Difference between acoustic pressure and fluid pressure
In summary, acoustic pressure is a dynamic pressure perturbation that is measured on top of any existing static or dynamic pressure variations in a fluid medium. It is the variation in pressure with respect to time and can be measured within the human hearing range of 20 to 20,000 hz. Acoustic pressure values are often very small, with the threshold of hearing being 20 microPascals and a sound pressure level of 100 dB having an actual pressure magnitude of 2 Pa. A microphone can be thought of as a sensitive dynamic pressure transducer, as it measures small displacements caused by acoustic pressure waves. In relation to this, there is a similar relationship between particle velocity and fluid velocity.
Saumya Kar
While the sound waves travel in a medium, let's say a fluid, what is the difference between fluid pressure and acoustic pressure ? Are these entities same?
Acoustic pressure is dynamic, so you are measuring a pressure perturbation (variation). Think of a DC signal vs an AC signal. The acoustic pressure would be a (usually) very small AC pressure signal. It would be measured on top of any existing static or dynamic pressure variation present in the fluid. Acoustic pressure is the variation in pressure wrt time. Human hearing range is generally accepted to be betwen 20 and 20,000 hz (cycles per second)...so if you have pressure that varies with time in that range, you'll be able to hear it. Acoustic pressure values can be very small. The reference pressure for the threshold of hearing is 20 microPascals. A sound pressure level of 100 dB would have an actual pressure magitude of 2 Pa. Compare that to a typical fluid pressure in whatever application your are thinking of. A microphone is just a very sensitive dynamic pressure transducer...the microphone diaphragm measures very small displacements as acoustic pressure waves impinge on it.
Likes Saumya Kar
Thanks David,
The explanations helped a lot.
An extension to the original question is, is there a similar relation between 'particle velocity' and 'fluid velocity' ?
Best Regards
Saumya
Related to Difference between acoustic pressure and fluid pressure
1. What is the difference between acoustic pressure and fluid pressure?
Acoustic pressure is the pressure that is created by sound waves, while fluid pressure is the pressure exerted by a fluid on its surroundings. Acoustic pressure is a type of mechanical pressure, while fluid pressure is a type of hydrostatic pressure.
2. How are acoustic pressure and fluid pressure measured?
Acoustic pressure is typically measured in units of decibels (dB), while fluid pressure is measured in units of force per unit area, such as pounds per square inch (psi) or pascals (Pa).
3. What are some examples of where acoustic pressure and fluid pressure are important?
Acoustic pressure is important in various applications such as noise control, sonar, and musical instruments. Fluid pressure plays a crucial role in hydrodynamics, engineering, and many other fields.
4. How do acoustic pressure and fluid pressure affect the human body?
Exposure to high levels of acoustic pressure can damage the human ear and cause hearing loss. Fluid pressure can also have significant effects on the human body, such as the sensation of pressure in the ears when diving or flying in an airplane.
5. Can acoustic pressure and fluid pressure be converted into each other?
No, acoustic pressure and fluid pressure are two distinct types of pressure and cannot be directly converted into each other. However, changes in one type of pressure can affect the other, such as sound waves causing changes in fluid pressure.
  • Mechanical Engineering
  • Classical Physics
