are of course many ways to define things by use of elements which have nothing in common with the thing defined.
your question about how to construct the line from simple operations of division is one of the oldest questions in mathematics originating in the time of the ancient Greeks.
the Greeks, particularly the Pythagoreans, imagined that God constructed space through a sequence of geometric constructions using a straight edge and a compass. Space was the product of an unending geometric construction. Your example of constructing new points by finding mid-points is one possible straight edge and compass construction but there are many others and it was not known until Gauss what they all were.
At first the Pythagoreans thought that all points of space were simple divisions of whole distances. For them all of space was just ratios of whole straight edge lengths. All numbers were rational and in fact the word rational means ratio.
When they discovered the Pythagorean Theorem they immediately wanted to know which ratio equals the square root of 2 which they constructed as the hypotenuse of a right triangle whose sides have length 1. When they proved the the square root of 2 is not a ratio, it stunned their concept of God and space and they kept this result a secret from outsiders.
Now a new questions came up. That was what are all of the lengths that can be constructed using a straight edge and compass. This was a question about what space actually was when viewed as a geometrical construct.
Gauss finally solved this age old question by proving that all constructable points in space are solutions of a certain type of polynomial equation. From this it was immediately clear that not all points were constructable because many numbers were solutions of polynomial equations different from those that represented straght edge and compass constructions, for instance cube roots.
I believe that there were attempts to generalize the idea of geometric construction and am not sure when people realized that the entire program must fail because even if you construct for ever you will end up with only a countable infinity of points.
I know that the debate over whether infinity even existed raged into the late nineteenth century and that Cantor's construction of transfinite numbers was violently attacked. Dedekind told Cantor that infinity did not exist and when Cantor rebutted that there are infinitely many integers, Dedekind responded, "Yes, but the integers were created by God."
Cantor conceived of real numbers as limits of infinite successions of converging numbers, what we today call Cauchy sequences. To him these limits could only exist as what he called "actual infinities" as points that occur at the end after all possible points in the infinite sequence have been traversed. This idea of an actual infinity flew in the face of the ancient and then still accepted belief that infinite successions could not exist and that the idea of infinity was merely the idea of a finite succession that can always be extended further - such as counting integers. This rejection of infinity goes back to the Greeks and arguments against the possibility of infinite sequences led to many conclusions in philosophy and theology. Zeno's paradox uses the impossibility of infinity to prove that Achilles can never catch a tortoise that is given a head start in a race and therefore that all motion is an illusion. Aristotle directly rejected the idea of infinity as vacuous and said that all it really was was the idea of a finite succession that can always be extended one step further. Acquinas proved the existence of God by arguing that if there was not a first cause then there would be an infinite regress of causes, a clear impossibility. So God exists as the first cause.
Cantor destroyed this attitude by showing that the numbers must exist as actual infinities. And just to seal the point he demonstrated an inductive method of generating infinities successively in order of size. His inductive method was much more powerful than Aristotle and Zeno's method and represents a new way of reasoning not known to his predecessors.
Today we tend to forget these profound historical thoughts and take mathematical objects as givens as if they were never discovered and as though they never affected the way we think. Your naive question about constructing the reals is really a profound question that has led to much of modern mathematics and which helped shape all of intellectual history.
What precisely do you mean by adding infinitely many things? And why should that have anything at all to do with the notion of dimension?
Prove it.
(Hint: you cannot -- there exists a model of Euclidean geometry where the lines are literally pairs of points)
Hurkyl said:
Prove it.
Not in my context, but what do you mean by model? A model could be anything you wanted it to be. My earlier post was based upon what I remembered from my math teacher back in the late 50's to the 1960's. I am not sure what grade I was in.
If you really do not know what a model for an axiom system is, then this discussion is way over your head! (Much of it is over my head!) A "model" is a specific assignment of meanings to the "undefined terms" in the system such that all axioms are true. If there exist a statement "A" in the vocabulary of the system that is true in one model for the system but false in another, then "A" cannot be proved or disproved in that system.
