Electric Field Divergence of Monochromatic Plane Wave: Why is it Zero?
In summary, divergence of the real part of an electric field of a monochromatic plane wave is always zero.
zb23
Why is the divergence of an amplitude of an electric field of a monochromatic plane wave zero?
Likes Alex Ford
Humm... I don't think I understand your question.
Divergence is a vector function, not just amplitude, which is why we can use it on E-fields, which are vectors.
One of Maxwell's equations (Gauss' Law) says ∇⋅E=ρ/ε0; the divergence of any E-field is 0 unless it is measured over a region that encloses an electric charge.
Likes vanhees71
ampitude can be written as a vector compex function in most generalised way.
  • Skeptical
Likes Vanadium 50, Dale and DaveE
What does ## \nabla \cdot \bf D = 0 ## say?
(no charge density assumed)
The way you are saying this is a bit confusing. Divergence is an operator that can be applied to vectors; the result of applying this operator to a vector is a scalar.
Likes DaveE and etotheipi
yes. I was also kind of sloppy in mixing the derivative and integral forms when I said "measured over a region...".
Right, so if I can say ## \nabla \cdot \bf E = 0 ## for any electric field E in the absence of charge, am I home or not?
So,question: can you say that? Did someone say it about 140 years ago?
Yes.
Yes, it's the charge-free case of the first Maxwell equation.
Likes etotheipi
So is divergence of a complex vector amplitude of electric field of a monochromatic plane wave always zero?
I don't know where "complex vector amplitude" is coming from. In classical EM, the electric and magnetic fields are vectors with real components, and the divergence of the electric field vector when no charges are present, which will be true for an EM wave in vacuum, is zero by the first Maxwell equation.
If you ask "why" this is true, there is no answer beyond the fact that Maxwell's Equations have plenty of experimental confirmation within their domain of validity.
I think you didnt understand me. My question is more mathematical than physical. When you derive solution for wave equation from maxwell equations, sometimes it is more general for you to write your solution for wave equation in the form of complex vectors, and then you take just real component. So, if I write my solution as E*e^i(wt-k*r), where my E is my amplitude written as complex vector and k,r are my wave vectors and radii vector, than if you put this solution for wave equation for monochromatic plane wave in gauss law in vacuum you ll get two parts, one of them if div (E), where E is complex amplitude.
Griffits and Jackson, that is standard literature for classical electrodynamics, write general solution for wave equation for monochromatic wave in complex notation. Sorry if I am a little bit confusing. I hope I explained my troubles better this time.
Doing this is a convenience for calculation, but to get the actual physical answer at the end you're going to take the real part, since that's what has physical meaning. The divergence of the real part of ##E## is what is zero.
I understand but E is not longer a vector field it is just an amplitude vector that doesn't have to satisfy maxwell equation.
E is not a vector field that represent electric field*
If these statements are true, then your question about why the divergence of this ##E## is zero makes no sense. The only ##E## whose divergence has to be zero in charge-free space is the ##E## that appears in Maxwell's Equations.
In short, your question appears to be based on a misconception, so it is unanswerable. Thread closed.
Likes etotheipi
Related to Electric Field Divergence of Monochromatic Plane Wave: Why is it Zero?
1. What is the electric field divergence of a monochromatic plane wave?
The electric field divergence of a monochromatic plane wave is a measure of the change in electric field intensity at a given point in space. It is a vector quantity that describes the amount and direction of electric field flow at that point.
2. Why is the electric field divergence of a monochromatic plane wave zero?
The electric field divergence of a monochromatic plane wave is zero because the electric field is constant and does not change with respect to time or space. This means that there is no source or sink of electric field, resulting in a net flow of zero.
3. How does the electric field divergence of a monochromatic plane wave relate to Maxwell's equations?
The electric field divergence of a monochromatic plane wave is a fundamental concept in Maxwell's equations. It is represented by the first equation, known as Gauss's law, which states that the net electric flux through a closed surface is equal to the charge enclosed by that surface.
4. Can the electric field divergence of a monochromatic plane wave ever be non-zero?
In theory, the electric field divergence of a monochromatic plane wave can be non-zero if there is a source or sink of electric field, such as a point charge or dipole. However, in most practical applications, the electric field divergence is assumed to be zero due to the absence of these sources.
5. How does the electric field divergence of a monochromatic plane wave affect the propagation of the wave?
The electric field divergence of a monochromatic plane wave does not affect the propagation of the wave itself. However, it is an important concept in understanding the behavior and interactions of electromagnetic waves with matter, as it is related to the distribution of charges and currents in a given medium.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
