Can Derivatives Exist at Discontinuities of a Piecewise Function?
  • MHB
  • Thread starter mathmari
  • Tags
    Existence
In summary, the conversation discusses the function $f:[-1,1]\rightarrow \mathbb{R}$ defined by \begin{equation*}f(x)=\begin{cases}\frac{1}{k} & \text{ for } x\in \left (\frac{1}{k+1}, \frac{1}{k}\right ], \ k \in \mathbb{N}\\ 0 & \text{ for } x=x_0=0 \\ \frac{1}{k} & \text{ for } x\in \left [\frac{1}{k}, \frac{1}{k-1}\right ), \ k \in \mathbb{Z}\setminus \
  • #36
mathmari said:
But then if $f_+'(x_n), f_-'(x_n)$ and so $f'(x_n)$ (for $n\in \mathbb{N}_0$) exist, do they not have to be equal to $0$ ?
Not necessarily.As we have seen, $f_+'(x_0)=f_-'(x_0)=f'(x_0)=1$, while $f'(x)=0$ everywhere else where $f'(x)$ is defined.
That is, $f'$ has a removable discontinuity in $x=0$. (Nerd)That's because for $f_\pm'(x_n)$, we evaluate $\frac{f(x_n+h)-f(x_n)}{h}$, where $f(x_n+h)$ and $f(x_n)$ can fall into different intervals.
And for the limit with $x\in D$, we evaluate $\frac{f(x+h)-f(x)}{h}$, where $f(x+h)$ and $f(x)$ are in the same interval. (Thinking)
  • #37
Why are $f(x+h)$ and $f(x)$ in the same interval when $x\in D$ ? (Wondering)
I have also a question about the case $n=1$.
I like Serena said:
I'm a bit unsure about $f'(x_1)$. It seems to me that it does exist and is equal to $f_-'(x_1)$.
That's because if we calculate $f'(x)$ according to $\varepsilon$-$\delta$ definition of a limit, that's what we'll find. (Thinking)
Is this because $x_1^+$ is not in the interval that we consider? (Wondering)
I like Serena said:
The first limit explicitly excludes $x_n=1$, so we cannot calculate that limit.
We can calculate that second limit though.
Note that all $x_n\not\in D$, but that does not prevent us from calculate the limit to it. (Thinking)
We have that $\displaystyle{\lim_{\substack{x\rightarrow x_n+0, \\ x\in D, x_n\neq 1}}f'(x)}$ is not defined, since $1^+\notin D$, right?
For $x\rightarrow 1^-$, we have that $x\in D$, or not? That would mean that $f'(x)=0$, right?
So, we get $\displaystyle{\lim_{\substack{x\rightarrow x_1-0\\ x\in D}}f'(x)=\lim_{\substack{x\rightarrow x_1-0\\ x\in D}}0=0}$, right?
(Wondering)
  • #38
$x$ is inside an open interval.
And for $h$ small enough, $x+h$ must be in that same interval.
So when we approach the limit close enough, we have $x$ and $x+h$ both in an interval where the function values are the same. (Thinking)
Yes.
The problem is that different texts define a limit slightly differently.
Some texts require that the upper limit and the lower limit must both exist for the limit to exist.
But certainly the generalized definitions of a limit do not require this.
See wiki that begins explaining the first simplified form, which is actually only for functions $\mathbb R\to \mathbb R$, so it would effectively not even apply to our problem.
And that definition is then inconsistent with the later form in the sections Functions on metric spaces and Functions on topological spaces. (Nerd)
Yep. (Nod)
  • #39
Ah ok!
I see! So, we have that $f'(x_1)$ exists and this derivative is equal to $f'(x_1)=f_-'(x_1)=0$. At the case $x_0=0$ we have that the derivative is discontinuous since the limit is equal to $0$, $\displaystyle{\lim_{\substack{x\rightarrow x_0+0, \\ x\in D}}f'(x)=\lim_{\substack{x\rightarrow x_0-0\\ x\in D}}f'(x)=0}$ but the value of the derivative is $f'(x_0)=1$. At the case $n\in \mathbb{N}\setminus \{1\}$ we have that the limit is equal to zero, but the value of $f'(x_n)$ doesn't exist. Does this mean again that the derivative is discontinuous in $x_n$ ? Or would we have this meaning only if $f'(x_n)$ would exist and would be different from $0$ ? (Wondering)
  • #40
mathmari said:
Ah ok!
Yep. (Nod)
Continuity and discontinuity are only defined at points where the function (in our case the derivative) is defined.
So indeed, we can only say that $f'$ is discontinuous in $x_n$ if it exists and has a limit that is different. (Happy)
  • #41
I see! Thank you so much! (Happy)
  • Topology and Analysis