Hurkyl's point is that it is possible to assign specific meaning to "point", "line", etc. in Euclidean geometry such that a line is defined as exactly two points. Therefore, the statement that a line is not two points cannot be proved in Euclidean geometry.
If that is not the case in your "context", then your context is not that of Euclidean geometry.
I think he just means the model of a continuum endowed with Euclidean geometry
A model just means a specific set of objects that are mapped onto the terms in the axiom system so that these objects obey the axioms. Instead of a continuum as you are thinking of, Euclidean geometry, according to Hurky, has a model where lines are just pairs of points. I am not sure what this model really looks like.
But I think you are interested in whether one can construct the continuum - not just any model of the line - from points, using only simple geometric constructions. This age old question is completely reasonable and occupied the minds of mathematicians throughout history.
I suspect that ruler and straight edge constructions were enhanced with other constructive techniques in attempts to perform difficult constructions such as the trisection of an angle. I seem to remember that Descartes tried some novel constructions using curves.
While Gauss showed that ruler and compass constructions could never produce the continuum, the question of how the continuum came into existence remained. Cantor, I think, believed that the continuum arose through completion of Cauchy sequences and he modeled the process of completion as an act of inductive thought, by God no doubt, that defined ''actual infinities" as ideas that represent the entire process of succession. Another way of saying this is that an actual infinity is an idea in which the entire infinite succession of rational numbers in the Cauchy sequence is a predicate.
It is interesting that this philosophical and theological line of thought led to real mathematics. Before our realistic modern attitude that theology and science are separate domains of inquiry, mathematicians and physicists thought they were revealing God's laws. The idea that the universe is fundamentally similar to the mind of God is found in Kepler, Riemann, and many others, (probably Bach and Beethoven).
It is an age old idea that God is that of which all things are predicated. This abstruse theological idea might have been the inspiration for Cantor's actual infinities. After all, an actual infinity is that of which an infinite succession is predicated.
In modern physics we do not worry about these ideas of creation. We just take any model that explains data. Not so historically and certain key advances were made though this fusion of mathematics, physics, and theology. Another example is the Ptolemaic system which was rejected intellectually long before Copernicus because people felt that the centers of the circles in epicycles were arbitrary and therefore could not represent Divine geometry. In modern times we would not have rejected the Ptolemaic system because it provides an accurate model of planetary orbits. In fact, the mathematical technique of epicycles is similar to the modern method of Fourier series.
Right, and that's sort of the key point. Euclidean geometry, as typically presented today, is a theory that talks about "points", "lines", "incidence", "betweenness", and "congruence". It doesn't tell you anything about points or lines 'really are' and it doesn't really care -- you don't need any of that to be able to study geometry.
Of course, sometimes we have specific applications in mind -- e.g. maybe we want to study equations in two real variables (which I'll call x and y). Then we might say that points "really are" pairs of real numbers, and that lines "really are" certain sets of points. Or, maybe we'd prefer to say that lines "really are" equations of the form ax + by = c. Or maybe we'd prefer to say that lines "really are" pairs of distinct points. Or maybe we'd prefer something else entirely.
It makes no difference what the semantics are: Euclidean geometry is the same whether we say that lines are certain sets of points or certain equations or something else entirely. In fact, in practice we often exploit this fact -- rather than binding ourselves to one and only one meaning, we instead use whatever is most convenient at the time. We might make one calculation where we use "line" to mean a pair of points, and then turn right around and use "line" to mean a kind of equation in the very next statement.
Defining a "line" as a certain set of points (where a point is in the line in the set-theoretic sense if and only if the point lies on the line in the geometric senes) happens to be one of the more convenient meanings -- note that we also need to talk about "rays", "circles", "discs", "triangles", "parabolas", and all sorts of other things. Expressing them as sets of points allows us to use set theory to describe how they relate -- it would be very cumbersome to do otherwise! And except for some rather unusual ideas, shapes in the Euclidean plane are completely determined by the set of points lying on them, so nothing is "lost" by expressing shapes as sets of points.
