Determinism of classical mechanics
In summary, classical mechanics is deterministic if you can know all the initial conditions. However, this is not always possible and there are uncertainties involved.
zezima1
123
Is classical mechanics deterministic?
If so, please explain this.
Suppose we collide two bodies with each other. Assuming they are point particles and using conservation of energy and momentum this gives us a set of equations. Unfortunately these aren't enough to predict their trajectories. To do this we will also need the angle between the trajectories after the collision. Now that doesn't sound very deterministic.
But so I thought that imagining bodies as point particles is not really a valid thing to do in classical mechanics, and that might be the reason why the problem is not deterministic.
So instead I tried to scale them up to an everyday size, i.e. two hockey pucks. Treating them as rigid bodies you can use conservation of angular momentum etc. to obtain even more equations. Problem is however that you still get too many variables.
So indeed, how can you say that clasiccal mechanics is deterministic following this example.
The key is that IF you can know all the variables and such you can determine the outcome of anything in Classical Physics. Without knowing everything you cannot determine anything down to the absolute smallest detail. It isn't actually possible in real life as there is simply no way to know all the variables of a system. Not to mention Quantum Mechanics has shown us that nature isn't deterministic. You simply cannot know the exact conditions of any system, ever.
What's more, you have put your finger on the original objection people had to Newton's approach. Newton said that to know everything about the future, you have to know everything about the present. This raises two problems that people didn't like:
1) they wanted to know why things are the way they are, but they couldn't know that without knowing why things were the way they were, and
2) there is no way to know everything about the present, so there is no way to know everything about the future.
Problem #2 speaks to your issue above. But despite these two significant objections, it was found all the same that Newton's approach does tell you what you need to know (what will happen if I do X given Y), if not what you want to know (why Y). So we kind of stopped objecting to it! (But we should not have been so surprised later on when it was found that Newton's approach was incomplete.)
Know all the variables? Deterministic means that you can predict what happens from knowing all the initial variables.
... And what I wrote was indeed under the assumption that you know all about the initial conditions!
So is your question that it still seems to you, even if you know all the initial conditions, that you'd have too many variables in the final condition? That can't be true, since the final condition involves all the same variables as the initial condition, so there must be the same number of them. You are right that you need to know something about the nature of the collision, like is it hockey pucks and is it elastic, etc., but if you do know what kind of collision you are talking about, you don't need to specify the angle after the collision, you can figure that out given the initial conditions. Perhaps the key point is that you do have to say something specific about the nature of the interaction, otherwise I can just turn all the interactions off and I know perfectly well I can get a valid solution where everything just keeps doing what it was doing before.
To me, the key point in all this is that the concept of determinism never worked at all without also making certain idealizations. One must idealize the initial conditions as being exact, even though they never are, and one must idealize the nature of the collision as being exactly known, even though it never is. Hence, the entire notion of determinism in classical physics was never anything beyond an idealization, and as such should not be taken as seriously as it is, even without ever mentioning quantum mechanics. In practice, any concept of determinism must account for uncertainties in the initial data and uncertainties in the interaction physics, so once you account for all these uncertainties, all you have left is a form of statistical determinism that is actually quite similar to quantum mechanics uncertainties except that the latter are generally much smaller (not larger!) than the former. The idea that the uncertainties in classical determinism could in principle be made arbitrarily small was never anything but an unsubstantiated leap of faith.
Try it for yourself. Assume that two particles with momentum (p1x,p1y) and (p2x,p2y) with masses m1 and m2 collide in a completely elastic collision.. I want to see an expression for the angle.
Work in the inertial coordinate system such that the CM of the two particles is at the origin before the collision. Since the forces are all internal, the CM remains at the origin after the collision.
In this coordinate system there is no "angle". The particles approach along a straight line and separate along the same straight line.
Then transform back into your original coordinate system to find your "angle".
I think what zezima1 wants, among other things, is a proof of the following statement: if the center of mass of particles A and B is stationary, and particles A and B have an elastic collision in a straight line, then they will separate along the same line.
<snip>
Do you admit statistical mechanics as part of 'classical mechanics'?
As I think has been pointed out, unknown variables doesn't weigh in on determinism.
We generally model classical systems deterministically (i.e. their phase trajectories don't cross in phasespace so that there's only one future for each point in the state space). But then some people will add a small noise term, making their system mathematically non-deterministic, but not really modern physics either.
Of course, one could still argue that this noise term is deterministic, but we model it randomly because it's simpler and yields the same qualitative results.
So it always becomes a philosophical issue in the end about how you interpret the discrepancies between model and observation.
I don't believe there is enough information to determine this. You haven't given us any way to determine when the particles impact each other or where. So we don't actually fully know the initial conditions for the system.
I'd prefer they weren't point particle; let's do spherical dirt clods. I'd also like to see compression, friction, hydrogen bond breaking, and thermodynamics of the collision in this problem. So really it's a collision of two ensembles. Thanks for your hard work.
(i honestly don't think it would be deterministic anymore if you considered all of this)
Clearly a rigid particle with zero size is a mathematical abstraction, not something "real". I think Newton would have answered that question with "Hypotheses non fingo". Or as the first "rule of reasoning in natural philosophy" puts it in Principia, "we are to admit no more causes of natural things that such are are both true and sufficient to explain their appearances".
