Asilartus
- 1
Hi, I am sorry I just forgot formula to calculate how long it will take to boiling water -> some lower temp.
Thanks in advance.
Thanks in advance.
The equation for time to boil water is t = T/(4.186M) where t is the time in seconds, T is the temperature difference between the initial and final temperatures in degrees Celsius, and M is the mass of water in grams.
To use the equation, first determine the temperature difference between the initial and final temperatures of the water. Next, measure the mass of the water in grams. Plug these values into the equation t = T/(4.186M) and solve for t to find the time in seconds.
The specific heat capacity is the amount of heat energy required to raise the temperature of 1 gram of a substance by 1 degree Celsius. It is included in the equation to account for the energy needed to heat up the water to its boiling point.
In the equation t = T/(4.186M), T represents the temperature difference between the initial and final temperatures of the water. This can be calculated by subtracting the initial temperature from the final temperature.
The variable "t" represents the time it takes for the water to reach its boiling point. It is measured in seconds and can be calculated using the equation t = T/(4.186M).