Geometrically, it really looks like a Euclidean plane.
What then is meant by the statement that line AB passes through point C where point C is neither point A or point B? To say that a line is just two points is akin to saying since the boundaries of Utah are all that is needed to define that state then Salt Lake City is not part of Utah. You may also note that the boundaries of a state are not part of that state even though they define it.
It means that the incidence predicate "C lies on [tex]\overline{AB}[/tex]" is true.
The incidence predicate is one of the fundamental undefined terms of Euclidean geometry (in its usual formulation), and there is no reason it should coincide with the set-theoretic relation [itex]\in[/itex].
In particular the "locus of points lying on [tex]\overline{AB}[/tex]" consists of many more points than just A and B.
In fact, if we have a model where lines are pairs of points, there's no formal reason either of those points should even lie on that line!
(However, in the particular model I was imagining, the two points did, in fact, lie on the line)
One particular practical application of "lines are pairs of points" semantics comes from trying to study compass-and-straightedge constructions. Here, it is most natural to define a line as the pair of points used to 'construct' it. (And different pairs can define the same line) Similarly, a circle is most naturally defined as an ordered pair of points (one names the origin, the other gives the radius) -- and is a natural example where a shape is defined by a pair of points, but one of those points doesn't even lie on it!
Then I think your wording is inaccurate and confusing. You are not defining a line AS a pair of two points, but in fact you are defining a line BY a pair of points. PS in my model a line may be defined by any two separate points that lie on the line (or points not on the line if you add other defining elements) but a line and points are two entirely distinct concepts. This does not conflict with the geometry that was taught to me back in grade school.
Hurkyl's statements are very precise and clear. The problem is that YOU have not stated what YOU mean by "point" and "line"!
For example, it is perfectly valid to have a geometry in which your points are "A", "B", and "C" and your lines are the sets {A, B}, {B, C}, {A, C}. In that geometry, the lines consist exactly of two points.
The fact that you do not understand what Hurkyl is saying does not mean he is "inaccurate and misleading". As I said before, I think you are way over your head here.
Isn't [tex]\overline{AB}[/tex]" (which "consists of many more points than just A and B according to what I read here) the "Line". If [tex]\overline{AB}[/tex] is not the line then what do you call it? And my question remains how then can one say as my math teacher said in the 1960's that Line AB passes through point C where A,B and C are distinct points? As I understand it you are saying that this geometry model existed long before the 1960's. Then why wasn't it explained to me like that? Why wasn't it explained to me that a line consists of two points; most likely because mathmaticians did not talk like that back then.
Once again Hurkyl admits that lines are not just "pairs of points" because he says that
the "same line" can be "defined" by "different pairs of points"; thus a line must consist of more than the pair of points that may be used in the delineation of the line.
Each unique pair of points is associated to a unique line segment in your sense (all the points between them), thus you need only think about the pair of points, not all the points in between, as your line segment.
I did not specify whether C was a point between points A and B or not because the line defined by them extends without limits, so C need not be between A and B. As to thinking only of the definition and not the thing defined, why not think of the thing itself?
What is the difference between a definition and the thing defined in mathematics? There is no "thing itself" without you defining it. But now we've ventured into the philosophy of mathematics.
Because semantics don't matter. As far as Euclidean geometry is concerned, the question of what points and lines "really are" is a completely irrelevant topic.
Euclidean geometry is Euclidean geometry whether a line consists of a pair of points, the set of all points lying on it, some other interesting kind of object, or even if we give absolutely no meaning to the word at all -- none of that has anything at all to do with geometry.
Any particular model of Euclidean geometry gives a meaning to the word "line" and "point". It also gives a meaning to the relations "lies on", "between", and "congruent". The meaning given to those five terms can be absolutely anything at all, as long as they satisfy the axioms of Euclidean geometry.