Another way to look at it is using symmetry. Why should there be a collision force that causes a sideways deviation in one direction, rather than the other direction? A Newtonian point particle doesn't have any properties that can break the symmetry here.
For collisions between finite sized bodies, there is a mechanism for generating a sideways force, namely friction. When you specify a model of the frictional forces (e.g. Coulomb's "laws" of friction) you have sufficient information to get a unique solution. But I don't see the purpose of inventing a hypothetical effect in collisions between point particles, for the sole purpose of making the situation indeterminate, unless you can provide some experimental evidence to back up your assertion that it is indeterminate.
I think the only point of even thinking about this possibility is to demonstrate that Newtonian mechanics for point particles does not by itself logically force determinism (although with very weak additional assumptions, like the symmetry considerations you brought up, it does very clearly lead to complete determinism).
There's no such thing as a point particle in classical mechanics. There are times when you can pretend an object is a point particle and get a very good answer, other times not. For example, if you have two solid balls gravitationally attracting each other, and their radii are much, much smaller than the distance between them, you can pretend they are point particles and get a very good answer. But if they collide, you break your original assumption that they are far apart compared to their radii, and then you cannot treat them as points. Now they are solid balls, and you have to know the details of the collision in terms of balls, not point particles. Any time you are pretending you have point particles in classical mechanics and come up with such an indeterminacy, you have violated the assumptions you made that allowed you to treat them as point particles.
What law in classical mechanics forbids point particles?
None. Just because they are not forbidden does not mean they exist. What experiment proves they exist?
Well, classical mechanics has been superseded anyway by later theories, so the whole question of whether or not point particles could or would exist classically is a purely theoretical issue, not one amenable to experimental testing. And I maintain that point particles make total sense classically.
If you find yourself getting too comfortable with point particles, just imagine what the force of a negative charged particle on a positive charged particle right next to it. Since they're two point particles and they touch, d = 0. Thus, the electromagnetic force (or gravitational force) between them is infinite.
They make sense only under certain conditions. When those conditions are not met, they make no sense. The collision of two classical point particles is a situation where those conditions are NEVER met.
Classical physics NEVER uses the concept of a point particle except as a limiting condition. "In the limit of blah blah" and if "blah blah" is not true, the object cannot be approximated as a classical point particle. "blah blah", whatever it is, is NEVER true when considering the collision of two classical bodies. You cannot give one instance where classical physics deals with a point particle except as an approximation.
Your position is that point particles make total sense classically. How do you defend this position? What is your argument? If it is simply an opinion, then what you are saying is that determinism in classical physics is less fundamental than your opinion, and I can't believe you mean that.
Why not adopt the viewpoint that the lack of determinism in the collision of classical point particles is proof that they do not make sense under all classical conditions?
Point particles with no external fields would never collide anyway. And if they have external fields, like the electric field of an electron, then the collision will involve the fields, and can be calculated deterministically in principle. I think the key point here, which relates to what you need to know to determine those scattering angles, is that it is true that simply knowing the initial positions and velocities of all the particles does not suffice in producing a deterministic outcome, because you also have to know the fields (or the nature of the collisions, however you choose to model them). That does not ruin determinism-- it means that part of what you have to determine is the fields (or whatever is the nature of the collision). As I said above, if you turn off all interactions, you obviously "determine" different outcomes, so the nature of the interactions has to be in there to consider anything deterministic.
Of course, that isn't what actually spoils determinism. Uncertainty does that, whether it be uncertainty in the nature of the fields, or uncertainty in the initial conditions. This is the flaw in imagining that classical physics was ever a deterministic theory-- there was never any reason to imagine that classical physics was devoid of uncertainty.
Related to Determinism of classical mechanics
1. What is determinism of classical mechanics?
Determinism of classical mechanics is the belief that all physical events in the universe are determined by previous events and the laws of nature. This means that if the initial conditions of a system are known, then the future behavior of that system can be predicted with complete accuracy.
2. How does determinism of classical mechanics differ from determinism in other fields?
Determinism in other fields, such as philosophy and psychology, often involves the concept of free will and the idea that human actions are not completely determined by previous events. In classical mechanics, determinism is based on the laws of nature and the assumption that the universe operates in a predictable and deterministic manner.
3. Is determinism of classical mechanics still considered valid in modern science?
While determinism of classical mechanics was a widely accepted belief in the past, it has been challenged by quantum mechanics and other theories. Some scientists argue that quantum mechanics introduces an element of randomness and uncertainty into the universe, making determinism of classical mechanics no longer applicable in all cases.
4. Can determinism of classical mechanics be tested or proven?
Determinism of classical mechanics is a philosophical concept rather than a scientific theory, so it cannot be tested or proven in the same way that scientific theories can. However, the success of classical mechanics in accurately predicting the behavior of physical systems does provide evidence for the validity of determinism in this context.
5. What are some potential implications of determinism of classical mechanics?
If determinism of classical mechanics is true, it could have significant implications for our understanding of the universe and our place in it. It would mean that everything that happens is a result of previous events and the laws of nature, and that free will may be an illusion. It also raises questions about the role of consciousness and whether it is simply a product of deterministic physical processes.
