Construction of tall buildings
  • Thread starter Frenemy90210
  • Tags
    construction
In summary, the conversation discussed the construction costs of 30 separate houses at ground level compared to that of a 30 storied building with one house per floor and the same layout. The question was also raised about the linearity of construction costs for 10 or 20 houses. The conversation also delved into other factors such as water pressure, real estate costs, and additional expenses for elevators and steel. Overall, it was concluded that building taller structures leads to higher incremental costs and there are numerous factors to consider in the construction process.
Frenemy90210
What is cheaper,
the construction cost of 30 separate houses at ground level vs
that of a 30 storied building, with one house per floor and exactly same layout ?
Also, how about 10 or 20 instead of 30 ? Does it linearly scale ?
Frenemy90210 said:
What is cheaper,
Have you any thoughts on the linearity of construction costs?
Frenemy90210 said:
What is cheaper,
I suspect, costs may linear. But, I am not from construction field. So I am purely guessing.
Frenemy90210 said:
purely guessing.
F'rinstance: water pressure?
Likes russ_watters
Does the cost of the real estate factor into this?
Nope. Just the construction costs.
Ok, I guess you are saying water pumping expenses will add up.; Then also, may be elevator costs.
Think of it this way. Suppose you live in a neighborhood where every single house is identical. Tear the roof off of every house except one. Start stacking houses up one on top of the other saving the house with a roof for last. Other than the obvious of only the first story house having a front door that is actually useable, don't you think this would have failed long before the stack got very tall? Modern houses are designed and built to hold their own roof up with not a lot more to spare. However, you would be saving 29 basements or foundations.
I think there would be some additional cost arising due to the lower levels needing to be strengthened so they can safely support higher levels.
Yes, and steel. A 20 floor building is more than just two 10 story buildings on top of each other.
This article suggests that 29 stories using wood framed construction would indeed be rather optimistic.
A tall building requires an elevator, but separate houses need roads - at least walkways - to link them. How far apart they are will influence the cost a lot. Even as "separate" houses, the buildings may have common walls, reducing construction & maintenance costs.
Frenemy90210 said:
What is cheaper,
What is the point of asking this? The number of factors involved is very large and the intangibles are also considerable, so what is it exactly that you are trying to figure out?
Speaking VERY GENERALLY:
The taller you build a building, the higher the incremental costs per story. In fact, after a certain point (obviously depending on the materials, style, function, etc) the cost to add additional floors gets very very high. There are numerous reasons for this -structural, infrastructural, maintenance, stability and construction of load bearing foundation, load bearing walls and internal structure, effects of wind, general other safety issues, proximate construction costs and tons of others. There also comes a point after which you can throw as much money as you want at the project but could not reasonably build it any taller.
Notably, the energy needed to pump water to the upper floors isn't as big of a deal as one might think. That is why there are water tanks on the roofs of tall buildings... not to provide a supply of water, but to maintain pressure. That way it is more just a matter of moving the water rather than having to do all the usual work one would associate with lifting it.
This is all from memory, but I am sure that some basic texts on architecture, urban planning and the like all go into this in abundant detail.
--diogenesNY
After watching a 'social housing' development grow beside my local supermarket, there's more to consider.
A 'tower' block is built one floor at a time, and its frame must support all of them, plus wind-loads, plus cladding that will endure such wind-loads. Are you in a 'seismic' zone ??
The development was built in parallel, with several properties at similar stages at any time. Being low, only 2~3 floors, construction was lighter, access easier. And, they are 'walk-up', so no elevators or complex fire suppression / containment required.
Given 'Western' housing towers are rarely 'elbow to elbow' as in many Asian cities, there's not much saving in 'footprint'...
Getting the pro/con balance right is non-trivial.
@Nik_2213, perhaps you didn't notice it but the OP is no longer with us.
Sorry, I'm tired, and the strike-through is easy to over-look at my three 1600*900 displays' resolution.
Will try harder...
Related to Construction of tall buildings
1. What materials are commonly used in the construction of tall buildings?
The most commonly used materials in the construction of tall buildings are concrete, steel, and glass. Concrete is used for the foundation and core of the building, while steel is used for the frame and structural support. Glass is used for the exterior of the building, providing natural light and aesthetics.
2. How do engineers ensure the safety of tall buildings during construction?
Engineers use a variety of techniques to ensure the safety of tall buildings during construction. This includes conducting thorough site investigations, performing structural analyses, adhering to building codes and regulations, and implementing rigorous quality control and safety measures.
3. What is the typical timeline for constructing a tall building?
The timeline for constructing a tall building can vary greatly depending on the size, complexity, and location of the project. On average, it can take 2-3 years for the planning and design phase, 2-4 years for the construction phase, and an additional 6-12 months for finishing and occupancy.
4. How do architects and engineers determine the height of a tall building?
The height of a tall building is typically determined by the client's needs and the site's limitations. Architects and engineers also consider factors such as building function, structural stability, and design aesthetics when determining the height of a tall building.
5. What are some challenges faced during the construction of tall buildings?
Some common challenges faced during the construction of tall buildings include managing the logistics of construction materials and equipment, dealing with weather and site conditions, coordinating with various contractors and subcontractors, and ensuring the safety of workers and the surrounding public.
  • General Engineering
  • DIY Projects