I'm bringing this up to be pedantic. This really is an important fact. We switch between different meanings all the time. The ability to make interpretations is vital (e.g. to interpret Euclidean geometry as talking about pairs of real numbers, so that we can make use of algebra to study geometry -- and in the reverse direction too, so that we can make use of geometry to study algebra).
One of the major advances of classical Euclidean geometry was working out the definition of the projective plane. The purpose for doing so? Because you can swap the meaning of the words "point" and "line", and the geometry of the plane remains completely unchanged. (Geometers had been observing for a while that there were lots of theorems that remained theorems after swapping the word "line" with "point" along with whatever other changes were necessary. Until the projective plane, they had to work with this on a case-by-case basis)
I am not sure I understand the distinction between "sets {A, B}, {B,C}, {A,C}" and the Hurkyl's terms [tex]\overline{AB}[/tex] , [tex]\overline{BC}[/tex] , and [tex]\overline{AC}[/tex] as used to answer my question. Each term defines something by a pair of points. In Hurkyls model they are each the same, but your are treating your terms as distinct. Is my understanding correct that each term is called a line in that particular model, but that the lines in Hyrkyl's terminology extend without limitation while the sets are finite line elements, e.g. a pair of points. If that is so Hurkyl may have been concise in answering my question but I would have been better informed if he instead explained how defining lines as a pair of points e.g. {A,B} leads to a useful model that agrees with the Euclid axioms. Please excuse me for my ignorance.
Thanks for explaning this, it indeed can be a powerful tool to show that separate models each satisfy the same axioms and thus certain theorems apply to each model.
Any particular model of Euclidean geometry gives a meaning to the word "line" and "point". It also gives a meaning to the relations "lies on", "between", and "congruent". The meaning given to those five terms can be absolutely anything at all, as long as they satisfy the axioms of Euclidean geometry.I'm bringing this up to be pedantic. This really is an important fact. We switch between different meanings all the time. The ability to make interpretations is vital (e.g. to interpret Euclidean geometry as talking about pairs of real numbers, so that we can make use of algebra to study geometry -- and in the reverse direction too, so that we can make use of geometry to study algebra).
While these model concepts are all true and have been key to advancing plane geometry, they have little relation to the problem of constructing space that this thread began talking about.
  • #31
Sure. But remember that this line of argument spawned because ramsey was effectively declaring the original question as improper -- because it was considering a line as being made out of points. Everything since then was trying to explain how overly narrow-minded such a view is.
  • #32
I understand. I was just disappointed that the original problem wasn't pursued.
Perhaps you could talk about how in terms of models one could describe ruler and compass constructions. Can we start form two points, a straight edge and compass, and axioms that govern constructions? All new points would arise as intersections of newly constructed lines and circles. For instance if the original two points (line) are used to construct two new points from two intersecting circles these two new points determine a new line whose intersection with the original we would call the midpoint. And so forth.
  • #33
How about calling the intersection of the arc of a compass with the line a point? What axiom of construction would rule that out? For instance is the radius of the compass be required to be in units that are constructed initially from the distance between the two points?
  • #34
I would think that a compass could only be placed initially at two points that were already constructed. Otherwise the points chosen would be arbitrary and not really constructed.
New points would occur as intersections of already existing lines with the compass arc and of two compass arcs with each other.
Another issue would be how to say how lines intersect. If we go purely by Hurky's example where lines are just pairs of points, I am not sure how we get a midpoint. I was going to ask him this.
  • #35
That would be the solved by use of the 1st axiom of construction which is that a line can be drawn between two points, same as to draw a perpendicular bisecter, but you already knew that and was just testing me I think. So constructing a line in effect is to draw non arbitary points on a line by connecting points using a compass and a straight edge all on a single plane. The radius of the compass would always be a distance between the original two points, between constructed points (points of intersection) or a combination thereof. I think you gave a very good rundown of this problem already.
  • Linear and Abstract Algebra
