- #36
Baluncore
2023 Award
- 14,544
- 8,441
I did not bother to follow your calculations once you departed SI units for cal/g.JoeSalerno said:My only questions now are did I do my math right? Because I only got 30mm, so it doesn't sound right.
Energy is delivered perpendicular to the surface, over the area of the projectile, the projectile will spread out sideways as it delivers the energy which will then radiate within the steel. My guestimate is that the energy will be concentrated within a cone angle of about 50°.JoeSalerno said:And also, when you mentioned 50 degrees earlier, was that for the frustum?
Not everything is obvious. If the projectile had a hardened rod as a core it would penetrate deeper with a sharper cone. When tanks were first introduced during WW1, it was found that by reversing the bullet in the cartridge before firing, it could penetrate the light armour of the tank, while a pointed bullet traveling forwards would not.
