Exploring the Impact of Gravity on Time and Distance
In summary: You are correct in saying that the speed would be the factor in dilating time, however, the angle of the interrupt would also play a role. If the angle of interruption was too great, then the object would be deviated from the path altogether and would reach its destination at a different time.
Mayankv1994
I'm feeling so frustrated that I typed out a whole detailed write up & it got washed off. Damn it.
1. How does gravity dilate time? I've been trying to get a conceptual answer that is easy to understand, for I have no background in physics whatsoever & am reading up out of interest.
Today however I started to wonder if the question itself was wrong, & that if I should be asking myself how gravity dilates/warps spacetime, since time isn't absolute.
2. Let us say an object travels from point A to B in space at Y Km/h, reaching B in X seconds. Let us also assume the object has traveled throughout its journey in linear motion, without being gravitationally interrupted/deviated from it's pathway.
If this same object were to travel from the same point A to B in space at Y Km/h, this time however being interrupted at some point by the gravitational pull of a body of mass, deviating off path, and into orbit of the body of a considerable mass. The speed & angle of this object however allows it to escape the the gravitational pull of this large body, to get back on track and reach point B. Due to momentary deviation, the interrupted object would obviously have taken a slightly curved path, meaning that it would have traveled a longer distance in reaching B, & since the speed was the same for the interrupted & uninterrupted object, the interrupted object would've taken a longer period of time to reach point B.
I was not satisfied with this conclusion of mine, due to the fact that it has been said that gravity dilates time (hence the 1st question to understand this whole concept), & since the interrupted object was affected by the gravitational pull of the large body. Shouldn't this mean that my above conclusion that the interrupted object would've taken a longer period of time to reach B would've been wrong, since time has been dilated at some point, making the factor of time uncomparable?
P.S. I would appreciate it if I could get a non-mathematical answer, though I would be able to understand the basic stuff (I do advanced maths).
Thank you so very much.
Cheers, & happy new year.
This is a drawn picture explaining difference in distance traveled when interrupted
First of all, the picture you drew is impossible, because if a planet (or a body) was to interfere with the object, then the object will deviate from the path ITSELF.
But, theoretically speaking for your case, if it was to happen that way, gravity will be too weak to actually dilate time.
I am in no ways a Physics major or minor, but I remember something about gravity affecting the SPEED of the object which dilates time. For example, a black hole is a point of "infinite" gravity, which accelerates the object subject to its event horizon indefinitely to the point of "passing" speed of light. In this case, the speed itself will be the factor in dilating time as the universe wants you to stay within the boundaries of light speed; space will slow down time as to make the speed slower (time is in denominator).
This is a very crude (and possibly highly incorrect), but this is my understanding of the relationship between speed, gravity, and time.
Yes I already knew that dilation is a sort of an adjustment made to ensure that the boundary (speed of light) isn't crossed.
I also understand that this it is highly unlikely that such a scenario as shown in the picture will ever be possible though just for theory sake I came up with it. How can you say that gravity would be too weak too dilate time in this case? If you were to travel at a certain speed & at a certain angle through the gravitational radius of a black hole for example, you would be able to escape being sucked in. If this is possible, why wouldn't it be possible the way I put it in my question?
Related to Exploring the Impact of Gravity on Time and Distance
1. How does gravity affect time and distance?
Gravity affects time and distance by warping the fabric of space-time. This means that objects with mass create a curvature in space-time, causing time to slow down and distances to appear shorter.
2. Can gravity impact the accuracy of time measurements?
Yes, gravity can impact the accuracy of time measurements. This is known as gravitational time dilation, where time moves slower in areas with stronger gravitational forces. This effect has been observed and measured using atomic clocks on Earth and in space.
3. How does gravity affect the trajectory of objects?
Gravity affects the trajectory of objects by pulling them towards the center of mass in a curved path. This is known as gravitational acceleration and is responsible for the motion of planets, moons, and other celestial bodies in our solar system.
4. Can gravity be used to travel through time?
While there are theories about the possibility of using gravity to travel through time, it is currently not possible with our current understanding and technology. The effects of gravity on time are only significant at extreme speeds and in the presence of massive objects.
5. How does the strength of gravity vary on different planets?
The strength of gravity varies on different planets depending on their mass and size. The larger and more massive a planet is, the stronger its gravitational pull. For example, the gravity on Earth is stronger than on Mars, which is smaller and less massive.
